Elite 1768 rehab part 2
| davegardner0 |
Joined: October 2016 Posts: 23 Location: NJ, USA | Hi all, https://imgur.com/a/ovation-1768-bent-top-2Jszd I tried steaming the top and putting weights on it, which undid the warp just a little bit. But the braces themselves are definitely bent. I put the guitar back together and it surprisingly plays okay with a correct neck angle, but it still looks terrible and doesn't sound very good. I couldn't glue the fretboard extension down since the top is so warped underneath, so the high notes don't ring out at all. The birch ply behind the soundholes is delaminated a bit. I think the top has continued to shrink, too, as the binding is pulling away on the treble side of the lower bout. The fretboard wood is really rough textured too, which I don't like. I wanted to ask the group about the feasibility of a retopping project and see if there's anything I'm overlooking... Here's what I'm envisioning for the project:
I don't have a go-bar deck. Can I use deep-throated clamps to glue on the braces one by one? The fretboard extension has a tiny bit of back bow (visible in one of the photos) but I think this will be fine when it's glued to the top. Do you agree? How do you guys set up clamps to glue on the freboard extension and bridge without a conventional soundhole? I'm thinking maybe use rare earth magnets? How do you recommend removing the top? Heat gun and putty knife, to take the binding off first and then the top? I assume the kerfing (or whatever is in there?) stays attached to the bowl and is reused?
Some photos of the guitar as it sits now:
| DanSavage |
Joined: June 2012 Posts: 2346 Location: Pueblo West, CO | davegardner0 - 2025-07-05 10:06 AM 6. Fabricate and glue on some thin laminate around the soundhole areas on the back When I did my 1778T, I made the cross-grain reinforcement go all the way across the top a la the 1537. This required that I 'notch' the underside of the braces. That was unnecessary. The main purpose of the reinforcement is to ensure the top doesn't split between the sound holes. As such, you only need reinforcement over the sound holes in the same way later Elites are done. The image below is from a 2078 TX.
11. (Do I need to do something here with the bowl to make sure the neck is at the correct angle?) I have a jig I made that simulates a tool used by the factory. I use this to set the neck angle when the top is being glued.
At one time I tried a bowl-bend using heat, but I found when doing Jen Chapin's 1613 that the neck angle can be reset when the top is glued. Once glued, the neck angle will remain the same. 15. Glue on the bridge (or maybe after finishing?) You'll definitely want to glue the bridge on after finishing. To ensure a good glue joint, mask the area of the bridge before applying the finish, then once the finish is done and you've cut and polished the top, remove the masking tape and use naphtha to clean any glue residue. Do Ovations use a radius on the top? I don't have a radiused sanding dish, but could buy one. It would be great if I could use one in a "standard" radius for building more conventional acoustic guitars, which is something I'd like to do in the future. Generally speaking, Ovations are one of the few guitars with no radius to the top. I don't have a go-bar deck. Can I use deep-throated clamps to glue on the braces one by one? I suppose you could use clamps for the braces, but if you're planning to build/re-top guitars in the future you'd probably be better off just spending the money to buy a go-bar deck. I bought mine from Blues Creek Guitars. They sell for $110. (See: Gobar Deck) As it sits now, the guitar has a full-width laminate across the top in the soundhole area. I see in the thread I linked above that Dan suggested in future builds only adding the laminate laminate behind the soundholes, which I'd also like to do. Any pitfalls I should be aware of? If you're going to use torrefied wood for the top and braces, I would also make the doubler from torrefied wood. I have on hand here a StewMac torrefied sitka top and a set of torrefied bracing stock, would those be acceptable to use? What top thickness do you guys recommend? I usually string my acoustics with 12's, by the way, and definitely like a responsive-feeling guitar. I'm not a heavy-handed player. Stewmac torrefied Sitka is fine. Ovation guitars are one of the few to feature tapered tops. IOW, the wood is thicker near the neck and thinner near the bottom. I made myself a custom tool to do this. The top is place in the tool, then it gets tapered when it goes through the belt sander. I usually go for ~.110" at the top and ~.094" at the bottom. I'm sure you would get good results with a top that isn't tapered. Just make the whole top ~.110". The torrefied wood will be much more responsive than a normal top. Keep in mind that torrefied wood has less shear and peel strength and normal wood. Because of this I usually recommend and use Extra Light strings so It doesn't pop the bridge off the top. I've read in some of the retopping threads about heating the bowl to change the neck angle. Is that something I need to do? Is there a way to "measure" the alignment of the neck heel and bowl before I put everything together. Either way, I'm thinking of installing the frets after gluing on the neck, so that I get a chance to sand the fretboard with everything assembled. This is how I've refretted acoustics in the past. Is there any issue with doing things in this order? Only thing I can think of is maybe it'll be really hard to trim the fret ends where the fretboard tapers at the end. If you go to my Harry Chaping 1613 thread, page 3, I explain how I did the neck reset while gluing the top to the bowl. It worked so well, this is my go-to method to reset the neck. I tried a bowl-bend once, but the bowl eventually reverted back to it's previous condition. In the photo below, the top is being glued at the same time the neck is being reset.
If you adjust the TR so the neck is flat, you can lay a straight edge along the middle so the end of it is near the bridge. On a properly adjusted neck, the straight edge should be just above the top of the bridge, like this: How do you guys set up clamps to glue on the freboard extension and bridge without a conventional soundhole? I'm thinking maybe use rare earth magnets? On my 1778T, I used Stewmac deep throat clamps for the bridge. You'll have to remove the bottom adjuster to get it through the sound hole, then reinstall it once it's inside the guitar.
How do you recommend removing the top? Heat gun and putty knife, to take the binding off first and then the top? I assume the kerfing (or whatever is in there?) stays attached to the bowl and is reused? The binding and purfling can just be peeled off without heat. I use an Xacto chisel to remove the top. It gets slid between the lining and the wood of the top. Since you're replacing the top it won't matter if the wood gets a little chewed up. In the photo below you can just see the tip of the chisel.
| arumako |
Joined: October 2012 Posts: 1093 Location: Yokohama, Japan | Hi davegardner0,
The above is on a mid-depth bowl, but the door stop clamp works on deep and super shallow bowls as well. Not exactly the precision Luthiery solution, but it works well with the Os I've worked on. If the neck joint is properly fit, there's no need for an enormous amount of clamping force to keep the fretboard extension in place. If the extension is not designed to be floating I'd definitely recommend against leaving the fretboard floating. If the floating is too bad, I think a shim under the fretboard extension would be advisable. Oh and if you're going to take the top off anyway, you might try flatening it out after removal. My 1868 top looked like this when I first got it
After stripping the paint and removing the top it looked like this...
I was able to salvage, repurpose the top and restore my 1868. Repairing the warped top took a bit of time wetting and drying over several months, but the results were well worth it to me. Having said that, I would probably choose to re-top the 1768 if it were mine. Might be good to get the project under way and share as you go. The BFLG folks are highly experienced and always provide valuable insight. As far as I can tell there is nothing on your 1768 that isn't repairable! Good luck! Edited by arumako 2025-07-06 11:59 PM | ||
| davegardner0 |
Joined: October 2016 Posts: 23 Location: NJ, USA | Dan and amurako, thank you both so much for the wealth of info! This is wildly helpful. As I move forward with the project I'll definitely post updates. And I'm sure I'll have more questions as I go along... Dan, do you have a thread for the build of that elite that you showed gluing the fretboard extension on? I hadn't seen that thread if it exists. Regarding the thickness of the top, I'm pretty good with a hand plane and scrapers, so I was thinking of thicknessing the top that way. Therefore I do think I can accomplish the taper as easily as a constant thickness top. I think I just need to buy a deep throated thickness caliper to check the top thickness as I go. The taper on the top is really interesting...any idea who ovation does it that way? And I guess same question on the non-radiused top, seems like an odd choice? Oh and when you say extra light strings, what gauge do you mean? 11's? Do either of you have thoughts on the alternate bridge and bridge bolts I'm thinking of using? How about pulling the preamp and using a soundboard pickup? I can't think of a reason it wouldn't work, but I wouldn't be able to confirm until I'm in pretty deep. | ||
| DanSavage |
Joined: June 2012 Posts: 2346 Location: Pueblo West, CO | davegardner0 - 2025-07-07 5:45 PM Dan, do you have a thread for the build of that elite that you showed gluing the fretboard extension on? I hadn't seen that thread if it exists. On the Frankenvation, (1778T) I never glued the fretboard extension to the top. I did that because the 1537 neck I used was made for a deep bowl and I planned to eventually buy a neck for a mid-depth bowl and swap it out. It doesn't really make a difference in tone. Early Adamas guitars didn't have the extension glued, either. The taper on the top is really interesting...any idea who ovation does it that way? And I guess same question on the non-radiused top, seems like an odd choice? According to early documentation tapering the top was done for two reasons. 1) To allow a greater 'excursion' in the belly which enhances tone and timbre. 2) To make the sound board above the sound hole stiffer and more resistant sinking. WRT the lack of radius, it was probably done to speed up production. Oh and when you say extra light strings, what gauge do you mean? 11's? I use Elixir 80/20 Nanoweb Extra Lights. (.010"-.047") Do either of you have thoughts on the alternate bridge and bridge bolts I'm thinking of using? How about pulling the preamp and using a soundboard pickup? I can't think of a reason it wouldn't work, but I wouldn't be able to confirm until I'm in pretty deep. I've only ever used the Ovation bridges/pick-ups/pre-amps, so I wouldn't be able to offer an opinion. For the bridges that are bolted, Ovation used aluminum screws, washers and nuts. They also used glue to secure the nut so it didn't rattle loose. If you're going to use a pinned bridge you'll need to install a bridge plate on the underside of the top as the spruce alone won't prevent the ball ends from pulling through. Most bridge plates use maple, but my Alvarez uses rosewood. I've used rosewood for a bridge plate on one guitar and it worked well. Edited by DanSavage 2025-07-08 10:27 AM | ||
| arumako |
Joined: October 2012 Posts: 1093 Location: Yokohama, Japan | davegardner0 - 2025-07-07 9:45 AM Do either of you have thoughts on the alternate bridge and bridge bolts I'm thinking of using? How about pulling the preamp and using a soundboard pickup? I can't think of a reason it wouldn't work, but I wouldn't be able to confirm until I'm in pretty deep. Hi davegardner0, You're getting great advice from Dan. He's helped me with pretty much all of my BFLG projects. I think there would be overwhelming consensus that he's the "Go to" guy at the BFLG and beyond. As far as using the "All Parts pinless bridge" that will definitely work. Whether you bolt the bridge down or not might depend on the strength of the adhesive you use. I've replaced bridges on some Celebrity models and used the space age epoxy Hysol 9462. As long as the bridge is properly clamped and you're glueing wood to wood (as opposed to wood to poly finish), there is no need for bolts (of course, the bolts are there just to protect players and others in the event the bridge pops off so you might want to add bolts just in case anyway). If you're thinking the bridge might need to come off some time in the future, I'd go with Hysol 0151 with bolts. The adhesives you choose will definitely guide your project in different directions. I also might be able to provide some insight with the bridge and "soundboard pickup" inquiry. I'm assuming you mean round transducer style pickups, right? I've worked with K&K and other brands. They'll definitely work on your 1768; however the configuration will very much depend on how you decide to brace your 1768. If you're going to go with factory specs, I think you'll be using the Quintad bracing; but that will raise some challenges if you decide to go with traditional 3 transducer PUPs (two transducers aren't enough to provide level dynamics across six strings) because the center brace goes right through the middle of the bridge where one of the transducers need to be positioned. I think the pic below might help...
That middle transducer brace blockage will be an issue with A-braced and K-5 braced O's as well. There's several alternatives IMHO. One is to use X-bracing. The other is to keep the Quintad bracing and test for the transducers sweet spot where dynamic balance is achieved. I've put transducer PUPs in some classical guitars with intricate bracing configurations. If you use some masking tape on the guitar top and double-stick (tape) the transducers onto the masking tape, you can test for the sweet spot on the guitar. The masking tape really helped to protect the delicate French polish finish while I stuck and peeled off the transducers to find the perfect position.
This particular classical guitar used a Fleta style bracing pattern modified for a cutaway. There was no way to get the center transducer positioned perfectly under the bridge. Once the ideal position was determined (as shown above) the masking tape was marked at the center and the transducers were glued (very carefully using CA gel) under the sound board using two hands (lots of dry runs!) I was afraid that the proximity of the transducers would detriment the output volume, but my fears were unfounded. Hope this helps! Cheers!
| davegardner0 |
Joined: October 2016 Posts: 23 Location: NJ, USA | arumako - 2025-07-09 10:19 AM I've replaced bridges on some Celebrity models and used the space age epoxy Hysol 9462. As long as the bridge is properly clamped and you're glueing wood to wood (as opposed to wood to poly finish), there is no need for bolts (of course, the bolts are there just to protect players and others in the event the bridge pops off so you might want to add bolts just in case anyway). If you're thinking the bridge might need to come off some time in the future, I'd go with Hysol 0151 with bolts. The adhesives you choose will definitely guide your project in different directions. Oh this is very interesting, I had just assumed I'd use titebond since it bonds "stronger than the wood itself". I'm surprised to see you using a "space age" epoxy instead. What's the reason for it? Assuming I have a really tight glue joint, would titebond be sufficient? Or maybe it's hard to clamp the bridge well enough to get a thin joint where wood glue can work? arumako - 2025-07-09 10:19 AM I'm assuming you mean round transducer style pickups, right? I've worked with K&K and other brands. They'll definitely work on your 1768; however the configuration will very much depend on how you decide to brace your 1768. Yep, those are the pickups I was thinking of! I would like to get more of the sound of the top, rather than just the saddle. I think using the 4-transducer classical guitar pickup sounds like the way to go. But, now you've got me thinking about bracing patterns. I just assumed I'd use the factory Quintad bracing. What are the pros/cons of it versus other bracing types like traditional X bracing? Either way, I like your idea of using tape to figure out the optimum transducer placement before gluing! | ||
| arumako |
Joined: October 2012 Posts: 1093 Location: Yokohama, Japan | davegardner0 - 2025-07-25 7:10 AM Oh this is very interesting, I had just assumed I'd use titebond since it bonds "stronger than the wood itself". I'm surprised to see you using a "space age" epoxy instead. What's the reason for it? Assuming I have a really tight glue joint, would titebond be sufficient? Or maybe it's hard to clamp the bridge well enough to get a thin joint where wood glue can work? Hi davegardner0! Yes, Titebond will work just fine, BUT as Dan Savage of BFLG fame has said, Titebond has a tendency to creep meaning the parts being glued can move as the glue cures. I've experienced this problem myself, but still use Titebond whenever I can secure parts with a dowel or other countermeasure to ensure the parts maintain position while curing. When securing your bridge, you'll definitely want to use bridge pins if you're going to use Titebond. I use the "space age" epoxy (Hysol 9462) in areas like a bridge on my own personal guitars when I am sure that... if the bridge ever pops off again, I'm going to completely re-top the guitar. For guitars that belong to others, I've settled in to using either Titebond (the regular wood glue) or Hysol 0151 (bonds as strong as 9462 but melts at a lower temperature to allow for removal). davegardner0 - 2025-07-25 7:10 AM Yep, those are the pickups I was thinking of! I would like to get more of the sound of the top, rather than just the saddle. I think using the 4-transducer classical guitar pickup sounds like the way to go. But, now you've got me thinking about bracing patterns. I just assumed I'd use the factory Quintad bracing. What are the pros/cons of it versus other bracing types like traditional X bracing? Either way, I like your idea of using tape to figure out the optimum transducer placement before gluing! The 4-transducer pickup sounds like a good idea. It will give you more flexibility when positioning your transducers. With regard to bracing patterns, my comments were made in consideration of transducer positioning only. The braces will definitely interfere with transducer positioning depending on the bracing you choose for this project. Personally I love Ovation's Quintad and A braces. IMHO they not only provide great resonance power to the voice of the tops, but they also provide the most dynamic range stability (almost like a natural compressor) that gives each note consistent articulation; however, you won't be able to position the transducers directly under the bridge as recommended by transducer PUP manufacturers (meaning you'll need to resort to the tape method) if you go with Quintad bracing. I have nothing against X-bracing; and if you want to position the transducers directly under the bridge as recommended by the PUP manufacturers, X-bracing will definitely give you the space you need to do so. Oh yeah, In my last post I mentioned that "two transducers aren't enough to provide level dynamics across six strings," and in principle I think that's right, but I should mention that I have used the two transducer K&K minis on a Taylor Baby and a vintage Japanese arch top successfully. The two transducers couldn't be placed directly under the bridge and had to be positioned using the masking tape method. Hope this helps and good luck with your 1768 Rehab! | ||
| Jonmark Stone |
Joined: May 2008 Posts: 1565 Location: Indiana | davegardner0 - 2025-07-25 5:10 PM I'm surprised to see you using a "space age" epoxy instead. What's the reason for it? Epoxy is mother's milk in the Ovation world. Edited by Jonmark Stone 2025-08-15 4:44 PM | ||
| davegardner0 |
Joined: October 2016 Posts: 23 Location: NJ, USA | Hi All! After some time, I'm finally able to get working on this project. Today I spent some time taking some measurements on the guitar, and then taking off the binding and top. @DanSavage, your suggested of an exacto chisel blade worked great.
| seesquare |
Joined: November 2002 Posts: 3664 Location: Pacific Northwest Inland Empire | This is exciting to see a new project in-the-works. Best of luck with sourcing parts. I'm sure there will be plenty of opinions & conjecture in the progression of this repair and reconstruction. I admire and applaud your efforts and sense of adventure. Carry on! BTW, another venue for advice and instruction would be the Ren-Ovation site on Facebook. Lots of expertise there, too. | ||
| DanSavage |
Joined: June 2012 Posts: 2346 Location: Pueblo West, CO | Hi Dave, davegardner0 - 2026-01-19 3:10 PM Ok so now that I have the guitar apart, some questions come to mind that I thought you all might be able to help me with:
Edited by DanSavage 2026-01-20 4:44 PM | ||
| Patch |
Joined: May 2006 Posts: 4236 Location: Steeler Nation, Hudson Valley Contingent | This looks like a fun watch! | ||
| davegardner0 |
Joined: October 2016 Posts: 23 Location: NJ, USA | Dan, thanks so much for the helpful info! Mind if I ask a few follow-ups? With those mixing nozzles, are you able to use part of a tube of epoxy, then (with a new nozzle presumably) use the rest later? And that epoxy you recommended, with a 1 hour working time, seems perfect for this type of work. For binding routing, I have these two stew-mac jigs: Precision Router Base (with edge guide) I was thinking since the top isn't radiused, the first one would work well. I do also have a full-sized router that I can buy the bearing bits for. Last question (for now), how much clean-up do you typically do on the bowl where the top will be glued on? Are we talking removing every last speck of old epoxy and wood? And if so, what's your preferred method? | ||
| davegardner0 |
Joined: October 2016 Posts: 23 Location: NJ, USA | P.s. this is potentially a dumb question, but is there a way on this forum to subscribe to a thread? I'm probably looking right at the button and not seeing it. It would be nice to know when you guys reply. | ||
| seesquare |
Joined: November 2002 Posts: 3664 Location: Pacific Northwest Inland Empire | RE: thread subscription. Y'got me on that one, too. I just scan the front page for updated entries. It would be nice to receive notifications, though. And, Dan Savage, you may be The Oracle. Soup-to-nuts, you're the source. Thanks for the guidance and expertise! OK, Dave, post a lot of photos. "A picture is worth a thousand words", right? | ||
| davegardner0 |
Joined: October 2016 Posts: 23 Location: NJ, USA | seesquare - 2026-01-22 7:46 AM OK, Dave, post a lot of photos. "A picture is worth a thousand words", right? You know, if I didn't have to keep going to work every day, I'd have way more time for progress and updates! That's my excuse for sure. lol But yes, lots of photos coming as I progress through the project! First thing I'm going to tackle is jointing and thicknessing the top, as well as cleaning up the bowl. Edited by davegardner0 2026-01-22 4:02 PM | ||
| DanSavage |
Joined: June 2012 Posts: 2346 Location: Pueblo West, CO | davegardner0 - 2026-01-21 4:55 PM Dan, thanks so much for the helpful info! Mind if I ask a few follow-ups? I make my braces 1/8" thick with no taper. I use Old Brown Glue to attach the braces to the top, though you could use the Hysol 0151, as well. You'll want to use a torrefied top with the torrefied braces. Mixing torrefied with non-torrefied won't sound as good as an all-torrefied top. Also, consider bolting the bridge to the top as a belt-and-suspenders measure. I had one bridge pop off the Black Parlor that has a torrefied Englemann spruce top. After I re-glued the bridge, I added a pair of aluminum screws, washers and nuts so it doesn't happen again. The torrefied Englemann spruce has the lowest peel strength of all the torrefied tone woods. I checked the gun in the link. Their 1:2 pushrod doesn't match the Hysol 1:2 pushrod. They didn't say whether they include the 1:1 pushrod or if you're just supposed to use their 1:2 with the 1:1 cartridges. The diameter for their large side of the 1:2 pushrod would probably work on the Hysol 1:1 cartridge. My 1:1 diameters on both sides are 18.8mm. The small side of my 1:2 pushrod is 15.5mm, but the large side is 22mm. Their 1:2 small side is 15.5mm and the large side is 18.8mm. I'm not sure their 1:2 pushrod would work with the Hysol 1:2 cartridges because of the smaller diameter of the large side. At that price you could buy one to test, then if need be, buy the Hysol gun. FWIW, Hysol 0151 is a 1:2 mix. With those mixing nozzles, are you able to use part of a tube of epoxy, then (with a new nozzle presumably) use the rest later? And that epoxy you recommended, with a 1 hour working time, seems perfect for this type of work. Yes. The nozzles are removable and you just put the tube cap back into place when you're done and throw away the nozzle. Just make sure you don't mix up which way the cap goes back on. You don't want to put the epoxy into the hardener tube and vice versa. For binding routing, I have these two stew-mac jigs: Precision Router Base (with edge guide) I've used the second one. On guitars with bolt-on necks, I prefer using a Bosch Colt Router with the bearing bits. On guitars with a glued neck, I use the Bosch router for the majority of the body, then switch to the Stewmac Binding Router Guide because it's smaller diameter allows me to route closer to the neck. Lastly, I use an Xacto #11 blade to whittle the remaining grooves as far as I can under the fretboard extension. I was thinking since the top isn't radiused, the first one would work well. I do also have a full-sized router that I can buy the bearing bits for. Last question (for now), how much clean-up do you typically do on the bowl where the top will be glued on? Are we talking removing every last speck of old epoxy and wood? And if so, what's your preferred method? I use the Xacto chisel to remove excess glue and wood remnents. It doesn't need to be perfectly clean, just mostly pretty flat so the top sits evenly. Edited by DanSavage 2026-01-22 4:14 PM | ||
| DanSavage |
Joined: June 2012 Posts: 2346 Location: Pueblo West, CO | davegardner0 - 2026-01-22 2:00 PM But yes, lots of photos coming as I progress through the project! First thing I'm going to tackle is jointing and thicknessing the top, as well as cleaning up the bowl. Ovation used to taper the tops from with the thickest part near the neck and tapering thinner near the lower strap button. From what I understand, they no longer do this. According to the Historical Documents on Jerome's Ovation Tribute site, the thickest a sound board should be is .125" and it should be is no less than .105". I use these measurements as the guide for the taper. | ||
| davegardner0 |
Joined: October 2016 Posts: 23 Location: NJ, USA | I made some progress today. First, some more measuring. I cut a few slots in the purfling on the old top to measure the thickness in a few spots.
Interestingly, I do not see much of a taper, if any: Where I do see a relatively extreme taper is near the neck joint, where the top seems to get VERY thin, 0.0845" w/finish. I sanded off the black paint inside some of the soundholes to be able to differentiate the ply vs top vs finish vs epaulettes, and so this photo I think really shows the tapering.
The ply/reinforcement around the soundholes is peeling, so I was able to easily measure its thickness too. It looks like it tapers to nothing around the waist of the guitar, and is very thin around the joint to the bowl all around, too. But right near the soundholes it's about 0.030" thick.
I did also notice that on the treble side of the lower bout, the lining has separated from the bowl a bit. I think this isn't surprising, as the old top had shrunken so much that it must have really been pulling on these linings. Can I use the same Hysol 0151 epoxy to glue this back on?
I'm also working on a full sized drawing of the top. I had previously traced the guitar. Today I added the locations of the soundholes and braces, as well as the various thickness measurements I've taken so far.
Next I (finally!) started working on the new top. I jointed the edges using a hand plane (and eventually switched to my shooting board instead of freehand).
I used the clamping method from Cumpiano's book: (practice without glue)
Before gluing, I did notice a little bit of cupping on one of the plates (the right side in the photo). Is this any cause for concern? I only ask because there are no braces that run perpendicular to the strings. I have had this wood sitting on stickers in my basement for about a year, btw.
A few other random thoughts/questions as I continue to think through this project: What's a good method for locating and intonating the bridge? Dan, I was reading through your threads on Harry Chapin's guitar as well as the elite you retopped, and was surprised to see that you locate the bridge before gluing the top onto the bowl. How does that work? My initial thought was to glue the top on, mount the neck, and then make lots of measurements to figure out the bridge position. But locating it before gluing would be easy in the sense that I can add in the aluminum bolts, etc. more easily. Do we know the typical thickness of the veneer used on the newer elites where it only covers the soundholes and doesn't go under the braces? Like for instance in this image. I definitely want to do the reinforcement this way rather than the full width of the guitar. I'm thinking about what wood to use, and how to make this thin piece. As far as wood, I may have some torrefied spruce scraps from this top and/or the brace stock. I also have a bunch of torrefied maple from electric guitar necks that I've built. As far as the fabrication, my thought is to resaw it as thin as I can manage (I have a small cheap bandsaw), then glue it on, and then handplane it down to the final thickness. It could get a little more tricky if I have to glue multiple pieces together to get enough width, though. Another option is to try to handplane it very thin before gluing on, maybe using double sided tape to hold it as I use the plane. Either way, it may be tricky but I think I can pull it off. Last random question, what kind of wood is recommended for gluing the fretboard extension onto the top, once I get to that step? And would you recommend I mask that area off so it doesn't get finish on it, like the area where the bridge will be glued? | ||
| DanSavage |
Joined: June 2012 Posts: 2346 Location: Pueblo West, CO | davegardner0 - 2026-01-24 3:08 PM Next I (finally!) started working on the new top. I jointed the edges using a hand plane (and eventually switched to my shooting board instead of freehand). I realize it's a little late now, but did you candle the joint by holding it up to a bright light source, such as the sun, before gluing it? Candling will show any gaps to ensure the entire joint is tight. I did also notice that on the treble side of the lower bout, the lining has separated from the bowl a bit. I think this isn't surprising, as the old top had shrunken so much that it must have really been pulling on these linings. Can I use the same Hysol 0151 epoxy to glue this back on? You can use 0151 to re-glue the lining to the bowl. Before gluing, I did notice a little bit of cupping on one of the plates (the right side in the photo). Is this any cause for concern? I only ask because there are no braces that run perpendicular to the strings. I have had this wood sitting on stickers in my basement for about a year, btw. No worries. A few other random thoughts/questions as I continue to think through this project: What's a good method for locating and intonating the bridge? Dan, I was reading through your threads on Harry Chapin's guitar as well as the elite you retopped, and was surprised to see that you locate the bridge before gluing the top onto the bowl. How does that work? My initial thought was to glue the top on, mount the neck, and then make lots of measurements to figure out the bridge position. But locating it before gluing would be easy in the sense that I can add in the aluminum bolts, etc. more easily. 1) Put a piece of masking tape on the bottom of the bowl, along the edge of the old binding groove. 2) Bolt the neck on. 3) Lay a straight-edge on one side of the neck and mark the location on the masking tape. Do the same for the other side of the neck. This is is the neck location at the bottom of the bowl. 4) Measure and mark the center. This is where the top joint will sit. 5) Notch the top so it fits tightly to the neck. Make sure the bottom joint aligns with the center mark on the tape. 6) Mark the location of the notch onto the bowl. 7) Measure and mark exactly 25" from the nut. This is the location of the front of the bridge. 8) Measure and mark the location of the alignment pin holes. 9) Measure and mark the location of the pick-up hole. 10) Remove the top. Drill the holes. I use a Forstner bit to minimize tear-out. 11) At this point, you can remove the neck or not. For bolt-on necks I find it's easier to glue the top with the neck off the body. It's also easier to route the grooves for the purfling/binding. Do we know the typical thickness of the veneer used on the newer elites where it only covers the soundholes and doesn't go under the braces? Like for instance in this image. I definitely want to do the reinforcement this way rather than the full width of the guitar. I'm thinking about what wood to use, and how to make this thin piece. Interior doubler is 1/8" thick. Since you're going to drill holes through it, I would recommend cutting these from the torrefied brace stock blank. You'll want to cut these so they are flat-sawn, not quarter-sawn. As far as wood, I may have some torrefied spruce scraps from this top and/or the brace stock. I also have a bunch of torrefied maple from electric guitar necks that I've built. Either one would work fine as long as they're flat-sawn. The sound holes are fairly close to each other. Flat-sawn will make these holes stronger and resist tear-out when you drill the holes. Quarter-sawn will not provide the necessary strength. As far as the fabrication, my thought is to resaw it as thin as I can manage (I have a small cheap bandsaw), then glue it on, and then handplane it down to the final thickness. It could get a little more tricky if I have to glue multiple pieces together to get enough width, though. Another option is to try to handplane it very thin before gluing on, maybe using double sided tape to hold it as I use the plane. Either way, it may be tricky but I think I can pull it off. If you were going to make these full-width, then you'd want them pretty thin. (~1/64" to 1/32") If you're just going to reinforce the sound holes, I'd just make them 1/8" thick. If I were to re-top another Elite, I'd do the same as the photo you linked to. Just make sure the grain of the doubler is perpendicular to the grain of the top so it forms a rudimentary plywood. Last random question, what kind of wood is recommended for gluing the fretboard extension onto the top, once I get to that step? And would you recommend I mask that area off so it doesn't get finish on it, like the area where the bridge will be glued? You can glue the fretboard extension or not. I did not glue the extension on my Frankenvation Elite and it plays fine. In fact, the early Adamas extensions were not glued, but floated above the top. When I glue extensions, I use 5-minute epoxy. If you're going to use hardware store glue, test it first on scrap to make sure it fully cures. I have come across hardware store epoxy that didn't fully cure which required me to clean out the uncured epoxy, then re-do it. Edited by DanSavage 2026-01-25 12:29 PM | ||
| davegardner0 |
Joined: October 2016 Posts: 23 Location: NJ, USA | DanSavage - 2026-01-25 1:20 PM I realize it's a little late now, but did you candle the joint by holding it up to a bright light source, such as the sun, before gluing it? Candling will show any gaps to ensure the entire joint is tight. Yep! The joint passed the candling test before gluing. Thanks for checking, though. I'm really happy with how it came out. I had a chance to smooth both sides with a plane and scraper, and the glue line is actually a bit difficult to find! Also, is it just me or does the torrefied spruce not really behave super well when scraped? I kept getting little fibers of the wood pulling up. Not sure it super matters, just an observation. Then I traced my template onto the top, figured out where I'd like the body to be exactly, and roughly cut it out on the bandsaw. We have something guitar-shaped!! Next will be thicknessing it. Today I spent some time on the bracing. I didn't get a photo, but I split my bracing stock with a chisel. (that was scary!). Next I planed the split faces flat, then resawed to just over 1/8" on the bandsaw. These braces are going to be super tall and skinny by "regular" acoustic guitar standards, aren't they? I glued up a jig to hold very thin workpieces for planing, so next will be bringing the braces down to their exact width (while cleaning up the bandsaw marks), and jointing one edge for gluing to the top. I also pieced together some pieces of the bracing stock for the soundhole reinforcements, and glued them. Not 100% sure if this will work, I had to use thin pieces to get them to be flatsawn. But I think it's worth a try. One side is pretty much planed flat, and hopefully I can plane the other side flat without breaking anything after the glue dries. DanSavage - 2026-01-25 1:20 PM You can glue the fretboard extension or not. I did not glue the extension on my Frankenvation Elite and it plays fine. In fact, the early Adamas extensions were not glued, but floated above the top. When I glue extensions, I use 5-minute epoxy. If you're going to use hardware store glue, test it first on scrap to make sure it fully cures. I have come across hardware store epoxy that didn't fully cure which required me to clean out the uncured epoxy, then re-do it. I'm curious why you use 5 minute epoxy for this rather than the Hysol for the fretboard extension? Perhaps to make it a joint you can take apart more easily, if needed? And on a related note, I went to buy the Hysol 0151 50g cartridge that you recommended, and it seems to be out of stock everywhere right now! Must be a bit of a funny coincidence. Not sure exactly when I'll be ready to glue the bowl on, but I'll have to watch for it to come back in stock. I have the dispenser gun and nozzles on order now. Edited by davegardner0 2026-02-01 3:41 PM | ||
| davegardner0 |
Joined: October 2016 Posts: 23 Location: NJ, USA | p.s. Dan, when you don't end up gluing the fretboard extension, do you notice a difference in tone of the notes up there? My hunch is that the sustain would be deadened, but I could be wrong. | ||
| DanSavage |
Joined: June 2012 Posts: 2346 Location: Pueblo West, CO | davegardner0 - 2026-02-01 1:37 PM Also, is it just me or does the torrefied spruce not really behave super well when scraped? I kept getting little fibers of the wood pulling up. Not sure it super matters, just an observation. Could be. I usually don't use a scraper on the surface. Once it's been through the thickness sanding process, I proceed with gluing the braces. Today I spent some time on the bracing. I didn't get a photo, but I split my bracing stock with a chisel. (that was scary!). Next I planed the split faces flat, then resawed to just over 1/8" on the bandsaw. I don't have a band saw, so I cut my braces on a table saw. Yes, they are. I made myself a tool/jig to keep the braces from flopping over when being glued.
As I wrote, I use a table saw with a veneering blade to cut the braces to their net thickness. After that, I use a jig saw to cut the outlines. One of the reasons I chose 0151 is because of the low glass transition temperature. (Tg) It's about the same as hide glue. (~170° F) I use 5-minute epoxy because it cures faster. Grainger says their stock should be replenished around the end of the month. p.s. Dan, when you don't end up gluing the fretboard extension, do you notice a difference in tone of the notes up there? My hunch is that the sustain would be deadened, but I could be wrong. I haven't noticed a difference in tone. I didn't glue the extension on my Frankenvation because I plan to someday replace the 1537 neck with an Elite neck meant for a mid-depth bowl. | ||
