The right amplifier for my Adamas guitars
Flash1717Legend
Posted 2014-11-28 1:12 PM (#501375 - in reply to #494495)
Subject: Re: The right amplifier for my Adamas guitars
September 2010
Although I do not have an Adamas - I do own a couple Ovations and gig regularly. The Traynor AM Custom is a marvelous amplifier. Full Compass sells them for $999. Made in Canada - really well made. 35 pounds, metal grill, full wood box, 3 channel mixer, outstanding Fx.
ohiopicker
Posted 2014-12-17 8:49 PM (#503874 - in reply to #494495)
Subject: RE: The right amplifier for my Adamas guitars
September 2011
May I give you a general answer? I own an Ovation 6751 12 string currently, but have owned a half dozen other Os in the past. I primarily play the Martins. That having been said, all of my Ovations paired well with whatever acoustic amp I had at the time (fender Acoustasonic, Marshall, A.R Acoustic, Crate Taos, Kustom, Roland. I ca't say it was nearly that easy with my other guitars. The Acoustasonics and the Roland were a particularly good match.
To summarize, you should be able to find a number of good matches! Let us know what you pick.
Edited by ohiopicker 2014-12-17 8:51 PM
hwebster
Posted 2015-01-18 9:39 AM (#504833 - in reply to #494495)
June 2005
I will be cleaning some space, have a TR30 amp if interested. They are great.
Hector.
Edited by hwebster 2015-01-18 9:40 AM
AdamasW597
Posted 2015-01-22 11:14 AM (#504947 - in reply to #494495)
November 2008
If you can find a 100-watt Trace Ellliot TA-100. One of the British ones. Buy it. I still have the 200-watt TA-200 with 8 speakers and that's what I run my Adamas through. There isn't a drummer anywhere that can play louder. If you're playing in a solo or duo situation the 100-watt trace will be fine. These amps sounds like an acoustic only louder. They have an onboard Alesis reverb with 16 settings. Just try to find one and play it. Go look at the artists that use Trace Elliot. Then tell me they're old and outdated.
