UK II 3-way switch wiring
enders UKII
Posted 2008-08-11 3:52 PM (#26686)
Subject: UK II 3-way switch wiring
August 2008
Hello,
I am new to this forum and to Ovation guitars. I recently bought a UK2 which is in pretty good shape, EXCEPT that the previous owner appears to have rewired part of the guitar. The 3-way switch only gives one pup or the other, but not both pups at once. In the center position, the switch only activates the bridge pup.
Anyone know which color wires go to what parts of the switch? Also, does anything connect to either of the two screws on the side of the switch?
Anxious to get this guitar into full swing. Any help greatly appreciated.
Posted 2008-08-11 4:06 PM (#26687 - in reply to #26686)
Subject: Re: UK II 3-way switch wiring
Remove and visually inspect the switch. Sometimes the spring pieces get a little worn or a little bit of film and causes the center position to only connect one pickup, or none sometimes.
Sometimes it is a wiring issue, but more often than not, it's a mechanical issue.
enders UKII
Posted 2008-08-11 4:09 PM (#26688 - in reply to #26686)
August 2008
Hi Mr Ovation,
I put a new switch in and have the same problem.
Cheers.
Posted 2008-08-11 6:35 PM (#26689 - in reply to #26686)
If you can get one and then the other you shouold be able to get both. Better check the wiring again.
enders UKII
Posted 2008-08-11 6:40 PM (#26690 - in reply to #26686)
August 2008
Hell Mauvais. I agree. That's the problem. The wiring looks to be messed with, and I'm not sure how it should be. Currently, there are a green and yellow wire on one side of the switch leading to the jacks, and a red - black - blue configuration on the other (to the pups). There are also 2 screws on the side of the switch with nothing on them - don't know if they're supposed to remain that way. Any further help definitely appreciated.
enders UKII
Posted 2008-08-11 6:41 PM (#26691 - in reply to #26686)
August 2008
Meant to say Hello Mauvais.
Posted 2008-08-11 6:53 PM (#26692 - in reply to #26686)
Yes, Hello to you too. should be pretty much like a Paul but I can't tell you the wires and colors. Keep at it, you'll figger it out, oh hell, you know what I mean.
enders UKII
Posted 2008-08-11 6:54 PM (#26693 - in reply to #26686)
August 2008
Thanks Mauvais. Will try.
Posted 2008-08-12 7:21 PM (#26694 - in reply to #26686)
I opened the back cover on my UK II and here is the wiring: the switch has three top(from the back) wires and the bottom (underneath the top wires) has two wires:
Looking at the switch from the back with the wires towards the bottom of the switch cavity:
Top: (looking at the switch from left to right)
1st: Red
2nd: Black
3rd: Blue
Bottom (Left to Right)
1st: Yellow
2nd: Green
Hope that helps!
BTW: Welcome to the club!
enders UKII
Posted 2008-08-12 7:25 PM (#26695 - in reply to #26686)
August 2008
Thank you Music Mike. I truly appreciate your doing that. That's exactly the way it was wired on mine. Good to confirm. I finally gave up yesterday and brought it into a guitar tech who called me and told me it's now fixed. The good thing besides is that I'm now getting the guitar professionally set up. Can't wait.
Posted 2008-08-12 8:53 PM (#26696 - in reply to #26686)
I think you'll really like it.
Posted 2008-08-13 2:27 PM (#26697 - in reply to #26686)
I have a few guitars, that's my fav for sure.
enders UKII
Posted 2008-08-13 2:29 PM (#26698 - in reply to #26686)
August 2008
Yeah. I've had several in the past, and I kinda fell in love with this guitar at first play.
