UKII "too clean"?
muzza
Posted 2008-11-16 6:02 AM (#11813)
Subject: UKII "too clean"?
August 2005
Just after AJ loaned me his UKII, (back in August) I took it to work to let a colleague give it a workout, then on the way home, I took it in to see my local guitar store to get his opinion.
Both said, in not so many words, that it had a very "clean" sound and needed some "dirt".
Something someone said in a thread recently (Strat vs Les Paul) got me thinking about the above comments.
The thread I'm referring to said (something like) you can make a Strat sound dirty like a Gibson, but you can't get a Gibson to make a clean Strat sound.
Now, I know as much about electric guitars as Ozwatto knows about computers. :rolleyes: Wouldn't having a clean sounding guitar be much more versatile? Don't you get that 'dirty' sound through one of the myriad of pedals anyway?
Posted 2008-11-16 7:09 AM (#11814 - in reply to #11813)
Subject: Re: UKII "too clean"?
Yes.
Posted 2008-11-16 8:12 AM (#11815 - in reply to #11813)
I can't see how the UK11 could be described as "clean" Those pickups have enough output to overdrive anything. The dirt comes from the amplifer, in the way the input gain is balanced against output level, or you could use overdirve/distorton pedals.
Shroeder, remember when I had the T-Head plugged in an amp and swapped it for the UK11 which was at least double in volume? That's hardly a "clean" pickup in terms of output.
Now if there were referring to the "tone" being clean, then compared to say a Gibson humbucker then maybe. The UK11 pickups are brighter than most humbuckers but still have a very high output. Most high output pickups tend sound a little dull, as the extra coil windings tend to kill the treble response a little.
Posted 2008-11-16 9:06 AM (#11816 - in reply to #11813)
Mine had a very smooth "clean" tone but the p/u's had enough output to nicely drive the amp(Fender Deluxe)in the clean channel; in the drive (2) channel it was smooth sustained singing sound w/ the ammount of "dirt" according to the amount of pre amp dialed in; and in the overdrive (3) channel, it could get insane...
I have Clestions in both the amp and extra cabinet and was amazed at the great sound from the UK II.....It has the ability and flexability to sound pretty much like anything you want or need...
Posted 2008-11-16 9:45 AM (#11817 - in reply to #11813)
I remember the UKII very well - the most powerful pup I've heaqrd outside of a retro-fitted EMG active humbucker in a strat.
I was saying yes to the desirability of a great clean sound out of a guitar - like muzz says you can always dial in the filth but a good clean sound is something too many guitars lack. And amps - it's only in recent years that I've heard what I think of as a good clean sound out of a Marshall. And I've never thought much of Orange clean channels either.
Posted 2008-11-16 9:51 AM (#11818 - in reply to #11813)
It's like being able to grow a beard...
Posted 2008-11-16 1:09 PM (#11819 - in reply to #11813)
UK2 will get as dirty as you want.
Posted 2008-11-16 1:41 PM (#11820 - in reply to #11813)
With clean you can get dirty, but not the other way around.
Smoooth....now that's harder to find. Jazz git smooth.
"Orange" clean sound? I know the Blues, Grey and Dirty.....but I never heard Orange. (Besides, it's too hard to rhyme.)
Posted 2008-11-16 2:17 PM (#11821 - in reply to #11813)
Check out Damon's video's of his UKII... Clean?? Really ?? UKII is probably one of the most "flexible" humbuckers out there. Back off the volume and you can get a nice "clean." Lean on it, and you can get as much dirt as you want.
As far as the tone, as was eluded, they are brighter... which is fine. You can always take away bright with the tone control. Inversely, you can't put bright in if it doesn't exist in the first place.
Posted 2008-11-16 2:51 PM (#11822 - in reply to #11813)
UKII
That's going straight into a Carvin X100B. No pedals except for a bit of OD and delay for the solo.
The UKII is quiet when it comes to noise, but the pickups are way hotter than anything I own or have ever owned. That includes A LOT of freekin electric guitars over the years.
Maybe they don't know how to properly describe what they mean. I do that with wine at parties... "absurd, yet flaccid".
Maybe smooth is a better adjective. My Gibby pickups to seem more harsh, more mids which I guess could be considered dirt cuz it sounds like crap in my opinion. I have to do a lot more tweaking on the amps to get tones I like.
Posted 2008-11-16 3:17 PM (#11823 - in reply to #11813)
Damon,
What an awesome vid. That should go on YouTube!
Bluebird
Posted 2008-11-16 3:25 PM (#11824 - in reply to #11813)
Clean is not the word I would use at all for my Bluebird with UKII electronics, nor is it the case with my nephew's UKII. More of a trick to keep them sounding clean.
Posted 2008-11-16 3:38 PM (#11825 - in reply to #11813)
Thanks Johnny. It's up there.
If you go on to youtube and search for "Ovation UKII" only 2 vids come up. This is one.
Posted 2008-11-16 3:42 PM (#11826 - in reply to #11813)
Originally posted by Damon67:
"Ovation UKII"
Super! I just subscribed.
Posted 2008-11-16 3:59 PM (#11827 - in reply to #11813)
Cool. My first YouTube subscriber! :cool:
Posted 2008-11-16 4:27 PM (#11828 - in reply to #11813)
Also, to consider is the scale length. Strat or tele is 25.5 and UKII is 24.75, as I recall.
Another reason a tele sounds the way it does is that the harmonics are streched out over the strings while the les paul types are jammed closer together. Hence, the lp comes across as warmer (or muddier, as the overtones are closer together and more piled onto each other) and the tele is brighter (or cleaner) depending on your perspective.
True, you can add dirt thru an overdrive pedal, but I've found it best just to celebrate what they are instead of trying to make a strat sound like an LP. But you're right, it's easier to add dirt to tele, than to brighten an LP. Also, I like a wide neck tele scale because it fits my hands better, some of those LP's get cramped.
To me the UK II gets plenty warm, but other ears will differ.
Posted 2008-11-16 4:36 PM (#11829 - in reply to #11813)
There is an age at which alcohol is no longer a performance enhancing substance. They make pills that help, though not with the absurd part. ;)
ozwatto
Posted 2008-11-16 11:52 PM (#11830 - in reply to #11813)
January 2007
Thanks Muzza :D
I can be clean..but I like it dirty
