Early Breadwinner pickup help
| AussieJames |
Joined: June 2007 Posts: 3084 Location: Brisbane Australia | The "for repair" AussieWinner I managed to snare here arrived today. Not in too bad shape really, a few nicks and bangs but nothing too bad really, looks to have been well played but not abused. Neck looks straight frets have been dressed at some stage and a bit low but ok. Its obviously an early one by the pups but the jack is in the pg not the body. Missing the parts as stated, neck plate, battery cover, nut etc. Which I already had. There must be different length neck mounting screws as the ones I had are a bit short, enought to assemble but I wouldn't string it. My biggest concern is the pups. The metal mounting plate on both pups has seperated from the pup itself. They were obviously glued originally but time has had its effect. I havent had a chance to power em up yet to see if they work but other than the plates coming unglued they look ok. Circuit board, switches, pots all look ok. Suggestions, just an epoxy type glue? Thanks guys AJ | ||
| numbfingers |
Joined: January 2006 Posts: 1132 Location: NW Washington State | James- You might want to put them together temporarily and make sure they're working properly before you permanently glue them with epoxy. Hot glue from a glue gun would do for that. It holds pretty well but can be removed. If there are any plastic parts, look for an epoxy that is made to bond to plastic. I've never seen one of these older pickups, but lack of knowledge has never stopped me! -Steve W. | ||
| FlySig |
Joined: October 2005 Posts: 4089 Location: Utah | I don't think epoxy would hurt anything, but if it were me I'd use something undoable, like hot glue. That way in the future you can get back inside if the pups need repair. | ||
| 2ifbyC |
| Joined: December 2006 Posts: 6268 Location: Florida Central Gulf Coast | RTV? ![]() | ||
| AussieJames |
Joined: June 2007 Posts: 3084 Location: Brisbane Australia | Thanks for the suggestions guys. I hadn't thought of hot glue, makes good sense. I will certainly make sure they work before I re glue them. I have a set of the later BW pups if need be but that would require a new pg as they are smaller than these. I would like to keep it as original as possible. Iffy, what's RTV? Is that Native American for chewing gum? :D AJ | ||
| 2ifbyC |
| Joined: December 2006 Posts: 6268 Location: Florida Central Gulf Coast | Originally posted by AussieJames: Not for this Yank... RTVchewing gum? | ||
| AussieJames |
Joined: June 2007 Posts: 3084 Location: Brisbane Australia | OK Thanks mate AJ | ||
| Mr. Ovation |
Joined: December 2001 Posts: 7248 Location: The Great Pacific Northwest | The originals were done with a double-sides foam. Not sure who thought that one up :) For some reason, hot glue doesn't seem to work very well. I use the Black Silicone RTV. It looks nice, fills in so there no vibrations. I've tried double-sided sticky foam also, and I guess they just don't make it like they used to, cause I couldn't get the stuff to hold at all. -mkb | ||
| AussieJames |
Joined: June 2007 Posts: 3084 Location: Brisbane Australia | Thanks guys. Miles the silicone sounds like the go. I'll power up the pups tomorrow and see what happens AJ | ||
| muzza |
![]() Joined: August 2005 Posts: 3736 Location: Sunshine State, Australia | Try carpet tape. Its an 'industrial grade' double sided tape that sticks like shit to fur. It will be as permanent as you want it to be. | ||
| Captain Black |
Joined: June 2007 Posts: 270 Location: Yorkshire, England | Jim, we have a product over here called 'No More Nails' - it will stick just about anything to anything, and they also produce a double sided tape version - do you have anything like that over where you are? Clyde | ||
| AussieJames |
Joined: June 2007 Posts: 3084 Location: Brisbane Australia | I got 2x 9v today, powered up the pups and plugged em in tonight. All good, seems to make all the right noises when I bang em with a screwdriver( gently) lol. Will use some Sikaflex silicone type stuff to secure the mount plates. AJ | ||
| numbfingers |
Joined: January 2006 Posts: 1132 Location: NW Washington State | Another easy test is to hold a tuning fork (not aluminum) near the pickup. You can compare the output and sound to your other guitars. -Steve W. | ||
| AussieJames |
Joined: June 2007 Posts: 3084 Location: Brisbane Australia | Steve thanks for the info. This forum is the best. Hey you going to the NW Jam? Just booked our airfares today, we are there!! AJ | ||
| numbfingers |
Joined: January 2006 Posts: 1132 Location: NW Washington State | James- I wasn't going to go due to my lack of guitar playing ability. But if you're going to travel all that way, I suppose I can make the 45 minute drive. The 4th is busy for me, but I'll probably stop by for a while on the 5th. -Steve W. | ||
| AussieJames |
Joined: June 2007 Posts: 3084 Location: Brisbane Australia | Mate I'm not much of a player either, more of a collector but who cares. I'm sure it will be fun and I'll learn something. Most of all I will meet some of you guys that's the best bit. AJ :) | ||
| Mark in Boise |
Joined: March 2005 Posts: 12762 Location: Boise, Idaho | I'll be there to ensure that no one else is embarassed about a lack of playing ability. I know a couple songs all the way through, but after a beer I forget them. Besides, 3 minutes without another gulp is too long. | ||
