Wall hanger question...
RNickels
Posted 2011-03-08 3:30 PM (#354975)
Subject: Wall hanger question...
May 2009
I have wall hangers in my office for my guitars and have a question about potential damage to my acoustics. When hanging from the wall, the acoustic guitars seem to sit at a noticeable angle protruding out more from the wall the further down the guitar you go. With the electrics, they hang straight down with no angle whatsoever.
My question is, will this damage the acoustic neck over time from hanging at an angle? Or is there a better mount to use for acoustics?
I am currently using these Hercules wall mounts to hang the guitars.
Hercules hangers I\'m currently using.
Picture of what's going on, very noticeable angle here... should I be concerned?
Tim in Yucaipa
Posted 2011-03-08 3:58 PM (#354976 - in reply to #354975)
Subject: Re: Wall hanger question...
....different center of gravity effect?
RNickels
Posted 2011-03-08 4:16 PM (#354977 - in reply to #354975)
May 2009
For sure it is center of gravity, has to be cause no matter which of the 3 hangers I put it on I get the same effect... just want to make sure it's not gonna hurt anything.
Posted 2011-03-08 4:43 PM (#354978 - in reply to #354975)
So long as they don't hit the ground they will be fine. :cool:
Darkbar
Posted 2011-03-08 4:43 PM (#354979 - in reply to #354975)
January 2009
I doubt if the tension of the strings doesn't cause a big problem, the angle of descent won't either.
bvince
Posted 2011-03-08 4:47 PM (#354980 - in reply to #354975)
September 2005
I don't have the Hercules hangers, and my guitars all hang straight down. I can see from the pics that the Hercules hangers angle up a bit. Since the acoustics are a lot lighter, perhaps the Hercules securing tabs are pulling back on the guitar's neck as it rests in the cradle. If you notice the acoustic not being able to rock a little in the hanger, that could indicate that pressure is on the neck. I don't know if that would cause any problem with the neck or not in the long run, but it would concern me a bit. Of course it could be the center-of-gravity thing also, but like I said ... it isn't happening with my hangers.
Posted 2011-03-08 5:12 PM (#354981 - in reply to #354975)
I wouldn't tolerate the angle and would modify the hanger to correct the issue. I have some experience modifying factory wall hangers to fit my unique applications, although I don't recall messing with any Hercules brand hangers.
Posted 2011-03-08 6:21 PM (#354982 - in reply to #354975)
Make sure they're seated all the way back in the cradle.
muzza
Posted 2011-03-08 7:06 PM (#354983 - in reply to #354975)
August 2005
It's not a problem - as long as the guitar is hanging freely there is no adverse pressure on the neck. If you modified the hanger so the headstock was clamped in postition to keep the neck vertical, THEN you'd be introducing unnatural stresses on the neck.
It hangs where it hangs.
It's physics.
It's all good.
RNickels
Posted 2011-03-09 1:41 PM (#354984 - in reply to #354975)
May 2009
Thanks for all the suggestions and feedback fellas, the guitar rocks freely and is sitting all the way in the back of the cradle each time it is placed there. It still makes me a bit nervous but I suppose I will just keep a close eye on the action to make sure nothing is changing!
muzza
Posted 2011-03-09 1:52 PM (#354985 - in reply to #354975)
August 2005
If the action changes, it won't be because you're using a wall hanger.
Captain Black
Posted 2011-03-10 5:12 PM (#354986 - in reply to #354975)
June 2007
For what it's worth, after long & careful thought over the years, I won't hang any instrument by it's neck. I always go by the rule that if I wouldn't like it myself, why would I do it to anything else?
Posted 2011-03-12 12:45 AM (#354987 - in reply to #354975)
Oops, from the title, I thought at first this was about the calendars...my bad :rolleyes:
