What Mics Are Used To Generate The Images For The Adamas 2080 NWT With VIP-5?
SpruceTop
Posted 2011-04-09 10:28 PM (#1726)
Subject: What Mics Are Used To Generate The Images For The Adamas 2080 NWT With VIP-5?
February 2011
Hi Folks,
Having just purchased a used, late-2008, Adamas 2080 NWT with VIP-5 preamp, I'd like to know what microphones were used to generate the VIP-5's Images. The particular booklet for this guitar's VIP-5 preamp, and mic-image listing, didn't come with the guitar. Thus, does anyone have the information I seek? Thanks!
Regards,
SpruceTop
P.S. I tried posting this in the "General" topic discussion board, but even though I've been a member of the board for a couple of months, I'm not allowed to post there. Is there a reason for my lack of access to other Ovation FanClub discussions? Thanks.
Posted 2011-04-10 3:07 PM (#1727 - in reply to #1726)
Subject: Re: What Mics Are Used To Generate The Images For The Adamas 2080 NWT With VIP-5?
Sprucetop, your status has been updated.
Now let me see if I can find the VIP manual for mine. I only remember that it's various mics on different adamas guitars I believe. If I remember right, the 2080 was only one of the models
SpruceTop
Posted 2011-04-10 3:25 PM (#1728 - in reply to #1726)
February 2011
Hi Damon67,
Thanks for updating my board-status!
I hope you, or anyone, is able to post what mics were used to generate the VIP-5 Mic Images for the Adamas 2080 NWT. Thanks!
Regards,
SpruceTop
titti
Posted 2011-04-11 12:53 PM (#1729 - in reply to #1726)
January 2011
.....here : 1) 2007BCS recorded via large diaphragm condenser mic
2) 2007BCS recorded via dynamic mic
3) Deep bowl cutaway Ovation via large diaphragm condenser mic
4) Deep bowl non-cutaway Ovation via a different large diaphragm condenser mic
5) Deep bowl Custom Legend recorded via dynamic mic It's right?
Posted 2011-04-11 2:45 PM (#1730 - in reply to #1726)
I don't think that's right for the 2080
Posted 2011-04-11 2:51 PM (#1731 - in reply to #1726)
Here's the right one:
1. Large diaphram condenser, 2080
2. Small diaphram condensor, 2080
3. Large diaphram condensor, 1680
4. Dynamic, 1680
5. Large diaphram condensor, 1581
AstroDan
Posted 2011-04-11 3:15 PM (#1732 - in reply to #1726)
March 2010
So... These are the one's used on the 07C w/ VIP? Interesting.
Never did see this.
titti
Posted 2011-04-11 3:56 PM (#1733 - in reply to #1726)
January 2011
Image list for the 2007 Bearclaw Collector:
1. Large diaphram condenser Contour Multi soundhole Spruce
2. Dynamic Contour Multi soundhole Spruce
3. Large diaphram condenser Deep Cutaway Multi soundhole Graphite
4. Large diaphram condenser Deep Non-Cutaway Center soundhole Spruce
5. Dynamic Deep Non-Cutaway Center soundhole Spruce
Image list for 2006 Koa Collector:
1. Large diaphram condensor Contour cutaway Figured Koa
2. Dynamic Contour cutaway Figured Koa
3. Large diaphram condensor Deep Cutaway Uni-directional composite graphite
4. Large diaphram condensor Deep Non-cutaway AAA Spruce
5. Dynamic Deep Non-cutaway AAA Spruce
1. Large diaphram condenser, Contour Bowl Cutaway, multi soundhole, Collector's 2006
2. Dynamic, Contour Bowl Cutaway, multi soundhole, Collector's 2006
3. Large diaphram condenser, Deep bowl, Adamas I multi soundhole, Adamas reissue 1581
4. Large diaphram condenser, Deep bowl, center soundhole, Custom Legend 1719
5. Dynamic, Deep bowl, center soundhole, Custom Legend 1719
how many VIP_5 exist?Anyone for Ovation $ Adamas? :confused: :confused: :confused:
titti
Posted 2011-04-12 4:13 PM (#1734 - in reply to #1726)
January 2011
.....at this point,if you please:Question :as I recognize my VIP-5 between these models?there is a sign?,a number,?a initial? :confused:
Posted 2011-04-12 7:29 PM (#1735 - in reply to #1726)
I have a VIP that I bought by itself with an XLR 'card'...
I just put it in assorted guitars when I feel so inclined.
So my images are just 1 thru 5.
I mostly use 4 and 5, sometimes 1... :p
TAFKAR
Posted 2011-04-12 8:16 PM (#1736 - in reply to #1726)
I didn't realise they programmed the VIP differently for each model. Theoretically, this means that if I swapped the VIPs in my 08C and 1680 I should hear a difference?
titti
Posted 2011-04-13 1:32 AM (#1737 - in reply to #1726)
January 2011
Clear question,if you please :exist one single VIP-5 with 5 images (...)or a model of VIP-5 for Adamas an another model of VIP-5 for Ovation ecc...?tank you :confused: :confused: :confused:
Posted 2011-04-16 8:29 PM (#1738 - in reply to #1726)
I've had two guitars with VIP, the 2007BCS and the 2080. The preamps both had little stickers on them, and a matching sticker on the can in the guitar. The 2080 says "SET 4". The 2007BCS has moved on to another owner and I do not recall what it said, just that it was another number other than 4.
titti
Posted 2011-04-17 12:09 PM (#1739 - in reply to #1726)
January 2011
...I also have two VIP-5.The first has a sticker that says "SET 4".The second says "SET 0" .....
:confused:
SpruceTop
Posted 2011-04-17 2:27 PM (#1740 - in reply to #1726)
February 2011
Thanks Folks for your input! What I'm actually looking for are the brand and model of mics used to generate the Adamas 2080 VIP-5 Images. For example, Martin's website lists the following mics used to generate the Aura Images for my Martin DCPA1 Performing Artist Series Dreadnought's onboard F1 Aura preamp:
From the VIP-5 preamp's characteristics, it sounds like this preamp is using Adamas 2080 Aura Images generated by Fishman. It would be nice to know what actual brand and model mics were used for the Adamas 2080. Maybe this information is out there somewhere but, regardless, the good part is that my Adamas 2080 sounds wonderful through my Bose L1 Model II with ToneMatch! If anyone comes across the actual mic and model listing for the Adamas 2080 VIP-5, please post. Thanks!
Regards,
SpruceTop
titti
Posted 2011-04-17 4:28 PM (#1741 - in reply to #1726)
January 2011
...well, we are waiting ....
:rolleyes:
