Quick question about the thunderhead balance control
| The Ovation Fan Club -> Welcome Center | Message format | |
| Kev100 |
Joined: October 2019 Posts: 21 | Hi, The balance control on my 72 thunderhead sweeps between the neck pickup, through to the bridge pickup. However, the middle part has much lower output than either end. It’s always been like this since I got the guitar, and I’ve never given it much thought, apart for needing a clean with some switch cleaner to get rid of some noise. Now it just struck me as counter intuitive. I’d have thought that the middle position of the control should have both pickups on, and deliver more output? Do I need a replacement pot? Cheers, Kev | ||
| alpep |
Joined: December 2001 Posts: 10583 Location: NJ | try cleaning the controls is the neck pickups louder than the bridge? is it just the perception of sound? | ||
| Kev100 |
Joined: October 2019 Posts: 21 | Hi, thanks for the suggestion. I’d say that both pickups have equal volume, but with the balance pot in the mid position the volume drops to about half ... it’s really unusable. | ||
| Kev100 |
Joined: October 2019 Posts: 21 | Hi again, just found an online manual, which says that in the middle position, ‘both pickups are heard equally’ ... http://www.ovationtribute.com/Catalogues/60%27s_Ovation_Thunderhead... On mine there’s definitely a drop in volume towards the middle position. I guess the only way to be sure is to take the pot out and maybe find a replacement. Kev | ||
| Mr. Ovation |
Joined: December 2001 Posts: 7247 Location: The Great Pacific Northwest | The three-way switch is "in-phase, out-phase, and mute. Is it working correctly? Those (if original) are single-coil pickups so there really shouldn't be a huge drop in the middle, but I'm thinking if that switch is messed up, or been re-wired that might cause an issue. Anyway, check it out. If that's not the issue, I would pull the pickups and you can usually get tuner-cleaner to the pots via a thin straw from the pickup opening. Make sure all wires are secure. | ||
| Kev100 |
Joined: October 2019 Posts: 21 | Thanks for the suggestion. The switch works as it should, but to be fair, it and the pots could all do with a clean. I’ll check it out. If it comes to it, though, any idea where I can get a replacement pot? Kev | ||
| Mr. Ovation |
Joined: December 2001 Posts: 7247 Location: The Great Pacific Northwest | The pots are pretty standard as I recall. I have a couple of complete looms I think... the thing is... "dirt" doesn't generally cause what you describe which is more faulty connection sounding. | ||
| Kev100 |
Joined: October 2019 Posts: 21 | Thanks everyone, good to know that my guitar isn’t as it should be. I’ll investigate further. I don’t suppose anyone’s got a wiring diagram for the thunderhead? | ||
| Old Man Arthur |
Joined: September 2006 Posts: 10777 Location: Keepin' It Weird in Portland, OR | Kev100 - 2021-02-22 12:10 AM Thanks everyone, good to know that my guitar isn’t as it should be. I’ll investigate further. I don’t suppose anyone’s got a wiring diagram for the thunderhead? http://www.ovationtribute.com/Ovation%20Schematics/Ovation_Thunderh... | ||
| Kev100 |
| Kev100 |
Joined: October 2019 Posts: 21 | Okay, sit rep time. I spent a fair chunk of the morning disassembling the guitar, checked all soldered joints (amazingly all okay) and switch cleaning the pots and selector switch. Got it all back together again (fairly easily) and put new strings on. No crackles and drop outs when using the pots, and the switch is perfect. However, there's still a dip in volume mid way through the balance put sweep. I downloaded a decibel meter app onto my phone and repeatedly plucked the G string whilst sweeping the balance from neck to bridge. With the particular volume setting I was using, there was a drop of around 10dB at the mid point (in both in-phase and out of phase). In the region of 68 - 58-68 dB. Can someone with one of these guitars try this experiment and let me know if my (admittedly non-scientific) results are typical and normal for the Thunderhead, in which case I can stop chasing ghosts, or maybe I do in fact have an issue. I used Sound Meter on Android, but I guess the effect, if present, should show on any app/device. Cheers, Kev | ||
