Fingerboard oil
LeonardDB
Posted 2008-02-29 9:24 AM (#52091)
Subject: Fingerboard oil
February 2008
My strings are removed and there are some areas on the fingerboard where the coloring is a little faded. What do you guys use to rub the fingerboard?
John B
Posted 2008-02-29 9:39 AM (#52092 - in reply to #52091)
Subject: Re: Fingerboard oil
January 2004
Dunlop makes a good fretboard cleaner / conditioner. After using that, I like to use a drop of lemon oil.
Posted 2008-02-29 9:55 AM (#52093 - in reply to #52091)
When my fretboard gets to that point, I use 0000 steel wool with a few drops of lemon oil. This cleans both the wood and frets. I thoroughly wipe away all traces of residue and then apply lemon oil. I let it sit for a couple of hours. I do this twice.Then I wipe off the excess and buff with a micro-cloth.
Mitchrx
Posted 2008-02-29 10:08 AM (#52094 - in reply to #52091)
I've been using heavy mineral oil as suggested by some of the members here in the past. It's cheap and available at most pharmacies. Make sure you get the heavy stuff that's labeled for internal use. I use 0000 steel wool with a few drops of the oil to remove gunk and polish up the frets and then a cotton rag to wipe up any residue. I find that it makes the fretboard look like new and works well with any kind of fretboard wood.
G8r
Posted 2008-02-29 10:12 AM (#52095 - in reply to #52091)
This isn't meant as a slap (newbies may not know about this functionality) - do a search on this board. This has been discussed often, as recently as the middle of last month.
The consensus (favorite to least): Dunlop65, Fret Doctor, mineral oil, tung oil, lemon oil. The caveat with lemon oil is that most available are not pure and contain solvents that could remove some of the natural oils of your fret wood. Also, the acidity in lemon oil is thought to be harmful to the wood by some.
LeonardDB
Posted 2008-02-29 11:59 AM (#52096 - in reply to #52091)
February 2008
My take would be to scrub the fingerboard using an Ocello no-scratch nylon scrub pad dipped in mineral oil. I would not use steel wool since the residue could cause rust around the frets. Not only that but I just would not want any steel wool residue anywhere on my instruments.
bvince
Posted 2008-02-29 12:15 PM (#52097 - in reply to #52091)
September 2005
All good suggestions and comments. I first scrub the fretboard down with pledge orange oil cleaner, then follow up with a combination of pure lemon oil, Jojoba oil, and olive oil. I call it the "spa treatment"
Posted 2008-02-29 12:57 PM (#52098 - in reply to #52091)
I use Guitar Honey by Gerlitz.
I believe it's mineral oil based.
Posted 2008-02-29 1:59 PM (#52099 - in reply to #52091)
Leonard, let us know how it comes out. I don't think you have to worry about the rust from the steel wool, though. I suspect it's been used on fretboards since before I was born and that's quite awhile ago. It often takes something pretty serious to get the grime from your fingers off the fretboard. I don't add oil until after I've blown off the steel wool particles, then add the oil and polish it really good.
scott lamperd
Posted 2008-02-29 2:50 PM (#52100 - in reply to #52091)
I use magic erasers in my repair business. They clean without scratching. A little vegtable oil on a soft rag does wonders.
Scott
Fridave
Posted 2008-02-29 4:50 PM (#52101 - in reply to #52091)
February 2008
I've used the "Petros" fingerboard oil. Did a great job.
Posted 2008-02-29 6:08 PM (#52102 - in reply to #52091)
BTW, olive and vegetable oils can go rancid. :eek:
Posted 2008-02-29 6:29 PM (#52103 - in reply to #52091)
I spit on it and wipe it off with my sleeve.
Doesn't do much for cleaning it, but I'm seldom bothered by people wanting to borrow my guitars.
Eman
Posted 2008-02-29 7:49 PM (#52104 - in reply to #52091)
October 2002
I saw a video put out by Copley where the guy used 000 steel wool to remove dirt and polish the frets and then he used lemon oil. I bought some stuff called Dr. Longfellows magic fretboard dressing of some nonsense like that. The ingredients? Lemon oil.
For discoloration, you might want to use a tinted stain/wax (Minwax) first, let it dry and then use lemon oil. Try the stain on some other wood first to match the color. I'm sure they have something close to ebony or rosewood depending on what your fretboard is made of. Good luck.
Posted 2008-02-29 11:01 PM (#52105 - in reply to #52091)
Clean the fretwire with wd 40.
Clean the frets and the fretwire with naptha.
Remoisturize with mineral oil.
Don't stain. Let it be natural.
Forget the expensive stuff.
Posted 2008-03-01 10:25 AM (#52106 - in reply to #52091)
Now, boys. Don't fight.
Posted 2008-03-01 12:08 PM (#52107 - in reply to #52091)
Who's fighting? :confused:
Just personal preferences ... ;)
Posted 2008-03-01 2:42 PM (#52108 - in reply to #52091)
The fight detector senses no tension.
Eman
Posted 2008-03-01 4:53 PM (#52109 - in reply to #52091)
October 2002
Personally, I like the aged look so I would do the most natural thing one can do. I don't use steel wool, stain or WD40 (sounds like a good idea though). I just use Dunlop 65 on everything but the fretboard and I use conventional lemon oil on the fretboard to both clean and treat the wood. Not sure what to put on the bridge.
I learn a lot from OFC members and take no offense if someone offers a different opinion or criticizes mine. Heck, I'm a finance guy. What do I know about lutherie. Now I have to research naptha. Never heard of it but it might be something worth trying when I next re-string.
All that to say, no fight from me and thanks to all for the input on this and many many other issues!
Posted 2008-03-02 2:01 PM (#52110 - in reply to #52091)
I apply the same lemon oil that I use on the fretboard.(shrug)
cpMike
Posted 2008-03-05 9:29 PM (#52111 - in reply to #52091)
February 2008
I agree. From many years spent maintaining boats, I can very much recommend 3M synthetic steel wool pads. Any particles from the pads that get into the pores of the material you use them on will not rust. Plus the pads last forever; just rinse them and re-use. I know they have #000 grade at least.
Granted, the conditions that boats must endure are slightly more harsh than what a guitar must (depending on the player I suppose). I still like the peace of mind of not using "real" steel wool.
