sound well and cone in reso-matrix project
| Jason_S |
Joined: August 2006 Posts: 2804 Location: ranson,wva | i started this project back in the summer and i finaly got the new top cut out and veenered, im getting ready to cut the hole for the cone and sound well but im kinda stumped, i got all the math and geomotry worked out, i know where the hole needs to go but not too shure how big to make it and how to hang the sound well. i was thinking of doing multi-soundholes as well..if temp,bill,miles or anyone else has any helpfull info i realy aprecaite it..thanks jason | ||
| Paul Templeman |
Joined: February 2002 Posts: 5750 Location: Scotland | If you’re using a Spider cone you will need a 10.5 inch hole or 9.5 for a biscuit cone. For the spider type the actual hole will need to be very slighty bigger so the cone can be installed and removed without binding on the edge. In this case the soundwell is just glued and clamped to the top. Bear in mind that Spider cones don’t actually need a soundwell. A lip around the hole to support the cone will work fine. If you install a soundwell you may need to support it from below. On Dobros with soundwells the soundwell connects the top to the back. | ||
| Jason_S |
Joined: August 2006 Posts: 2804 Location: ranson,wva | thanks temp,since this is my first reso project i think im gonna go with a spider bridge without a soundwell,this ones gonna probly look like shit anyhow. is bill's a biscuit or spider bridge? if i do decide to use a biscuit could i support it with braces running from the sides of the bowl? thanks jason | ||
| Paul Templeman |
Joined: February 2002 Posts: 5750 Location: Scotland | Bill's has a biscuit cone. These's no easy way to install a biscuit cone without a soundwell | ||
| cliff |
Joined: March 2002 Posts: 14842 Location: NJ | If I hadn't packed-up MasterTempleman's ResOvation (yesterday) for upcoming TransAtlantic PingPong, I woulda' posted a pic of the inside to show what the guy who adapted it "did" . . . Basically, a wooden ring that was glued/screwed to small, wooden blocks (of varying heights) that were epoxied to the inside of the bowl at strategic points to evenly support the ring . . . QuiteTidy. | ||
| Paul Templeman |
Joined: February 2002 Posts: 5750 Location: Scotland | Yeah, it's just the rest of it he made a complete bollocks of. You can't make a spider cone work without the spider. What a 'tard. | ||
| cliff |
Joined: March 2002 Posts: 14842 Location: NJ | I am NOT! . . | ||
| seesquare |
Joined: November 2002 Posts: 3666 Location: Pacific Northwest Inland Empire | Depending on how hard you want to work at this, I suppose you could derive the contour of the bowl, directly below the hole in the top, and taper the soundwell ring to fit it. The spider cone design on my Matrix project was a lot easier, since I didn't use a soundwell. 1/8" ply top, with a 1" ply support ring. Getting it DEAD flat is the tricky part. Not all cones are DEAD flat, either! Best of luck, Chris | ||
| seesquare |
Joined: November 2002 Posts: 3666 Location: Pacific Northwest Inland Empire | BTW, there is a picture of the critter in my OFC gallery. | ||
| Jason_S |
Joined: August 2006 Posts: 2804 Location: ranson,wva | i seen that this morning while i was having my honey nut cheerios and expresso..nice looking, i made my top out of a peice of 1/8in ply and covered it with a nice peice of burl crotch mahog..its do or die now, ive commited to the 10 1/2 in spider by cutting the top hole...we will se where it goes from here..jason | ||
| Jason_S |
Joined: August 2006 Posts: 2804 Location: ranson,wva | btw i was thinking of doing adamas sound holes with epaulets..any thoughts on that idea?? jason | ||
| seesquare |
Joined: November 2002 Posts: 3666 Location: Pacific Northwest Inland Empire | Jason, it's gotta breathe, sum-kinda-way. It's as good an option as any. Inlaid, or applied epaulets? No guts, no glory. | ||
| Jason_S |
Joined: August 2006 Posts: 2804 Location: ranson,wva | applied if i can source them out, i dont know if the factory will sell me a set or not..i doubt it tho..guess we will se what becomes of it...jason | ||
| Jason_S |
Joined: August 2006 Posts: 2804 Location: ranson,wva | i just relized after cleaning all the glue off the rim of the bowl where the plastic kerfing was glued that there is several spots that may be a problme, there is a few cracks i fixed with glass and resin,could i rebuild the small cracked rim with the same thing?? jason | ||
| seesquare |
Joined: November 2002 Posts: 3666 Location: Pacific Northwest Inland Empire | Originally posted by johnnycash83: Probably. By the time you install the new kerfing & attach the new top, it should hold soundly, anyway. And, if you route the edge for new binding, even better.i just relized after cleaning all the glue off the rim of the bowl where the plastic kerfing was glued that there is several spots that may be a problme, there is a few cracks i fixed with glass and resin,could i rebuild the small cracked rim with the same thing?? jason | ||
| Jason_S |
Joined: August 2006 Posts: 2804 Location: ranson,wva | by touching and feeling the bowl on the guitar you would never think they are as thin and flimsy as they are...i think the project is gonna turn out pretty good..jason | ||
