LX Neck reset anyone?
| d'ovation |
Joined: December 2003 Posts: 855 Location: Canada | I have searched the BFLG for "LX Neck" and have found nothing. So I am wondering anyone has attempted a neck reset on a LX guitar or at least explored or documented how the LX neck is attached to the body? | ||
| DanSavage |
Joined: June 2012 Posts: 2353 Location: Pueblo West, CO | If you don't see any bolt heads on the inside of the bowl at the neck heel area, then the neck is glued on.
If the neck is bolted on, then you'll need to free the fretboard extension from the top, then unbolt the neck to do a conventional reset. If glued on, the only way to do a neck reset is to remove the neck from the body. To do this, you'll need heat up the epoxy to soften it so the neck can be freed from the body. Ken (arumako) came up with a really slick way to soften the epoxy so he was able to remove the neck on his Celebrity. (See: Celebrity Deluxe CC247 Neck Reset) Edited by DanSavage 2015-12-16 1:09 PM | ||
| Old Man Arthur |
Joined: September 2006 Posts: 10777 Location: Keepin' It Weird in Portland, OR | Also... If you have an Elite-style, check to see if the fingerboard extension is bolted down. There will be a bolt head up under the fingerboard extension when you feel from the inside. | ||
| d'ovation |
Joined: December 2003 Posts: 855 Location: Canada | Thanks, I think your examples apply to necks with K-bar. I thought the LX models had a different approach with a separate block under the neck, and the fretboard is "floating"? | ||
| arumako |
Joined: October 2012 Posts: 1093 Location: Yokohama, Japan | Ummm, no insights to offer here; but boy, does that sound like fun! Edited by arumako 2015-12-16 6:00 PM | ||
| Old Man Arthur |
Joined: September 2006 Posts: 10777 Location: Keepin' It Weird in Portland, OR | Okay... My photo is of a 1778T Elite T with a Truss Rod Cover. It is not a Kaman Bar. But here is a photo of the innards of a 6778LX... Two bolts into the Heel Block. One bolt into the "tongue" of the fingerboard extension. So, if you have an Elite... That is how it attaches. | ||
| d'ovation |
Joined: December 2003 Posts: 855 Location: Canada | Thanks Oma. It's a Legend but should be similar too I guess. | ||
| Old Man Arthur |
Joined: September 2006 Posts: 10777 Location: Keepin' It Weird in Portland, OR | It depends on how the fingerboard is attached. I have only taken-apart an Elite. So a Legend still might have the fingerboard glued to the top. I have read about people peeling the fingerboard loose with a spatula... You should talk to DanSavage before doing that. You might be able to do a half-assed reset by just Loosening and re-Tightening the two main bolts. But discuss this with smarter people first. | ||
| tpa |
Joined: December 2004 Posts: 587 Location: Denmark | |||
| Randy22 |
Joined: April 2003 Posts: 252 Location: Pewaukee, WI | Digging up this old thread as my new-to-me 2079LX has no shims and kind of high action. Has anyone done this to an LX? | ||
| seesquare |
Joined: November 2002 Posts: 3667 Location: Pacific Northwest Inland Empire | Sorry, no. Best of luck and consult with the guys at Ren-Ovation. They might have some insights. | ||
| Love O Fair |
Joined: February 2016 Posts: 1895 Location: When?? | As the late, great OMA once said.. "You might be able to do a half-assed reset by just Loosening and re-Tightening the two main bolts." I have one LX I plan on.. maybe.. doing that with during the next re-string just to see how much, or how little, give and lash I may find in there. Meantime, please let us know of anything you may attempt (and/or succeed/fail with) if you decide on anything short of a full removal. | ||
| Randy22 |
Joined: April 2003 Posts: 252 Location: Pewaukee, WI | Thanks! Not sure I'm brave enough to try; let me know if you do | ||
