Finishes and Stands
| willard |
Joined: November 2002 Posts: 1300 Location: Madison, Wisconsin | The following was on a tag from a new stand I aquired this weekend. Attention: Can anybody tell me what kind of finish Ovations have and just what is a Nitro Cellulous Lacquer Finish.Not Recommended for Guitars With Nitro Cellulous Lacquer Finish. The Material of Foam Might Cause Unexspected Chemical Reaction That May Deteriorate The Finish | ||
| jb |
Joined: December 2004 Posts: 370 Location: Isle of Man, UK | If I'm right, I believe that the gloss finish on (e.g.) a Fender Strat/Tele is nitro-cellulose lacquer. I hold up my hand to pure ignorance of the Ovation finish, though. Having said that, I don't think it would affect an O as all the lacquer and finishing is on the front, away from the stand. JB | ||
| ChatMan |
Joined: August 2004 Posts: 604 Location: Tampa, FL | Ovations' have a catalyzed polymer finish that is impervious to just about about anything ('cepting maybe finish cracks ;) ) and therefore pretty difficult to fix when it gets marred. In balance, it's kind of hard to mar in the first place. Nitro cellulose I believe is what you find on Martins' and similar. It is susceptible to just about everything, but when damaged, is pretty easy to fix. A little perspiration is enough to give you a hazy finish. | ||
| schroeder |
Joined: November 2004 Posts: 4413 | Nitrocellolose is what you get on expensive acoustics. It's time consuming to apply (coat, rub down, coat, rub down and on and on)and to repair, though not difficult. | ||
| edzep |
Joined: December 2005 Posts: 111 | Good one, Willard! I was about to ask this very question, having bought an $8 made-in-China stand from Musician's Friend, with the same tag. I'm getting a Legend LX, which has the laquer finish on the neck, which would contact the neck support pad. I had been considering where to pick up different kinds of tubing, or cotton wrapping, etc. From replies by jb, chatman and schroeder, I guess we have no worries. Thanks, guys. | ||
| jb |
Joined: December 2004 Posts: 370 Location: Isle of Man, UK | Mark your calendars, guys - I finally helped someone!! Only 14 months into my membership of the site. Who'd have thunk it! Cheers, edzep! JB | ||
| willard |
Joined: November 2002 Posts: 1300 Location: Madison, Wisconsin | Mine is a Musician's Friend stand as well. A friend of mine meant to buy 4 and ended up with 6. For $10, I couldn't pass it up. I looked all over the thing and couldn't find a "Made In" sticker. Not even on the box. It's one of those short kind without the neck support. | ||
| Cc |
Joined: March 2003 Posts: 195 Location: Colorado Springs, Colorado | One of the guitar shops here in town used wall hangers with foam supports on some higher end used guitars. They were shocked to find the foam had eaten into the neck finish of some very expensive axes. I had a "body guard" on one of my Jazz Basses for years without any problem till I moved to the coast. In a matter of weeks the foam had deteriorated and ate the finish all around the edges of the bass. I was pretty sick about it. I have heard the rubber like surgical tubing is pretty safe. Cc | ||
| edzep |
Joined: December 2005 Posts: 111 | Surgical tubing is a pretty good idea, regardless of laquer type. Now, where does one find thick-wall surgical tubing with inside diameter arount 5/16 inch? | ||
| MWoody |
Joined: December 2003 Posts: 13997 Location: Upper Left USA | Find a variety of surgical tubing at most "Hard Core Fisherman" meccas! It is used as snubbers. | ||
| Standingovation |
Joined: June 2002 Posts: 6202 Location: Phoenix AZ | This scuba shop has all different sizes. http://www.reefscuba.com/surgical_tubing.htm | ||
Finishes and Stands
