Humidity control in the case
muskrat09
Posted 2010-12-12 11:26 PM (#359641)
Subject: Humidity control in the case
February 2009
I have a 07 Collectors and I am woundering what the best way is to add humidity while in the case. Could you name a specific product.
Posted 2010-12-12 11:33 PM (#359642 - in reply to #359641)
Subject: Re: Humidity control in the case
I use the Herco Guardfather
Posted 2010-12-13 9:21 AM (#359643 - in reply to #359641)
Take a new kitchen sponge and cut a piece off of it. Find a zip lock sandwich bag and punch a few holes in it with a paper hole punch. Wet the piece of sponge and then wring it out so that it is damp, not dripping wet. Put the sponge in the baggie and the baggie in your case.
Posted 2010-12-13 10:09 AM (#359644 - in reply to #359641)
Excellent idea, and one upon which Planet Waves has based their popular in-guitar humidifier for years. I use one, but FlySig's concept is the same thing and readily available from household stuff in the kitchen.
muskrat09
Posted 2010-12-13 12:30 PM (#359645 - in reply to #359641)
February 2009
Thanks for the tips. From what your saying it doesn't have to go inside the guitar.
Posted 2010-12-13 2:54 PM (#359646 - in reply to #359641)
Sounds like splitting hairs, but inside the accessories pocket, too? What about rust to any ferrous materials, i.e., capos, slides, etc?
Posted 2010-12-13 3:22 PM (#359647 - in reply to #359641)
Nope not inside the acessory pocket. Rust is not a problem.
Posted 2010-12-13 3:30 PM (#359648 - in reply to #359641)
So, best placement location? Under the peghead? The Ovation bowls are waterproof, so I guess the sponge could be placed by the heel of the neck. Don't think I'd want it near the electronics (if applicable). Some cases are pretty tight, so I'm thinkin' placement near the body is probably the most advantageous.
G8r
Posted 2010-12-13 9:27 PM (#359649 - in reply to #359641)
The idea is to humidify the air inside the case via evaporation from the "sponge." Whatever you wind up using - commercial or homemade - the idea is for the material that traps the water to be damp. No actual water should be leaking/dripping/flowing from the container, so no water would come in contact with any part of the guitar/electronics.
Posted 2010-12-13 9:58 PM (#359650 - in reply to #359641)
OK then, I will send up a "trial balloon" with my C2C4. It has some real small cracks in the fretboard. It will be interesting to see if they close up a bit, with an increased-humidity environment.
Posted 2010-12-14 1:52 AM (#359651 - in reply to #359641)
MF has dampits on Sale for $5.44, but I still prefer the Hercos
Posted 2010-12-14 9:54 AM (#359652 - in reply to #359641)
You can make your own. Go to the dollar store and get one of those travel soap cases. Poke a few holes in the top. There should be holes in the bottom. Get one of the wife's sponges, wet it, wring it out so it's only damp, throw it in the soap dish. Put it up near the peg head, and you're good to go. Also, apropos to the mineral oil thread, you'll find if you wipe on some oil, the small cracks will close up. Wipe on the oil after you've left the soap dish in the case for a week.
Posted 2010-12-14 9:54 AM (#359653 - in reply to #359641)
Posted 2010-12-14 9:55 AM (#359654 - in reply to #359641)
Is there an echo in here?
Rooster
Posted 2010-12-14 10:33 AM (#359655 - in reply to #359641)
November 2010
what if it's already wet? :eek: e-e-e-w-w-w-w!!
obscure???
seriously, is a good idea! i am going to use humidifiers from a large desktop humidor i no longer use. complete with sponge already.
Posted 2010-12-14 12:59 PM (#359656 - in reply to #359641)
Chet Atkins used to keep fresh cigars in his guitar cases....
Rooster
Posted 2010-12-18 10:26 AM (#359657 - in reply to #359641)
November 2010
i actually did the soap caddy thing. sponge fits perfectly. my balladeer fits way too snug, not enough room at headstock. I emptied the acc compartment and propped it open slightly with 2 soap caddy thingies inside. the 1778 case allows for the caddy to sit under headstock so i placed one there. my cigars stay put in the aristocrat plus humidor.
