D2
willard
Posted 2005-03-12 8:38 AM (#159963)
Subject: D2
It's probably a chord that I play already but I can't seem to find a notation for "D2". Could someone post the notation? Thanks
cruster
Posted 2005-03-12 8:48 AM (#159964 - in reply to #159963)
Subject: Re: D2
Never heard of a '2' chord. But, a 9 is a 2, just an octave higher, so couldn't you play a D9?
mattsmith
Posted 2005-03-12 8:57 AM (#159965 - in reply to #159963)
Subject: Re: D2
any chord labeled"2" or "5" is a triad (3 note) chord with no 3rd... a major triad uses the root 3rd and 5th of the triads major scale.. a 9th chord uses the root,3rd,5th,b7thand 9 (2) of the major scale... a "2" chord would use the root,2nd and 5th notes of the major scale... heres a d2
...0....
...3...,
...2....
...0....
TWA
Posted 2005-03-12 8:57 AM (#159966 - in reply to #159963)
Subject: Re: D2
I searched 2 chord reference programs. No D2.
TWA
Posted 2005-03-12 8:58 AM (#159967 - in reply to #159963)
Subject: Re: D2
Of course I didn't complete music theory studies...
Posted 2005-03-12 8:59 AM (#159968 - in reply to #159963)
Subject: Re: D2
D2 would mean add the note 2 steps above D, which would be an E. I'm not sure if you would leave the high E string open or add E on the D string, or both. I guess it would depend on which sounded better in the chord progression you're playing.
LeftyThatPlaysRighty
Posted 2005-03-12 9:00 AM (#159969 - in reply to #159963)
Subject: Re: D2
I use a D2 chord, It is the D chord minus the F# not that is played on the First (high) E string (play it open). Fingering uses only the D (second string 3 fret) and A (third string 2 fret). Strings 4,5 and 6 are played open. I usually grab the D chord and lift my middle finger that would play the F# note. I see it used alot in worship/christian contemporary music.
mattsmith
Posted 2005-03-12 9:00 AM (#159970 - in reply to #159963)
Subject: Re: D2
or it could be a subgroup of the r2d2 chord family, usually played by small annoying robot guitarists that squeek and bleep alot...
willard
Posted 2005-03-12 9:54 AM (#159971 - in reply to #159963)
Subject: Re: D2
Thanks to all. I think Matt was the first to explain it. Looks like it's just a D without the F#. L.P.T.R, you correct that I see it in a lot of P&W songs. I've used it for years but never known what it was called.
leftovertion
Posted 2005-03-12 9:58 AM (#159972 - in reply to #159963)
Subject: Re: D2
July 2004
The '2' chord also sounds good with the root in the base and using the 2nd 3rd and 5th notes of the scale to build the chord, for D2, using Matt's notation:
...2...
...5...(use pinky to reach)
...2...
...0...
...x...
...x...
Here's a fun progression using a D chord, then going to a D2 with a C in the bass (play as an arpeggio):
...2...
...3...
...2...
...0...
...x...
...x...
Then:
...2...
...5...
...2...
...x...
...3...
...x...
Of course, this is all in standard tuning; when you get into other tunings, you find lots of '2' chords showing up naturally in arpeggio's played on open strings...but that's another post...
Posted 2005-03-12 10:12 AM (#159973 - in reply to #159963)
Subject: Re: D2
D2...
That's a movie about hockey!
Matt said it simpler when he said:
...0....
...3...,
...2....
...0....
All the other stuff was invented to make guys like me polish their seat in class.
It also sounds good when the thumb reaches around the 12 string neck and covers the "E" on the 2nd fret. D/F# I believe?
Paulcc1
Posted 2005-03-12 12:19 PM (#159974 - in reply to #159963)
Subject: Re: D2
September 2004
R2D2 was in a movie.
Paul
BruDeV
Posted 2005-03-12 6:13 PM (#159975 - in reply to #159963)
Subject: Re: D2
Look for Dsus2 (D suspended 2nd) or D/2 (D add 2).
