Hello everyone, Ovation Magnum I rebuild help!
Asomodai
Posted 2012-05-04 4:32 PM (#454140)
Subject: Hello everyone, Ovation Magnum I rebuild help!
May 2012
Hey Everyone.
My name is Rob, I am from Swindon in the UK and I have just picked up a somewhat abused Magnum I bass.
I generally play dub and doom style music which the neck pickup is amazing for.
Unfortunately the previous owner of the this particular magnum HACKSAWED the pickup surrounds so that it removed the join between the bridge and neck pickup either side of the strings. Whilst the part surrounding the pickups is fine, there is nothing joining them!
IS there any place or anyone who has created reproductions of the full metal surround? I would gladly buy one! Obviously buying one second hand would be near impossible.
Another few things, the switch appears to never want to stay in anything but the middle position, it springs back to it after a few seconds, I assume its a special type of switch, almost as if its on a spring. Is there a recommended replacement?
Also, the truss rod is pretty much maxed out and wont tighten anymore, is this going to be just a simple washer job? It seems to have a basic truss rod that will allow for it.
Kind regards to everyone who replies
Rob.
Posted 2012-05-04 5:23 PM (#454142 - in reply to #454140)
Subject: Re: Hello everyone, Ovation Magnum I rebuild help!
Welcome...
I thought I had a spare surround, but I can't find it. Someone may actually have one. When you respond I'll upgrade your access and move this into the general area where more people can respond.
Asomodai
Posted 2012-05-04 5:50 PM (#454143 - in reply to #454142)
May 2012
mileskb - 2012-05-04 11:23 PM
Welcome...
That's shame! Is there any benchmark as to how much surrounds go for? Also my serial number is 985 is that a fairly low one? Any ideas of age?
Thanks for your reply, much appreciated!
Posted 2012-05-04 6:27 PM (#454144 - in reply to #454140)
No idea what the surround would go for. As you can see I moved this into the general area and you can now post here as well.
Your bass has some interesting characteristics... It's a Magnum I based on the body design and electronics, but I've never seen an early one with a black surround and bridge. The black bridge was used for a little while near the end of the Magnum run on the III and IV's. The bases were from 1974 to 1983 and you can see from the Serial info in the FAQ section... "B+5 Digits = 1974-1979 Magnum solid body basses " so the 985 doesn't add up exactly.. The model was made from 1974 - 1980, so that narrows it down pretty close. Their may be a date under the bridge. Next time you change strings check it out.
Asomodai
Posted 2012-05-05 6:09 AM (#454169 - in reply to #454144)
May 2012
mileskb - 2012-05-05 12:27 AM
Well if you manage to find yours let me know! I also need the entire string mute section .
Well i was wrong on the serial number, its B00965.
Took a photo under the bridge and I am unsure what it actually says. However the pots look original they say 481007-A-98 and 1377811
I have seen lots of Magnum 1's and 2's with black surrounds and bridge, its just a lot of them have worn down the base finish underneath. Mine however does have chrome tuners, which I guess was standard.
Posted 2012-05-05 12:31 PM (#454184 - in reply to #454140)
Well that's interesting. The date looks like 7/71 but B + 5 digits starts at 1974. However, we don't have 1973 data specifically. Serial Numbers
Someone else might be able to chime in on the pot dates, but for now...  regardless of the serial number list... that looks pretty clearly to me like 7/71.  Interesting.
Posted 2012-05-05 6:03 PM (#454197 - in reply to #454140)
Kinda looks like 7/31 to me
Bluebird
Posted 2012-05-05 9:16 PM (#454206 - in reply to #454140)
So, the pots were made the 11th week of 1978 so at least you have a 'not before' date to go on.
bvince
Posted 2012-05-07 7:49 AM (#454261 - in reply to #454140)
September 2005
I truly hope you are able to find the parts you need, but you may be better off looking for a second guitar to cannibalize from. The neck and body on yours appear to still be in good shape. You may be able to eventually find one with a thrashed body at a cheap price. I've seen some like that go pretty cheap on Ebay.
Asomodai
Posted 2012-05-13 6:40 AM (#454541 - in reply to #454140)
May 2012
Cheers guys.
Still looking for the parts!
TJR
Posted 2012-05-15 8:50 PM (#454670 - in reply to #454541)
July 2002
I do have one , though I thought I had one that matched, (I'll look again). The surround I have is colored "Gold". :-(
It was part of a set of trim pieces for what I assume was intended to be a Magnum "Deluxe", much like the Preacher Deluxe had gold appointments. I'll try to get some pics later on. TJR
Edited by TJR 2012-05-15 8:51 PM
Asomodai
Posted 2012-05-16 1:49 PM (#454712 - in reply to #454670)
May 2012
trickard - 2012-05-16 2:50 AM
Gold?
Well I may convinced! Get me some pics and I can make a decision. Cheers!
Rob.
TJR
Posted 2012-05-17 10:49 AM (#454736 - in reply to #454712)
July 2002
I'll get the pics here soon.. I need to take them, then upload to a hosting site. Stay tuned.
Asomodai
Posted 2012-05-18 3:51 PM (#454785 - in reply to #454140)
May 2012
Would much appreciate, I have cash waiting, sorting out some black powder coating.
Asomodai
Posted 2012-05-22 11:24 AM (#454837 - in reply to #454140)
May 2012
Heya.
Any progress on those photos?
Cheers!
TJR
Posted 2012-05-23 11:16 AM (#454879 - in reply to #454837)
July 2002
Life's been in the way.. Please be patient. My best oportunity to get on the computer is usually when I'm no where near a camera or the parts. Talbot
TJR
Posted 2012-05-29 12:02 AM (#455084 - in reply to #454879)
Subject: Magnum Deluxe?
July 2002
Parts for a Magnun Deluxe? and a few Proto tail pieces.
https://picasaweb.google.com/104209077305164586938/OvationMagnumPart...
Asomodai
Posted 2012-05-29 11:07 AM (#455088 - in reply to #454140)
May 2012
Wonderful! I have private messaged you!
Rob.
Asomodai
Posted 2012-06-06 3:28 PM (#455309 - in reply to #454140)
May 2012
Bump, still looking for a pickup surround, Anyone?!
