Capo for 12-string
| sycamore |
Joined: March 2007 Posts: 698 Location: Cork, Ireland | Anyone recommend a capo for a 12-string? My trusty Shubb sort of misses the 12th string, due to the heavier gauge of the adjacent 11th. I see that Shubb make one but its just a bit longer and more curved, not sure if that will catch the 12th string properly. | ||
| Tim in Yucaipa |
Joined: August 2003 Posts: 2246 Location: Yucaipa, California | I have a Balladeer 12 and I use ths Shubb-12 and it works just fine.... even up the neck for that mandolin-on-steroids sound. | ||
| Jeff W. |
Joined: November 2003 Posts: 11039 Location: Earth·SolarSystem·LocalInterstellarCloud·Local Bub | G7 and Planet Wave both make very good dedicated 12 string capos... The Shubb should work fine as well. They are all very good. | ||
| cliff |
Joined: March 2002 Posts: 14842 Location: NJ | Shubb 12-string. | ||
| Capo Guy |
Joined: December 2004 Posts: 4394 Location: East Tennessee | Originally posted by cliff: +1 for the Shubb. The G7 and Planet Waves are OK.Shubb 12-string. | ||
| Paul Templeman |
Joined: February 2002 Posts: 5750 Location: Scotland | I use a 6-string Shubb deluxe on my CG12 and it works fine, but I don't capo past the 4th fret on that guitar, a 6 string Shubb may struggle in higher positions. Try putting the capo on from above the neck rather than below, that might cure it. | ||
| Beal |
Joined: January 2002 Posts: 14127 Location: 6 String Ranch | Shubbs, Keyser or G7 | ||
| stephent28 |
Joined: April 2004 Posts: 13303 Location: Latitude 39.56819, Longitude -105.080066 | Shubbs or G7. | ||
| MusicMishka |
Joined: March 2005 Posts: 5567 Location: Blue Ridge Mountains | Shubb 12...and never look back! | ||
| sycamore |
Joined: March 2007 Posts: 698 Location: Cork, Ireland | Thanks all, local shop ordering me a Shubb 12. | ||
| Erniewan |
Joined: June 2004 Posts: 375 Location: Rocky River, Ohio | you'll love it. | ||
| TAFKAR |
Joined: April 2008 Posts: 2985 Location: Sydney, Australia | My normal G7 works just fine on my 12 string. One capo guy. | ||
| sycamore |
Joined: March 2007 Posts: 698 Location: Cork, Ireland | Actually, the normal Shubb works fine now - just played around a bit with the tension screw and position across the fretboard. | ||
| DRK HRSE |
Joined: September 2008 Posts: 58 Location: Just outside Dallas, TX | G7 makes a specific Capo for each type of Guitar - I have one for my 6, One for my Nylon (Classical Neck Width) and one for my 12... the 12 is just slightly wider than the 6 to ensure good contact with the Strings and neck... | ||
| bauerhillboy |
Joined: February 2004 Posts: 1634 Location: Warren,Pa. | I use the Schubb 12, but it's not a magic wand. The issue of the heavy gauge-next-to-the-light gauge strings requires adjusting the capo pretty tight and close to the fret; otherwise the light gauge strings sound muted. All of this means the strings go sharp and I have to re-tune...a little tricky when you're playing with others with no break between songs. The worst offenders are the low E,A& D strings. Sometimes I just turn my back and very quickly tune those down. Sometimes it's not spot-on. These issues only cause tension for me because of playing in a team of musicians. If you're by yourself you can relax. John <>{ | ||
| Damon67 |
Joined: December 2006 Posts: 6996 Location: Jet City | I bought a Keyser 12 string capo, then held it next to a regular Keyser 6 string. There was no difference I could see other than the package it came out of. | ||
| moody, p.i. |
Joined: March 2002 Posts: 15686 Location: SoCal | I've got a 6 and 12 and the 12 is slightly longer... | ||
| Damon67 |
Joined: December 2006 Posts: 6996 Location: Jet City | Then I was shafted by the store. They can easily "borrow" one out of those packages for a lesson or whatever and then replace it later with the incorrect one. | ||
Capo for 12-string
