1139 info wanted
d clark
Posted 2003-09-23 9:58 AM (#342481)
Subject: 1139 info wanted
anyone have any info,on a 1139 specs?value?clasical?
Posted 2003-09-23 11:20 AM (#342482 - in reply to #342481)
Subject: Re: 1139 info wanted
The 1139 refers to an early 80's Baladeer Special, which later became the Ultra before production went ofshore. It has an aluminum & urethane foam neck. It's a steel string not a classical. In good shape it'll be worth a couple of hundred dollars max. Use the search function above and put in the model number, there's been several threads in the past that will give you more info
