FIX THE OP PRO LOW OUTPUT
Posted 2019-12-26 10:17 PM (#550813 - in reply to #526770)
Subject: Re: FIX THE OP PRO LOW OUTPUT
Dan, I passed along that Op Pro out of my own self interest. I figured that once you got into it, you'd understand what was going on and if I ever had a problem with the remaining one in the 87C, that you might have a handle on trouble shooting it.
DanSavage
Posted 2019-12-27 7:00 PM (#550826 - in reply to #550811)
June 2012
MatureWolf - 2019-12-26 2:11 PM
While I was doing this mod I wondered why Ovation would cut the output. Then, I remembered that the ADII as well as the OFC II guitars have a boost switch that 'increases' output 4 dB. I'm guessing that the 'boost switch' doesn't really boost anything. Instead it has a separate daughter board that has different values of resisters, such as those used in this mod, to remove the inhibition built into the circuit that you found.
Seems you got the point, Dan.
Supposedly, 1769 ADII has special "modified" can (=housing) + outer "Boost" switch whilst OP-Pro preamp itself is very standard.
Best,
That's interesting that the mod was in the can and not the pre-amp.
DanSavage
Posted 2019-12-27 7:02 PM (#550827 - in reply to #550813)
June 2012
moody, p.i. - 2019-12-26 8:17 PM
The one you gave me is the first one I modified. I never did find the problem with the gain knob cutting out when turned > 9.
If you ever need a replacement OP-Pro, the best place to buy them is from Thomann Music in Germany. It's faster, cheaper and easier to buy a replacement from them than to try to fix a broken one.
Posted 2019-12-27 7:51 PM (#550830 - in reply to #526770)
I know. I was just teasing you.....
