Electronics Frustration
bburg
Posted 2017-04-10 1:07 PM (#533613 - in reply to #533185)
Subject: Re: Electronics Frustration
August 2009
There are two output units with XLR built in, one is the original built in guitars with the OP-PRO and feeds the OP-PRO with pantom power. If you use it with an OP-Pro-Studio or VIP and you have connected the XLR cable to a phantom power source maybe your preamp gets burned down.
The second one is built in guitars with XLR and an OP-Pro-Studio and maybe an VIP (for that I'm not sure). This unit does not feed Pantom Power, even not with an OP-PRO. I found no way to check it out, only by using an OP-PRO (that's important) an look wheather pantom power is working or not.
Bernie
bvince
Posted 2017-04-10 1:53 PM (#533615 - in reply to #533185)
September 2005
I'll just be honest and upfront in saying that I know very little about the whole idea of "Phantom Power"... I HAVE found what looks to be a pretty clear and comprehensive article Im 'planning to read though. ... http://audioundone.com/phantom-power
From what I have viewed so far though, my idea of adding on a condensor mic at the sound-hole, tied in to the preamp system, may require a bit of consideration. Sounds like a good sit down read on the porch, with a nice glass of ice tea
