Can a suspension ring top be replaced?
Posted 2010-05-17 6:40 PM (#371715)
Subject: Can a suspension ring top be replaced?
Can the Mothership replace just the top on a suspended ring Adamas such as the ADII? Any wild guesses on the cost of such a job?
G8r
Posted 2010-05-17 6:56 PM (#371716 - in reply to #371715)
Subject: Re: Can a suspension ring top be replaced?
Sure you mean ADII? The Al DiMeola 1769 AD-II is a (wood top) Custom Legend. If you mean an Adamas II, I would think they'd just use a whole top/bowl assembly.
Posted 2010-05-17 7:00 PM (#371717 - in reply to #371715)
Adamas II, aka 1581. It has a cutaway lyrachord bowl with the suspension ring attachment to the top. The ring probably needs to be replaced along with the top, though I'm not sure.
Posted 2010-05-17 7:52 PM (#371718 - in reply to #371715)
top and bowl would be my guess.
Posted 2010-05-17 8:00 PM (#371719 - in reply to #371715)
I would guess that TJ would be right, but I've never run across that question before...
Posted 2010-05-17 8:29 PM (#371720 - in reply to #371715)
Me neither... But it sure would open up some neat possibilities to have a SR option!
Posted 2010-05-17 9:43 PM (#371721 - in reply to #371715)
When you think about how much a bowl costs, I mean COSTS to Ovation, It's probably a lot cheaper to replace a top/bowl assy. than to cut the top off, refinish the edge of the bowl and attach a new top, don't cha think?
bauerhillboy
Posted 2010-05-17 10:07 PM (#371722 - in reply to #371715)
Last I heard, an injection-moulded Ovation bowl cost the company $60 or so. Even though the cost of a hand-laid fiberglass bowl would be more, it's easy to see how it would cost less in labor to just replace the bowl than to do what it takes to remove the top from the bowl and replace it. There is nothing about an original bowl that makes it worth more than a new bowl.
We've seen here how, as a labor of love, a member has carefully removed a bad top and replaced it with a new one. Such a job is a worthwhile "labor of love", but not if you're paying the service dept. to do it.
Gallerinski
Posted 2010-05-17 10:25 PM (#371723 - in reply to #371715)
Just curious, why do you care about the bowl? Sounds from your description that you have a busted up top that needs replacing. Do you really care if they replace the bowl or not?
Posted 2010-05-17 10:32 PM (#371724 - in reply to #371715)
There's a local guitar that has a badly busted top but otherwise looks like it can be saved. Definitely it needs a new top. The question is whether it is worth the time, effort, and $ to rehab this thing.
The guitar is pretty close to what I would want out of a custom order, but I cannot come close to affording the custom order. I'm wondering if it might be a nicely affordable option to put a new top on an otherwise good Adamas.
Posted 2010-05-18 9:10 AM (#371725 - in reply to #371715)
Sent you a PM Flysig. Hope it's helpful.
Posted 2010-05-18 10:07 AM (#371726 - in reply to #371715)
Reply sent.
