Help with microphone
| dobro |
Joined: January 2006 Posts: 2120 Location: Chicago | What do the switches on my AKG 3000 B represent? What do they do? They are labelled: "0 db / -10 db" and "lin" | ||
| dobro |
Joined: January 2006 Posts: 2120 Location: Chicago | I think I need a translation of this alien language: "Due to its surface area and special capsule tuning, the C 3000 B large-diaphragm transducer produces an exceptionally pleasing, smooth sound. An improvement over the original mic, the C 3000 B's switchable -10dB preattenuation pad immediately follows the transducer in the signal path, thus increasing the C 3000 B's SPL capability by a true 10dB. Loud sound sources are therefore no problem. An acoustically optimized cardioid polar pattern makes the C 3000 B an excellent choice for both recording and live sound applications where high gain before feedback is important." | ||
| FlicKreno aka Solid Top |
Joined: April 2006 Posts: 2491 Location: Copenhagen Denmark | Gregg , The minus 10db is simply an attenuator that lowers the sensitivity of the mic., so that it can withstand high volume levels, in case you want to mike -up a loud guitar amp. or trumpet etc. for acoustic guitar set it to zero db , the surface -area and capsule tuning describes what they did to improve it , Cardioid pattern covers an particular area where one can move in any direction and still gets picked up well , for more info , check here : http://www.crownaudio.com/mic_web/tips/mictip2.htm capable for both recording and playback indicates that it is not very prone to feedback. LIN means Linear , ( full frequency range ), otherwise a bass -filter is engaged , rolling off from 500 Hz.downwards with 6db octave . It is interesting to note that it is an ELECTROSTATIC Mic. Very Nice !! 3 db equals twice as much 6 db ,, ,, four times 9 db ,, ,, eight times 10 db about ten times Vic ..AKG C 3ooo B is a great mic. | ||
| dobro |
Joined: January 2006 Posts: 2120 Location: Chicago | Thanks so much, Vic. Another question: Jeff's dedicated digital recorder has only ONE input. I'd like to mix piezo with my AKG. We have the use of a Mackie mixer (Mackie DFX 12 12x2 I think)but can't make sense of the board. Have you ever used such a device? If so, any pointers on blending the AKG C 3000 B with piezo direct through the Mackie. Last Friday we tried and all we got was sh***t. I personally would like to have a little "air" around my Ovation sound.... | ||
| dobro |
Joined: January 2006 Posts: 2120 Location: Chicago | Jeff: if you're reading this maybe you could enter some of the labels and numbers on the face of the mixer so that we can make some progress.... BTW is it a Mackie DFX 12 12x2 Mixer as I claim? | ||
Joined: April 2006 Posts: 2491 Location: Copenhagen Denmark | Gregg, Did you mean No sound at all , or Bad sound ?.. The C3000B requires phantom power, ( 9 to 52 volts ) 48 volts would be good ,if the mixer does not supply phantompower, than either aquire an auxiliary 48 volts power supply or aquire a mic. pre -amp, The Best solution ( imho ) this one I have myself : http://www.artproaudio.com/products.asp?id=1&cat=1&type=79 This one you might be more interested in , it has a few more possibilities http://www.artproaudio.com/products.asp?id=58&cat=1&type=79 the studio V3 retails for about 70 dollars , it might just be the answer you seek :) Vic ..they fit any mixer.. | ||
| alpep |
Joined: December 2001 Posts: 10583 Location: NJ | the art stuff is cool but be careful they blew out a pile of the older stuff about a year ago so check your prices if you buy used. | ||
Joined: April 2006 Posts: 2491 Location: Copenhagen Denmark | Originally posted by alpep: Ah , Never buy such one used , there`s a radio -valve in it , that was the price for a new V3 , are you selling these Al ? the art stuff is cool but be careful they blew out a pile of the older stuff about a year ago so check your prices if you buy used. Vic | ||
| dobro |
Joined: January 2006 Posts: 2120 Location: Chicago | Very helpful. Jeff has an older Boss dedicated recorder that may somehow participate in the problem. I'll have to ask him what the exact model is and what the Mackie mixer "specs" are. We got VERY weak sound, not at all the HOT results I was accustomed to hear from the AKG at home... | ||
| dobro |
Joined: January 2006 Posts: 2120 Location: Chicago | The Mackie mixer provides phantom power. Do I still need to look into the pre-amp option, I wonder? | ||
Joined: April 2006 Posts: 2491 Location: Copenhagen Denmark | Originally posted by dobro: Gregg, The Mackie mixer provides phantom power. Do I still need to look into the pre-amp option, I wonder? Yes , I would still recommend the Studio V3 , first : A pre -amp. will boost the signal ,there is a Level control , and with that , the Mic.`s signal can be boosted , if that is not enough , than there`s a button that boosts the signal even more , Much More !!.. by 20 db ..more than 70 times !! Enough to blow the heaviest metal rocker into Distortion Nirvana ( doubt if you have that need ) :) Phantom power can be switched On/Off . It has a Phase reverse button , can be useful to adjust Mic./Instrument with the rest. Output level ( Volume control ) with a cool -looking meter to aid you in staying away from " clipping " , a type of distortion that scares even deadmetalheads . It incorporates a radio -valve , many ( including myself ) like the sound of a valve in a well -constructed pre -amp. ,especially , when used in conjunction with digital equipment . Yet , what really is Useful ( Important ) is it`s " voicing knob " , with that , you will be able to alter the sound significantly , the difference between a so-so sound or " oochy mama " ... :) Look , you can buy yer`self poor in purchasing pre -amps., there are those that costs several thousand dollars , but for what you have in mind , I would say , that`s the one !! I `ve got the MP -1 ( the smaller model ), have used it for over a year , works flawlessly , Longevity seems to be no problem , They are known to make Good and Reliable stuff. I am not connected with A R T , But ...I am connected with the OFC , so ,check with Al , maybe he can cut ya a good deal :) Vic ..the OFC..where -ever particular people connect.. | ||
