Truss Rod adjustment
Posted 2005-06-13 4:30 PM (#147799)
Subject: Truss Rod adjustment
I'm am sure this has been covered but I am asking anyway for a quick hand.
Adamas 1881 that has about 1/2 to 3/4 inch of spacing between strings and 14 fret. Which way do I turn the truss rod with the guitar facing down (bowl up) to start making the proper adjustment.
THanks
Mitchrx
Posted 2005-06-13 4:42 PM (#147800 - in reply to #147799)
Subject: Re: Truss Rod adjustment
Stephen:
You cannot fix 1/2 - 3/4" action with a truss rod adjustment. Sounds like you need to send the guitar to the factory for a neck re-set.
Posted 2005-06-13 4:44 PM (#147801 - in reply to #147799)
Any way.
Then go the other way if it was wrong!
Tightening, CW facing the nut, will tension the neck up, or toward the top.
Loosening, CCW, will allow the neck to relax back.
Very small increments produce large movements (shut up Cruster!).
Use a scale that measures in 1/64" and follow the Owner's Manual.
Posted 2005-06-13 5:06 PM (#147802 - in reply to #147799)
For future reference Stephen
Loosening by turning counter-clockwise---allows a backward bow to straighten by adding relief.
Tightening -clockwise-- removes relief..straightens a upward bow of the neck.
I agree with Jailhouse you'll never get that much out. Needs reset.
...but if you were making just a fine tune... you would want to remove relief by going clockwise.
Posted 2005-06-13 8:06 PM (#147803 - in reply to #147799)
Lefty loosee Righty tighty.
Hold down strings at the 1st and 12th or 13th fret check claearance at 5th fret. Too much clearance, tighten too little loosen.
Posted 2005-06-13 9:14 PM (#147804 - in reply to #147799)
Do search on truss rod adjustments grasshopper. You'll find the answer therein.
(But on a side note I can't believe your measuring it right.) The operative place to measure is at the 12th fret, from the top of the fretwire to the bottom of the low E string. The Ovation website has some tips on the factory settings. I did a review of the MEWP where I described how to adjust the action. I'd start there. Good luck
Posted 2005-06-13 11:30 PM (#147805 - in reply to #147799)
OK...finally got back home and measured (the first numbers were just a guess). It's about 1/4 inch at the 12fret and just a tad more at the 14th.
The guitar even tho 10 years old is close to mint. Could the neck have gotten out of wack in shipping? I can't believe that someone would have a guitar of this caliber and never fix the action/TR adjustment to make it playable.
The shipping box had a few dings and holes in it. If this could have happened in shipping I can file a claim to have the neck reset.
What's a neck reset cost and can it be done locally by a good luthier or does it NEED to be sent back to the mothership
TRboy
Posted 2005-06-14 12:56 AM (#147806 - in reply to #147799)
February 2003
Stephen,
Send it back to the Mothership.... Noboby can do it better!! I'd guessamate a factory neck reset starting at $150 and going up depending on model and what else needs doing.
I had the factory reset my Legend 12 string (some claim the shallow bowls give neck reset problems due to a small heel surface) dress and level my frets,install an external battery holder and install pearloid tuner buttons,set everything back to factory specs for only $235 including return freight!!.....that was 2 yrs ago and it still plays like budda!...I wouldn't trust my O's repairs to anyone but da Mothership!
It's going to take more than a few dings and holes in the shipping box to cause a neck reset (Ovations are tuffer than that!!) I think your chances of getting the shipping carrier to pay for a neck reset are nil to nothing at all....but stranger things have happened :cool:
Posted 2005-06-14 8:20 AM (#147807 - in reply to #147799)
Before sending it to the mothership, it might be better to bring it to your local guy, and have him check the nut and saddle heights. Did you try changing the saddle height?
Mitchrx
Posted 2005-06-14 9:07 AM (#147808 - in reply to #147799)
Stephen:
You need to accurately determine the acion. Get a good quality steel ruler that has 1/32" increments. Measure the distance between the top of the fretwire and the botton of the low E string at the 12th fret. Factory spec is about 3/32". If the action is higher than that, check under the saddle to see how many shims are there. You can remove some or all of the shims and lower the action.
If the action is really 1/4" (8/32") you're going to need a neck re-set.
Truss rod adjustments are NOT for the purpose of making the action lower.
Posted 2005-06-14 8:19 PM (#147809 - in reply to #147799)
Yep, it is reading 7/32 at the 12th and 8/32 at the 14th.
At the price I paid for it, I can afford to have the neck reset if need be.
I emailed the guy and asked him if it was an issue before he shipped it to me. His reply was...that he never played past the 4th fret so he never noticed. (Then proceded to tell me to adjust the truss rod or remove the shims)
Maybe I am being scammed here but the guitar is in near mint condition except for the neck issue.
A return trip to the factory with "return as new" instructions would run under $250???
TRboy
Posted 2005-06-14 10:29 PM (#147810 - in reply to #147799)
February 2003
Call or email Kim Keller at the factory....
....You'll probably have to send it in for a definite quote!
The guy I bought my Legend 12 from (I purchased it after it didn't sell on ebay) was very up-front about the guitar needing a neck reset....he said the action was high but in the "money frets" it was "tolerable" but anything past the 3rd fret you needed vise-grips...he adjusted the price accordingly!(even reduced the shipping,super nice guy) ;) with the price for the guitar and the factory visit...I'm still under what 1866 Legends are going for on fleabay!
If you can afford to add a neck reset to your purchase price and still feel you have a bargan, I'd say send it back to da factory.....when you get it back you'll probaly think they sent you a NEW guitar!! Those boys at the factory can "git-r-done!" :D
Posted 2005-06-15 1:00 AM (#147811 - in reply to #147799)
What would cause a guitar to require a neck reset?
What exactly does the factory do to "reset" a neck?
Thanks
Mitchrx
Posted 2005-06-15 1:31 PM (#147812 - in reply to #147799)
Stephen:
Good questions. Given the way O's are constructed, and Adamas in particular, it would seem that the bodies are not as prone to bending as with an all wood guitar. However, something happened to the body or top of your guitar and the neck no longer properly lines up with the top. The factory will remove the neck and make the necessary adjustments to properly re-align it with the top/body of the guitar. Once that is done the guitar will play like new with the great low action that O's are famous for.
Mitchrx
Posted 2005-06-15 1:35 PM (#147813 - in reply to #147799)
Here's a good article on neck re-sets:
http://www.acousticguitar.com/Gear/advice/neckresets.shtml
Posted 2005-06-15 2:14 PM (#147814 - in reply to #147799)
Bro' before making a federal case, did you check the shims under the saddle?
Mitchrx
Posted 2005-06-15 3:36 PM (#147815 - in reply to #147799)
Removing one shim lowers the action by about 1/64". Usually there are at most 3 shims under the saddle. There's nothing wrong with checking out the shims, but 7/32" action will need a neck re-set.
Posted 2005-06-15 4:22 PM (#147816 - in reply to #147799)
It might be more than 1/64 th. The factory sends out (sometimes) shims of different thicknesses and there can be up to 4 shims.
Posted 2005-06-15 9:58 PM (#147817 - in reply to #147799)
Good thought an4340 but that was the first thing I checked. One shim in and I took that out still leaving the measurements close to what I said before. Plays great as a laptop slide guitar! :D
My local luthier builds guitars that sell in the $5-10K range so I may carry it over to him to get his thoughts. If he says he can fix it, I know it will be done right but he will also be quick to tell me to send it to the mothership if they can do a better job. He charges about $150 and does a set up and fret polishing at the same time.
Mitchrx....great link to the site! Thanks!
Posted 2005-06-16 12:56 PM (#147818 - in reply to #147799)
Well, it looks like you need a reset. Good luck.
Posted 2005-06-16 2:44 PM (#147819 - in reply to #147799)
Skinny Baby,
I have been watching this post closely. I have read your previous posts on guitar maintanence issues and have always learned something.
Stephen,
See the first page of this thread
