Mineral oil question?
dweezil
Posted 2009-10-03 5:48 AM (#395794)
Subject: Mineral oil question?
I vaguely recall you shouldn't use mineral oil on certain types of wood. Is that right?
I've used it in anger on my ebony fretboards but is it OK to use on rosewood?
TIA!
ksdaddy
Posted 2009-10-03 6:59 AM (#395795 - in reply to #395794)
Subject: Re: Mineral oil question?
April 2003
I don't know if you 'shouldn't' use mineral oil but I don't like it. I always find a gritty residue afterwards.
On the rare occasion I use oil, I use regular boiled linseed oil. It takes longer because you're not just slathering it on and then wiping off the excess; you need to rub it in quite vigorously until much heat is generated, then wipe off the excess like you were trying to erase what you just rubbed in. If you can actually see oil on the board, you've put too much on. The net amount applied will be negligible but will last a long time. I got sold on this idea on my '71 Les Paul about 10-12 years ago. Every spring the truss rod, action, and tuning would go nuts because of the increased humidity; it was unstable. One application seemed to cure it.
twistedlim
Posted 2009-10-03 7:47 AM (#395796 - in reply to #395794)
November 2008
I cant remember where but I have also read mineral oil on the fret board. I did in one time with no ill affects but I would let it soak in and then wipe it as clean as possible getting all the oil you can off the frets themselves before restringing.
Northcountry
Posted 2009-10-03 10:37 AM (#395797 - in reply to #395794)
If you apply the Linseed oil, (very good stuff) liberally then use the Mineral spirits to clean it off this seems to thin the remaining oil and it seems to help it seep into the wood a little better and cleans up very nice.
I think some glues (many glues) used in the very important attachment of the fret board to the neck (or the bridge to the body) can come loose if you get to much of the mineral spirits on the wood and it soaks through to this glue layer below. This makes sense.
I have a mixture of butchers wax, linseed oil, mineral spirits, lemon oil and cedar oil that seems to keep my fret boards, bridges and headstocks well oiled and the light residue of the wax helps seal it a little without a white residue. You can get a shine from a buffer if you want to take the time. It is thick enough that it seem to only penetrate very little into the woods surface. I only do this once or sometimes twice a year. Otherwise just a good cleaning with a dry rag seems to be fine.
Posted 2009-10-03 7:23 PM (#395798 - in reply to #395794)
yes
Posted 2009-10-03 7:53 PM (#395799 - in reply to #395794)
I have been using Baby Laxative lately.
Before that I was using Old English Lemon stuff.
Neither has destroyed my fretboard, yet.
Gallerinski
Posted 2009-10-03 8:43 PM (#395800 - in reply to #395794)
I use baby laxative on rosewood and ebony. Just soap and water on walnut.
Posted 2009-10-03 8:48 PM (#395801 - in reply to #395794)
by Gallerinski:
Thank You.
I gotta be reminded to resist the urge to oil my Adamas and Viper.
dweezil
Posted 2009-10-04 4:45 AM (#395802 - in reply to #395794)
Thanks for the reassurance, the Olivia is well and truely oiled up now, it was pretty thirsty too.
ksdaddy
Posted 2009-10-04 8:10 AM (#395803 - in reply to #395794)
April 2003
I avoid using any oil on my Moosup Applause and Academy KA-14.
I just slapped myself (I deserved it).
Posted 2009-10-04 8:50 PM (#395804 - in reply to #395794)
You can use Penzoil on those.
bvince
Posted 2009-10-05 9:31 AM (#395805 - in reply to #395794)
September 2005
I like that linseed oil idea. Good suggestion. I think I'd throw a bit of lemon oil in with it though. It seem as though the lemon oil would help with the linseed cleanup the same way citrus cleaner does. (??)
G8r
Posted 2009-10-05 9:45 AM (#395806 - in reply to #395794)
Be careful with "lemon oil." Unless you buy 100% pure lemon oil, most such products are actually a mix of organic solvents with just a small amount (<10%) actual lemon oil. Those solvents can leach the natural waxes out of ebony and rosewood and actually dry them out even more. If you use linseed, make sure it says "boiled" or the linseed oil can turn rancid and smell like crap.
bvince
Posted 2009-10-05 10:13 AM (#395807 - in reply to #395794)
September 2005
Thanks. I do have 100% lemon oil, and I'll make sure the linseed oil says "boiled" on the label.
Posted 2009-10-05 11:44 AM (#395808 - in reply to #395794)
never had a problem with mineral oil on rosewood.
Posted 2009-10-05 11:54 AM (#395809 - in reply to #395794)
Originally posted by an4340:
never had a problem with mineral oil on...
... any of my neck woods.
Posted 2009-10-05 12:04 PM (#395810 - in reply to #395794)
back of the neck gets butcher's wax
