Attempting to adjust neck!!!
Wis WGC
Posted 2008-08-17 9:09 AM (#25783)
Subject: Attempting to adjust neck!!!
July 2008
The neck on my Balladeer is bowed up, and I am going to attempt to adjust it for the first time. I have never done this, should I keep the strings on or off when doing this?
BT717
Posted 2008-08-17 9:25 AM (#25784 - in reply to #25783)
Subject: Re: Attempting to adjust neck!!!
October 2007
Definitely loosen them a bit! You don't need to take them off. At least I never have and have never had a problem.
Posted 2008-08-17 9:55 AM (#25785 - in reply to #25783)
Having only owned Ovations neck tweeks are very rare.
Putting a big ol' allen wrench to a guitar neck creeps me out. I'm afraid somthing is gonna snap or I'm going to get things out wack to the point of no return. So... I'm not the best guy to be giving advice.
However... I have found that, oddly enough, it's the UTE that gives me the most problems with the neck adjustment. Right now I have a buzzy B string at the fifth fret. I'm getting up the nerve to fiddle with it.
It seems to me that I'd want the string tuned right up so I can see the effect of the adjustments I'm making. If you loosened the strings wouldn't the distance from the fret board change when the strings are tightend up?
I've found that a change from lights to mediums alone has an effect on the neck setting.
One rule I do know is.... just a quarter turn at a time.
Posted 2008-08-17 10:05 AM (#25786 - in reply to #25783)
I don't loosen mine when adjusting. Just adjust it a 1/4 turn at a time
BT717
Posted 2008-08-17 10:18 AM (#25787 - in reply to #25783)
October 2007
My thinking is if you are tuned in E or on the sharp end of it (because you haven't tuned),
You could possibly "snap" a String. Better safe then sorry to take the extra time to retune b/4
you check the action. So, after saying that,
I will Defer to Mr Beal and Mr Slipkid as their "Knowledge" is much greater than mine.
Humblely yours,
BT :) ;)
Posted 2008-08-17 11:40 AM (#25788 - in reply to #25783)
Oh my... thanks, but to have those two names in the same sentence with the the operative word being some sort of equated "knowledge" is soooo funny to me.
I think I'll hire a little old lady to embroider that post, frame it, and hang it on the wall in the music room.
BT717
Posted 2008-08-17 12:27 PM (#25789 - in reply to #25783)
October 2007
I thought anyone over 5000 post were elevated to All knowing, all seeing "Godlike" status?? ;)
Posted 2008-08-17 12:32 PM (#25790 - in reply to #25783)
HA!
yeah... right
If you could just re-phrase that thing about being "god-like", I'll add it to the embroidery project. :D
BT717
Posted 2008-08-17 1:17 PM (#25791 - in reply to #25783)
October 2007
HA!
yeah... right
How's "Ovation Geek" sound?? :D
CanterburyStrings
Posted 2008-08-17 1:18 PM (#25792 - in reply to #25783)
March 2008
Keep the strings tuned to pitch. Even if you only loosen them a little, the tension they put on the neck will be less, and so you will have the "bow" come back when you retune it. (Actually, to be precise, or perhaps persnickety, it's called a warp when it is a "valley", and a bow when it's a "hill".) Quarter turn, then leave it for a day or so. You will probably find that in your area, you will have to make some adjustments twice a year. (Humid in the summer. Dry in the winter.)The action will change, get higher in summer, because the wood on the top will swell some. Once you have the neck straightened, you should adjust the action from the saddle. Shims in during winter, shims out in the summer.
Posted 2008-08-17 1:31 PM (#25793 - in reply to #25783)
There... now I've learned something.
I've never heard of the "overnight" thing before.
Thanks CB!
Wis WGC
Posted 2008-08-17 1:36 PM (#25794 - in reply to #25783)
July 2008
Thanks guys.....you all have been very helpfull. Strings in.
Posted 2008-08-17 4:44 PM (#25795 - in reply to #25783)
I don't take mine off either.
1/4 turn at a time.
Overnight rest to let the adjustment take hold.
Posted 2008-08-17 4:59 PM (#25796 - in reply to #25783)
What Canterbury said.
Posted 2008-08-17 6:27 PM (#25797 - in reply to #25783)
What Beal said.
AussieJames
Posted 2008-08-18 6:53 AM (#25798 - in reply to #25783)
June 2007
Ditto :)
Omaha
Posted 2008-08-18 10:52 AM (#25799 - in reply to #25783)
Triple dittos all around.
Less is more. Tiny little turns. Patience. Give it some time to settle in. You have to be at full tension or you are wasting your time.
