My last Adamas Custom Order
DetlefMichel
Posted 2014-07-10 12:12 PM (#489530 - in reply to #489526)
Subject: Re: My last Adamas Custom Order
May 2011
The Thomastik strings come from Austria. Here in Germany I pay 14,19 Euros for one AC111 6string set(~19,30 USD). A good source is www.martinsmusikkiste.de, if you order in small quantities, there will be no customs, only shipping.I play these strings for many years and I will be terribly upset if they may be discontinued one day. The only guitars that are not suitable for th´s are Martin dreads, they need more tension. The th´s are especially phantastic on 12strings!! Even if you use standard pitch you will have less than 120Kp tension with.11-50, and I detune every 12string1/2step, so the (old) guitar tops will survive much longer.(And my old hands, too...) This set has(from e1 to E619,8lbs,18,4lbs,20,3lbs,22,6lbs,22,1lbs,22,1lbs. You see, very balanced.The wound strings are little flatted, thus you have no noise when moving on the fretboard and the sound is very very clean. Best on offset-soundhole-guitars like Adamas or Elite.
bburg
Posted 2014-07-11 1:29 PM (#489572 - in reply to #487931)
August 2009
+1
I also use them on most of my guitars. The best you can get.........
Bernie
bburg
Posted 2014-07-11 1:30 PM (#489573 - in reply to #487931)
August 2009
+1
Bernie
d'ovation
Posted 2014-07-11 2:33 PM (#489575 - in reply to #487931)
Sounds interesting, just checked Strings and Beyond and the 12-string sets go for more than $40 on sale ... yikes. Will have to watch for a real deal on there.
