UK II nut
   Members Forums -> Ovation Electric GuitarsMessage format
Posted 2014-02-11 10:13 PM (#482094)
Subject: UK II nut
For some reason someone replaced the nut on the UK2, which should be brass, with a plastic nut. My Viper, however, has a brass one. I'd swap them except the Viper neck is narrower. First, does the brass nut make much difference and, if so, how? Second, is the one for the UK2 comparable to any other guitar with a 1 11/16 nut? In other words, can I use whatever I can find if it's the right length, or do I have to worry about string spacing, fretboard radius and other issues?
Posted 2014-02-11 11:21 PM (#482097 - in reply to #482094)
Subject: Re: UK II nut
I don't think it's compatible. I'll check tomorrow but I think I have an extra UKII nut. Email me and I'll get the details and such to send it.. mileskb at aol dot com As far as the difference, the brass just adds to the whole sustain thing. On many guitars it makes things brighter, but on the UKII it just makes it right.
As a side note, I have an aluminum nut I made years ago for my Viper. That really changed the sound in a nice way. Added a richness and clarity without doing too bright.
numbfingers
Posted 2014-02-12 8:46 PM (#482124 - in reply to #482094)
Subject: RE: UK II nut
If Miles can't find his nut, I have a brass Allparts nut that might work. The slots are precut but might not match the UKII radius. Bought it for a UKII neck but haven't installed it. Could take a long time to find it, because my nut is small and mixed in with my larger parts.
Long long ago I took my Viper to Dan Torres' shop in San Carlos to have a brass nut installed on my Viper. Didn't make a huge difference, but they did scratch the headstock, apparently while filing the nut slots, which were cut so that the string spacing was uneven. <RANT> Only later did I figure out that Torres is a hack butcher who became well known only because his shop was near the offices of Guitar Player magazine. </RANT>
Edited by numbfingers 2014-02-12 9:00 PM
Posted 2014-02-12 9:38 PM (#482126 - in reply to #482094)
The Viper is only 1 5/8. I didn't notice much difference until I was playing hammer ons and pulloffs on open chords and couldn't seem to get my fingers from muffling the next string. I'm not much better with the UK II, but it's noticeably wider at the nut end. I like the Viper twang, which is probably enhanced by the brass nut and wondered what it should do to the UKII. The Viper looks like it has some repair where the headstock starts, so maybe that's why the nut was replaced. The UKII nut has glue slopped around it. I'm doing a very cheap restoration project. It will also be a good excuse to change the strings.
Posted 2014-02-13 1:42 AM (#482131 - in reply to #482094)
Mark, have you tried calling Mother? I swear they put a brand new one on when they fixed my neck.
Posted 2014-02-13 11:28 AM (#482138 - in reply to #482094)
I emailed Miles. If he doesn't have one, I'll call the Mothership. This is one of my many winter projects that I never started and winter is almost over.
Posted 2014-02-13 11:28 AM (#482139 - in reply to #482094)
I got one if all else fails
Posted 2014-02-25 10:23 AM (#482566 - in reply to #482094)
Thanks guys. I finally got ahold of John Budny. His email must have changed since the last time I used it or I was screwing something up. He's going to check the parts bin. If he can't find one, I'll get back to Miles and Beal.
Posted 2014-02-25 3:38 PM (#482578 - in reply to #482094)
The one I have appears to be "unfinished" in that it's the right dimensions, but not polished down and contoured like the ones on the guitars.
Maybe Beal or someone remembers how the build went because the nut I have was obviously installed at some point. Did they install the nuts THEN shape them? Seems a little counter intuitive but I'm sure if they did it, it had a reason...
TJR
Posted 2014-02-27 11:33 AM (#482607 - in reply to #482094)
July 2002
Sounds like a great project. Would like to see the finished product .
If all others leads fall through , I've got several, some still wrapped in paper
I'll verify the width
TJR.
Posted 2014-02-27 12:57 PM (#482608 - in reply to #482094)
I guess I better take some "before" pictures, in case I ever get to the "after" part.
What we really need to find are the original tone and volume knobs. That would be a project that even I could do.
Edited by Mark in Boise 2014-02-27 12:58 PM
danomyte
Posted 2014-02-28 8:37 AM (#482638 - in reply to #482094)
January 2014
I don't even think the nuts are solid brass.
TJR
Posted 2014-03-01 7:32 AM (#482662 - in reply to #482094)
July 2002
The ones I have are 1-11/16" wide
As for solid brass , they feel heavy enough to be so I cut one in half
It appears to be gold plated over cast brass
I'm away from home so it's not so easy to post pics right now I haven't figured out how to do it on my mobile device
Posted 2014-03-01 11:06 AM (#482669 - in reply to #482094)
Edited by MWoody 2014-03-01 11:09 AM
TJR
Posted 2014-03-01 11:11 AM (#482670 - in reply to #482094)
July 2002
A BIG thanks to MWoody for posting those pics up for me !!
Posted 2014-03-01 11:23 AM (#482672 - in reply to #482094)
Ain't no big thing!
On cast metal: My understanding of the "Die Cast" process is that the molten metal is injected and the metal cools from the outside in.
Since the injected metal is hot and expanding this forces more metal into the mold than a simple pour.
You end up with compressed metal (different grain structure) around the outside than in the center and it can add to the way the piece handles energy.
Is this all theory or proven mojo?
TJR
Posted 2014-03-01 11:35 AM (#482673 - in reply to #482094)
July 2002
If I had to guess. Id say they're from Schaller
Probably same process used to make the tuner buttons
danomyte
Posted 2014-03-03 1:56 PM (#482714 - in reply to #482094)
January 2014
Ahhh that would explain why I saw silver on the bottom of mine when I sanded it lightly to make the glue stick better. They chrome plate them before applying the gold finish.
Posted 2014-03-03 6:33 PM (#482733 - in reply to #482094)
I think that's the right width, so quit cutting them up! I haven't heard back from John Budny yet about what he found in the parts bin.
Posted 2014-03-04 1:34 PM (#482753 - in reply to #482094)
Just received the new nut from John in the mail. It looks just like the one in the pictures above. Now I'll have to take the before and after pictures and maybe try to polish the tarnished one on my Viper. Thanks, John and all the rest of you.
