Will it clip past the Ears?
Tim in Yucaipa
Posted 2006-07-13 8:36 AM (#247786)
Subject: Will it clip past the Ears?
Does anyone know whether this tuner: Intelli Tuner will clip on over the Ovation Headstock "Ears"? My Intellitouch won't reach that far....
Posted 2006-07-13 8:43 AM (#247787 - in reply to #247786)
Subject: Re: Will it clip past the Ears?
I have those in stock, the clip has a depth of around 20mm, so I guess not. I'll take one home tonight and check on one of my guitars. We have a similar tuner from another manufacturer which has a longer clip and will fit on an Ovation headstock
Tim in Yucaipa
Posted 2006-07-13 8:45 AM (#247788 - in reply to #247786)
Thanks Paul!
What's the other one you have?
Hobie
Posted 2006-07-13 9:20 AM (#247789 - in reply to #247786)
This Intellitouch Tuner clips on to my 1778T OFT. Not at the top of the head stock but just prior to the high e tuner.
Had to use it while the Op Pro was out of action; work very well on a variety of electric guitars as well; check eBay,
Hobie
Posted 2006-07-13 9:21 AM (#247790 - in reply to #247786)
PS It provides just enough space to turn the high e knob
Tim in Yucaipa
Posted 2006-07-13 9:32 AM (#247791 - in reply to #247786)
Thanks Hobie,
I have one of those but it does get in the way a bit too much for my taste. I also have one of these: Korg AW-1 that does fit over the Ears, but doesn't have a backlight.... :(
xnoel
Posted 2006-07-13 9:33 AM (#247792 - in reply to #247786)
Like Hobie I have to use it between the high e and the nut. Works fine there. These are good tuners.
Hobie
Posted 2006-07-13 10:56 AM (#247793 - in reply to #247786)
I got the cheapie without the backlight; works fine but I don't gig so lighting is not an issue.
Posted 2006-07-13 4:51 PM (#247794 - in reply to #247786)
Tim, check this out. The tuner on the left is the Intelli. It will go on to an Ovation headstock, but only securely from the back and in the middle on the headstock. The other Tuner is an unbranded model I found at the Shanghai show. Longer clip, goes on front or back and the clip is long enough (just) to go on sideways over the "ear" Nice easy to read screen, icons in red which turn green when in tune. I have one of these that lives permanently on my squareneck dobro
Tim in Yucaipa
Posted 2006-07-13 6:16 PM (#247795 - in reply to #247786)
Thanks Paul.... I think I'll keep looking....
Posted 2006-07-13 9:11 PM (#247796 - in reply to #247786)
Seiko makes tuner shaped like the ONO pictured above and it works perfectly on O headstocks. I own it for that reason
Seiko tuner
Posted 2006-07-14 12:25 AM (#247797 - in reply to #247786)
This one shows the Seiko clipped to an Ovation.
Seiko on Ovation
Tim in Yucaipa
Posted 2006-07-14 7:55 AM (#247798 - in reply to #247786)
very interesting... thanks!
Posted 2006-07-14 10:32 AM (#247799 - in reply to #247786)
Thought I would give one a try. The price on Jeff's link was the best I found until an ebay search turned them up as tuners for a saxaphone. Cheap price, cheap shipping...got one coming my way.
