Open E Tuning
Steveomatic
Posted 2016-04-28 12:01 PM (#524932)
Subject: Open E Tuning
May 2011
Hello all,
Can Ovations handle tuning to open e with the added stress on the neck? Speaking about my Book Elite. I know I can tune down and capo but I prefer the tone of open e.
Thanks,
Steve
bburg
Posted 2016-04-28 12:21 PM (#524934 - in reply to #524932)
Subject: Re: Open E Tuning
August 2009
The guitar has a Kaman-Bar neck and a pinned bridge, so there I'd not expect issues. The only thing is the top behind the bridge. Mine got two awful cracks, only using 12er strings.
So if I'd tune up to open E I'd use 10er or 11er (max.) strings....
Bernie
Posted 2016-04-28 12:23 PM (#524935 - in reply to #524932)
I tune to open E all the time. How else can you play She Talks To Angels?
leonardmccoy
Posted 2016-04-28 1:32 PM (#524939 - in reply to #524932)
December 2015
It depends on the string gauge and guitar. It's not a problem on any guitar with Lights. However, if your concern is putting too much stress on the neck (rare vintage guitars being the usual suspect), you can also tune to Open D tuning instead (D A D F# A D), and capo at the 2nd fret -- that gives you the same result, only with way less stress on the neck.
leonardmccoy
Posted 2016-04-28 1:41 PM (#524940 - in reply to #524934)
December 2015
bburg - 2016-04-28 12:21 PM
Bernie
Correct me if I'm wrong, but this is likely to be caused by how Ovation attaches the bridges to their tops? They glue down the bridge on top of fixating it firmly with two screws. This seems to be detrimental to me, since, once the glue starts coming off (which it seems to do with some of the older Ovations eventually), so does the bridge except that it's still being held in place firmly by the two screws, which in turn rip up the top, causing cracks away from and towards the bridge.
Edited by leonardmccoy 2016-04-28 1:46 PM
bburg
Posted 2016-04-28 2:06 PM (#524941 - in reply to #524932)
August 2009
Don't ask me-I don't know!! 12er Strings are not that hard..., but...I bought my guitar from Florida where the humidity is almost high and it came in Winter where the humidity in our area is almost low... Otherwise the bracing maybe is a point... The great tops with fine grain..... It was the only one I bought in USA which had cracks shortly after the arrival, so I don't believe it's an issue caused by the construction of Ovation.
Bernie
Posted 2016-04-28 2:22 PM (#524942 - in reply to #524932)
screws were only usually used on stained tops since the stain made it a little more difficult to get a solid bond between top and bridge. Naturals usually don't have screws
leonardmccoy
Posted 2016-04-28 2:51 PM (#524943 - in reply to #524942)
December 2015
Beal - 2016-04-28 2:22 PM
Thanks, that explains why I've been seeing some with and others without bridge screws.
Steveomatic
Posted 2016-04-28 5:30 PM (#524947 - in reply to #524943)
May 2011
Thanks for all the info. I might just tune down to open d and capo at the 2nd just in case.
Posted 2016-04-28 8:20 PM (#524949 - in reply to #524932)
Okay... You tune two strings up a step, and one string up a half-step.
This should not be a big deal!
If you are really concerned, de-tune those three strings when you aren't playing it.
Helpful?
Posted 2016-04-29 7:28 AM (#524950 - in reply to #524935)
Damon67 - 2016-04-28 12:23 PM
Damon - with what string gauge?
Posted 2016-04-29 11:44 AM (#524956 - in reply to #524932)
Same that are on most of the acoustics, EJ16
Edited by Damon67 2016-04-29 11:45 AM
Posted 2016-04-30 7:03 PM (#524969 - in reply to #524932)
". . It depends on the string gauge and guitar. It's not a problem on any guitar with Lights. However, if your concern is putting too much stress on the neck (rare vintage guitars being the usual suspect), you can also tune to Open D tuning instead (D A D F# A D), and capo at the 2nd fret -- that gives you the same result, only with way less stress on the neck . ."
I just use a Kyser PartialCapo(only capo's strings 2-thru-5).
Clamp-it-on @2ndFret and both E's remain OPEN strings instead of de-tuned/capo'd . . .
