How did YOU do it (get that great recorded sound)?
dobro
Posted 2010-05-17 9:23 AM (#371736)
Subject: How did YOU do it (get that great recorded sound)?
I've been listening back to the Members' Night out and to various threads. There are some FANTASTIC sounds out there. I'm working on getting a good recorded sound now and would like to hear how YOU did it: Dweezil, Templemann, Sergio Lara and many others. Share! Share!
Posted 2010-05-17 9:46 AM (#371737 - in reply to #371736)
Subject: Re: How did YOU do it (get that great recorded sound)?
tell the engineer to make it good
Posted 2010-05-17 9:55 AM (#371738 - in reply to #371736)
buy shear, dumb luck.
And even then it's not so good.
Posted 2010-05-17 10:08 AM (#371739 - in reply to #371736)
The Readers Digest condensed version...
A Mac running Logic Pro, an audio interface, and a few ok mics.
Darkbar
Posted 2010-05-17 11:44 AM (#371740 - in reply to #371736)
January 2009
Isn't Stephen28 the expert? (or Avatar)
Posted 2010-05-17 12:34 PM (#371741 - in reply to #371736)
What Damon said. Except you don't need a Mac or Logic Pro. ;)
Some good post-recording plugins (and a little knowledge) helps.
Posted 2010-05-17 12:41 PM (#371742 - in reply to #371736)
When I first heard Waskel's album, I had all the knowledge I would ever need: I knew I would never be able to do anything that well. So far, I've been right.
Nils
Posted 2010-05-17 1:01 PM (#371743 - in reply to #371736)
Where Brad? I'd like to buy some dumb luck too! :)
Meuti
Posted 2010-05-17 1:04 PM (#371744 - in reply to #371736)
August 2009
+1 on what Mark said. Shakehands.
Posted 2010-05-17 1:06 PM (#371745 - in reply to #371736)
Not by a long shot. I've got some good equipment and growing knowledge but everyday is another learning experience.
Training your ear is the most important tool you can have and mine got pretty damaged from the '60s through the '80s when volume was king.
Posted 2010-05-17 6:04 PM (#371746 - in reply to #371736)
There is a very important few words that you will hear nearly every engineer use when describing a micing or recording technique.
As example for recording an acoustic guitar they may say.. "I usually start with a condenser mic between the sound hole and where the neck meets, and a nice cardiod pattern up near the headstock" or something similar.
For Drums they may say "I usually start by micing all the drums, with such'n such"...
The important word is "START!!!!!" Most engineers have a baseline where they START, but rarely do things "end up" where they started.
There is no magic bullet. While many engineers can turn out amazing recordings, they will likely say that their favorite recording was more "luck." than anything else. It may have been luck based on good technique, but it was still luck.
Same goes for the musical aspect. Get the tune you are recording down so you can play it in your sleep. When recording NEVER stop for mistakes, unless you've completely derailed. Miss a note, skip a chord, don't stop. Again, many musicians can track all day long without a mistake, but chances are one of their "favorites" came about because of some sort of screw up, mistake, or complete train wreck that turned into a hit song.
Was it Perl Jam at the Columbia MD, outdoor fest where the sound guy made what was going to be a bootleg 2-track recording of a sound check that turned out to be one of their biggest hits?
Posted 2010-05-17 6:37 PM (#371747 - in reply to #371736)
Yup. Last Kiss.
The other most important thing to getting the greatest sound is to truly play it to "the audience" with all you've got. Remember, it's still a live performance ...
Posted 2010-05-17 6:57 PM (#371748 - in reply to #371736)
There are some obvious things, such as turning off the furnace/AC so the noise level is as low as possible. Isolate power hum, use fresh strings on your guitar, tune each instrument, etc.
I like using a bit of compression on guitar and vocals. A multi-band compressor can be handy for the final mixdown. EQ with care, placing each instrument in it's own place in the mix left/right, and in terms of frequency spectrum. Use only a little bit of reverb, and don't use it on everything. Reverb on one guitar can give the impression of space without muddying the sound with reverb on every instrument. Listen to the final mix on several different systems, such as your home stereo, on your computer, and in your car. Listen at low volume to see if it still sounds good. Come back tomorrow or the day after and listen again.
Nothing substitutes for talent in the performance.
NostrAdamas
Posted 2010-05-17 7:58 PM (#371749 - in reply to #371736)
October 2004
Theres a few things that are critical,capturing a breath of life in you recorded performance can bring a spark to even a poorly recorded song.Fixing it in the mix doesnt work so well,I like to hear the sound Im going to record at the time im recording it.Compression can be a good thing but not too much.Trust your ear because your the one who will be listening to it the most.
Joyful Noise
Posted 2010-05-17 10:59 PM (#371750 - in reply to #371736)
And make notes on how you record each song. There's nothing worse than coming back and listening to something you recorded two years ago and saying, "Damn, that sounds good, now how did I record that?"
