need parts for csd 225 double neck
plattyone
Posted 2009-06-18 10:20 AM (#290977)
Subject: need parts for csd 225 double neck
June 2009
I had someone modify my double neck. He installed two fishman natural 2 pickups. All the origanal parts have been lost. Both pick ups and the toggle switch. The wires coming out of the op-24+ pre amp have been cut. The reason I did the two separate outputs was to split the necks off to two separate loops. and have independence for each neck. With the double neck I play both necks at same time. The set up didn't work out like I had planned. So I would like to put it back to original. It sounded great when it was original. I tried contacting ovation and their response was to go to a dealer and they can order parts for you and good luck. I have dealt with dealers in the past. They want the guitar and to do the repairs. I just want the parts and I can install them on my own. Any info would be great! Thank you!!
Posted 2009-06-18 11:19 AM (#290978 - in reply to #290977)
Subject: Re: need parts for csd 225 double neck
Contact Alpep at lostartvintage.com. He's a dealer in NJ and he may be able to order parts for you.
