Non-slip friction patch
| DaveKell |
Joined: November 2011 Posts: 741 Location: Fort Worth, TX | That's as close a description as I could come up with for what I'm looking for. While I have an extreme reluctance to apply any type of peel and stick device to my gorgeous Balladeer, I would like to be able to play it sitting without needing to wear the strap because of its tendency to slip in my lap. So does anybody know where to acquire one? I searched on eBay for every conceivable combination of keywords pertaining to it with no luck. A link to a supplier would be most appreciated. | ||
| CanterburyStrings |
Joined: March 2008 Posts: 2683 Location: Hot Springs, S.D. | OK, I'll give it a go... If you do a search you will see that this has been discussed many times. There are lots of things people have tried, from a device especially made for this purpose, to those non-slip pads on a roll that you can buy at any store. (usually in the kitchen section - some people use it as shelf liner.) But the best advice I could give you is just learn to sit differently, and stop pressing on the lower bass bout with your right arm - not only does it cause your guitar to slip, but it kills the sound. | ||
| schroeder |
Joined: November 2004 Posts: 4413 | Just hold it properly. | ||
| bauerhillboy |
Joined: February 2004 Posts: 1634 Location: Warren,Pa. | I use 3M stair tread. I cut a curve all the way around except for the edge that runs parallel to the top binding. It's nearly unnoticeable and works perfectly. It comes in different widths; I get the widest one and cut it to the desired shape (with my wife's best sewing scissors, of course). I know you're reluctant to "stick" anything on your guitar, but it really is almost invisible and works better than anything else. | ||
| Mark in Boise |
Joined: March 2005 Posts: 12762 Location: Boise, Idaho | I used to say, "just lose some weight", but since Thanksgiving and two Christmas parties, I need to take my own advice. I still don't have any problem with any of the deep bowl Ovations, though, even though my own bowl is now inverted. | ||
| DaveKell |
Joined: November 2011 Posts: 741 Location: Fort Worth, TX | But the best advice I could give you is just learn to sit differently, and stop pressing on the lower bass bout with your right arm - not only does it cause your guitar to slip, but it kills the sound. I honestly don't grasp how pressing on the lower bout can be avoided, but I must be accomplishing it somehow as my sound rings like a bell. My waistline isn't a problem either. I was under the impression there was an actual product of this nature made for/by Ovation to alleviate slippage. Guess I was wrong. | ||
| TAFKAR |
Joined: April 2008 Posts: 2985 Location: Sydney, Australia | Dave, There is a thing called a Standing Ovation, which forces the guitar more upright. However, I do support the "hold it properly" crowd. The Standing Ovation basically forces this posture (as do the contour bowl Ovations). Is your upper leg parallel with the floor? If not, rest your foot on something - classical guitarists have a special little footrest, but a phonebook will work just as well. Is the face of the guitar perpendicular to the floor? If not, this is the main reason for slippage (IMHO), and is the point other posters made about leaning on the upper bout. If you can see the fretboard when you're playing, you're tilting the guitar back. This also makes your left hand action more awkward. | ||
| Nordicnorm |
Joined: May 2010 Posts: 95 Location: Vancouver Island, BC | PM sent | ||
| hwebster |
Joined: June 2005 Posts: 497 Location: California | I use 3M stair tread also. If want to see pictures let me know. They work great. | ||
| stephent28 |
Joined: April 2004 Posts: 13303 Location: Latitude 39.56819, Longitude -105.080066 | I know a few years back there was a product specifically for the Ovations. It was talked about in several threads and if you do an exhaustive search I am sure you can find the original thread with the name etc. Seems to me that several of us received samples of this product for free. | ||
| Nordicnorm |
Joined: May 2010 Posts: 95 Location: Vancouver Island, BC | They are called "Slip-Grip". P.O. Box 356 Oakmont, PA 15139 Helped my super shallow 12 + the little Trekker sit a little more securely on my thigh. They are suede leather/adhesive backing. You have to search d'bay to find them. They usually show up in the last pages when I search "Ovation Guitars". No web site. | ||
