broken in vs aged
sligoman
Posted 2008-05-01 10:31 PM (#41643)
Subject: broken in vs aged
October 2007
So what is it that makes an older guitar sound better? Playing or just aging. I guess I haven't had enough to know and wonder if it's the aging of the wood or the use that contributes the most.
FlicKreno aka Solid Top
Posted 2008-05-01 10:33 PM (#41644 - in reply to #41643)
Subject: Re: broken in vs aged
I would say : Both !
Vic
Posted 2008-05-01 10:49 PM (#41645 - in reply to #41643)
I'm no expert, but I think it needs to be PLAYED!
We could go into the technicalities of whether the vibrations cause the molecules to line-up, or whatever...
But I do think that it is the Playing that makes the difference.
If it hasn't been Played, it's just Old.
(and if it gets too dry or wet, then it is just old junk)
"I wanna New Tour Bus fulla Old Guitars..." :cool:
Posted 2008-05-02 7:53 AM (#41646 - in reply to #41643)
Playing it makes the greatest difference... it the guitar equivalent of breaking in a ball-glove...
Posted 2008-05-02 8:36 AM (#41647 - in reply to #41643)
yes
Posted 2008-05-02 9:21 AM (#41648 - in reply to #41643)
Not sure if I read it here or elsewhere, and I'm certainly no engineer, but the best explanation for me went something like this. A guitar's tone is impacted by a combination of numerous features, and the top vibration is one of the most significant. Vibration is good. The more the guitar is played, the better the top vibrates. Jeff's ball glove theory is right on. Think of a new piece of cardboard. It is difficult to bend. However, bend it back and forth 100 times and it becomes a much easier exercise. To a certain degree, wood and carbon share this elasticity characteristic. I think this explains why Mark's original slothead No. 43 has such an incredible ring to it.
numbfingers
Posted 2008-05-02 3:30 PM (#41649 - in reply to #41643)
A nice used guitar is broken in.
Many OFC members are aged.
TOPDOGJIM
Posted 2008-05-02 4:17 PM (#41650 - in reply to #41643)
February 2008
The salesman whom I bought my first decent guitar from told me to sit a radio in front of the guitar and let it play everyday while I was at work. Fortunitly I don't really like to work so I just played the heck out of it. I sold it a few years ago, I am lucky that from time to time I still get to play it and it sounds great. So I say - play it a lot for a long time.
Eman
Posted 2008-05-02 4:44 PM (#41651 - in reply to #41643)
October 2002
I read a study where they took equivalent brand new Martin D-28's and one was played regularly, the other was secured to a large speaker and subjected to various frequencies for the same period of time. The artificially aged guitar sounded much better at the conclusion of the exercise and was likened to guitars 20 years older that had been played regularly. Martin participated in the evaluation.
I've also read that guitars that are kept unplayed in their cases to preserve their "mint condition" tend to sound like crap. They do, however, sound much better if you take them out of their cases and actually play them.
Personally, whether broken in or not, I don't much care for the sound of a ball glove. I DO like the sound of a bat though, especially a wood one.
Sorry, slow day at work.
-Eman.
Posted 2008-05-02 5:42 PM (#41652 - in reply to #41643)
I knew there was a reason to keep all the guitars hanging in soundproofed bandroom as I crank up 1000 watts of amperage. For SWMBO, that's my new story and I'm stickin' to it. That is, to the extent I can hear the question.
Posted 2008-05-02 6:48 PM (#41653 - in reply to #41643)
So if you get a guitar that's been well-kept (unplayed), and you start to play it, will it open up? Seems like it should. Otherwise, what's the difference between making one out of wood from the 90's versus, say, sinker wood from the 19th century or salvaged wood from a century old building?
Posted 2008-05-02 7:32 PM (#41654 - in reply to #41643)
I just received a very nice/clean 1112 CB and now can compare it against my two years younger 1612 stage veteran.
The ol' 1612 vet definitely has more 'open richness' vs. the older 1112.
BTW, I'm impressed with the weight difference.
Posted 2008-05-02 7:44 PM (#41655 - in reply to #41643)
You want the BallGlove stiff where it needs to be and flexible every where else...
muzza
Posted 2008-05-02 7:57 PM (#41656 - in reply to #41643)
August 2005
...as I crank up 1000 watts of amperage...
Huh?
Posted 2008-05-02 11:22 PM (#41657 - in reply to #41643)
Huh?
Watts = sum total of Volts x Ampères..
ConeDrivers gobble -up tons of Ampères , and low voltage , say up to 10 - 15 volts..
Assuming a PA speaker gets fed 10 volts ( for sake of simplicity ) , then 1000 ampères divided by 10 volts would give One Hundred Ampère peak current , a Hefty Power Output , so , Proff.BB is not wrong , allthough I assume he meant WATTS , instead of Ampères..
Vic
..rather Elementary dear Muzzlite..
Posted 2008-05-03 1:21 AM (#41658 - in reply to #41643)
I think he was referring to pumping 1000 watts out of his amp, not watts out of amperes.
Bernard
Posted 2008-05-03 8:31 AM (#41659 - in reply to #41643)
April 2007
Hi everybody, interresting. Boucher guitars offers aged vintage tops. The tops are exposed to music 24h a day for a long périod and they say it sounds better. Itried them and I agree. I read an article on an expérience on violin (top quality sound) yhat was stored in complete silence for a year and it sounded bad but after playing again return to itS quality..... so keep playing !!! I would ad that time helps to because my first guitar I got in 1972!!! for 55$ was played a lot and sounds better than a 300$ new one. SO....
Eman
Posted 2008-05-05 3:53 PM (#41660 - in reply to #41643)
October 2002
It is possible to awaken a dead soundboard/solid wood guitar body. It takes some time and patience. Much easier to run vibration through the instrument electronically from an outside source than to bring it to life by playing it. Wish I could remember the source document I read. It came from Rick Turner's "Renassaince Guitars" website a few years back. Don't recall if he wrote it or just participated in the experiment. Think it may have been called "Instant Vintage" or some such thing.
Yes, unplayed guitars that have not been broken in are tight or "asleep" and need to be loosened up. Something about the fiber/resin composition and settling. Aged wood (rosewood, other tonewoods) are stored in a specific manner that perserves the livliness. If not done right, it makes a nice fire but not much else.
Lycrochord doesn't "age" but carbon fiber might, due to the resin used.
Posted 2008-05-05 3:58 PM (#41661 - in reply to #41643)
. . and there IS (albeit very thin) layer of wood running through the center . . .
