iDea recognition on my PC conundrum
Posted 2011-05-27 11:39 AM (#351675)
Subject: iDea recognition on my PC conundrum
I have installed an iDea OPi-1 into my C2C4 project (1122 neck/deepbowl/cedar-top), and it works fine, but........when I connect it to my PC, operating with Windows XP, it does nothing to recognize the preamp as a "removable disc drive", as stated in the Quick Start Guide.
Any of you computer gurus out there have some insights, or suggestions?
Posted 2011-05-27 11:41 AM (#351676 - in reply to #351675)
Subject: Re: iDea recognition on my PC conundrum
BTW, I have sent an email to Mother about this last night, also. No word, yet.
AlanM
Posted 2011-05-27 11:50 AM (#351677 - in reply to #351675)
Just some quick thoughts...
Bad USB cable? Try another cable?
Bad USB hub? Tried other USB ports?
Rebooted? (both)
My Vista machines have been able to see my iDea.
G8r
Posted 2011-05-27 11:51 AM (#351678 - in reply to #351675)
Have you connected a lot of different removable devices (flash drives, memory cards, etc.) to that particular computer? I've seen WinXP assign a new drive letter to each new mass storage device you connect via USB. Once you've used up all the drive letters available, the OS can't assign a new one to a device it hasn't seen before. You can clear the USB device cache, but the how-to for that is best left to another forum.
Posted 2011-05-27 12:06 PM (#351679 - in reply to #351675)
All I've got is the USB cable that came with the iDea. It has some type of device inline on the cable, also. I have only plugged in my cardreader for my DSLR camera to the 2 USB ports, and I know they both work. I have rebooted the computer, by turning it on-&-off at least twice. No help.
I just don't know enough about this stuff to make an accurate description. All I have determined, it is not Plug-&-Play, yet.
G8r
Posted 2011-05-27 12:32 PM (#351680 - in reply to #351675)
Any chance you could try connecting it to another computer?
BTW, that "device inline" in a ferrite choke, designed to eliminate electromagnetic/radio frequency interference from the cable when it's connected.
Posted 2011-05-27 12:41 PM (#351681 - in reply to #351675)
Thanks for that info. I will lug this critter down to my office, and see if that PC recognizes it. Knowing all the security crap installed in that multi-user system, I'm not holding my breath.......
AlanM
Posted 2011-05-27 12:55 PM (#351682 - in reply to #351675)
Careful what you do! If I were to plug an iDea into my office computer, it would be an immediate firing offense!
(not joking here)
Posted 2011-05-27 6:32 PM (#351683 - in reply to #351675)
Our CEO's middle name is "Musician's Friend". I will ask first, though!
Posted 2011-05-27 7:44 PM (#351684 - in reply to #351675)
OK, OK, OK........
AlanM: "told you so, told you so"
I mean, whaddar the chances? Brand new electronic gizmo, everything else works fine and, S**T!!!- the USB cord is bad.
So, I will trundle myself off to the nearest Radio Shack, and get a replacement.
Mother was good enough to send me an output jack cable already, so I'm not "dippin' from the well" again, this soon.
Thanks for the help, Alan & G8r!
About that ferrite choke device- should I put it on the replacement patch cord? Technically, what does it "choke" off in the signal, that would be present in the recording environment?
Posted 2011-05-27 7:49 PM (#351685 - in reply to #351675)
Oh, and another thing:
Alan, did you install the aux jack in your guitar bowl, and what do you suggest, as to its useful purposes?
I would think, recording an entire song, for accompaniment, would use up quite a bit of memory space, from like your I-pod, or an I-tunes file.
AlanM
Posted 2011-05-28 8:12 PM (#351686 - in reply to #351675)
Didn't do the aux jack install...I use the iDea as a way to "jot down" musical ideas if I'm not at home. Also, to accompany myself from time to time.
Any slightly new iPod should have plenty of space for a LOT o'songs. Mine is a couple years old, and advertises that it will hold "over 5,000 songs." That means your usual 3-5 mb mp3's. I have a few symphonies and a few entire baseball games, as well as several "IT Crowd" (britwit) episodes and several hundred songs (some even of my own devising!), and I still have GIGAbytes of storage left.
Far as iTunes is concerned, I think that's limited only by the capacity of your hard drive.
Posted 2011-05-29 12:46 AM (#351687 - in reply to #351675)
Thanks for the informed observations. Actually, I was referring to storing entire songs on the iDea. So, not recording onto iTunes, but recording from iTunes, so I have something portable & present, when I'm practicing a piece. Original material, much less original ideas, are not likely, at this juncture.
I did get the aux jack installed, just in case.
It doesn't appear to turn the preamp on, like when plugging in the 1/4" jack, or the earbuds.
Posted 2011-05-29 10:03 AM (#351688 - in reply to #351675)
I believe they said at the RoadShow that the iDea holds 100 minutes of recorded audio.
Posted 2011-05-29 10:48 AM (#351689 - in reply to #351675)
Wow, that's quite a bit. Thanks!
