OP40 vs. Others
nervous
Posted 2009-10-31 4:22 PM (#392802)
Subject: OP40 vs. Others
May 2009
I did a quick search but don't find much info on the OP40 preamp. What's the lowdown on these, likes and dislikes? How are they vs. say the newer Op-Pro, Studio etc? Tuner good? Output good? Sound good? Idiosyncrasies? Do they need to be 'plugged in' to tune? Thanks.
nervous
Posted 2009-11-01 10:06 AM (#392803 - in reply to #392802)
Subject: Re: OP40 vs. Others
May 2009
No love for the OP40?
Posted 2009-11-01 12:16 PM (#392804 - in reply to #392802)
The OP30 was a major step forward and the OP50 is my favorite along with the OP PRO Studio and the Optima.
The OP40 is just a transition between the 30 and 50 so it is easily overlooked.
I like the OP's much more than the OP24 series.
Fridave
Posted 2009-11-01 12:29 PM (#392805 - in reply to #392802)
February 2008
OP40- tuner is good, doesn't need to be plugged in, vol bass mid treble sliders, eq on/off, eq preshape, notch filter w/ variable control. My 1717 Legend has an op40 and I like it. op50 is similar but with two midrange sliders.
Gallerinski
Posted 2009-11-01 5:08 PM (#392806 - in reply to #392802)
How in the hell can ovation make an OP40 tuner that works normally (don't have to plug in) and on the others they force you to plug in. Yet if you leave it plugged in you drain the battery. I am 100% baffled by the logic.
Posted 2009-11-01 8:38 PM (#392807 - in reply to #392802)
Committee designed during the New Year's party? Or maybe on April 1st?
Curious 'bout the 'logic'...
Posted 2009-11-01 9:39 PM (#392808 - in reply to #392802)
It's all about the power consumption Dave.
Now if they could incorporate some solar panels to suck up the stage lights or a Magneto with matching wrist band to generate power from the strumming motion then we'd have something!
For now, I just Wet-Willie the XLR jack.
Gallerinski
Posted 2009-11-01 11:02 PM (#392809 - in reply to #392802)
You're right, but that's because it's a shitty design. You should be able to push a "tuner" button and activate power to only the tuner circuitry, which draws almost nothing.
Posted 2009-11-01 11:09 PM (#392810 - in reply to #392802)
All of which is why I prefer the OP Pro over the other "better" OP designs. It may not be as powerful, but it's simple and the tuner works on demand....
Posted 2009-11-02 12:17 AM (#392811 - in reply to #392802)
Don't under stand the rant...only time I need to plug in or use a dummy plug is the VIP.
Not OP-50, Op-Pro, or Studio.
Not sure if the problem is still in the newer VIP's.
Auriemma
Posted 2009-11-02 8:13 AM (#392812 - in reply to #392802)
October 2008
Tony is right. The Pro and Studio are switch activated. No dummy plug needed.
