has anyone made some bridge spacers?
kensmith
Posted 2006-08-14 2:46 PM (#244409)
Subject: has anyone made some bridge spacers?
Been adjusting the action on my new 6778LX and down to ONE of the thicker spacers. I am fearful that if I swap that out for the thinner spacer, I may get into buzz territory. What I will likely need is some thinner options to fine tune the action. Since I don't have a cnc maching handy, does anyone have recommendations on material and process for handcrafting some homemade spacers? I assume that any hard material will suffice (similar to the pcb board type material in the stock spacers, and I aslo assume that I want NO taper and that it should be EXACT shape in order to fully seat the bridge/pickup to the guitar top.
thanks!
Mitzdawg
Posted 2006-08-14 2:53 PM (#244410 - in reply to #244409)
Subject: Re: has anyone made some bridge spacers?
July 2004
I have made shims out of brass shim stock - easy to mark and can be cut with scissors. Just don't run when cutting.
Posted 2006-08-14 3:07 PM (#244411 - in reply to #244409)
Fearful? Just take it out and try a different combination of thick and thin spacers. Give the truss rod a little tweak.
I suppose you could clip out a piece of a beer can.
gh1
Posted 2006-08-14 3:52 PM (#244412 - in reply to #244409)
Credit cards. Junk mail provides a bunch of these in varying thicknesses.
_____
gh1
Posted 2006-08-14 4:04 PM (#244413 - in reply to #244409)
call the service department they will send you some. if you don't get through call me I have some sitting on my computer desk
kensmith
Posted 2006-08-14 5:15 PM (#244414 - in reply to #244409)
Thanks Al, I had actually not thought of that. Are there only 2 thicknesses of spacers? There were 2 sizes that came with my LX. One is a thinner dark brown one, and a thicker lighter tan colored ones. I only have 1 of the thinner ones, and perhaps 2 of those would be less than the thick (beige) one that is in the guitar now.
thanks again!
Ken
bauerhillboy
Posted 2006-08-14 8:03 PM (#244415 - in reply to #244409)
Ken,
I have the same guitar AND had the same situation. I took out all the shims and the action was just perfect for me with no buzzing, BUT the break angle was so shallow that tone really suffered. I actually sent it back to the factory where they changed the neck angle (and installed XLR).
Now I have 1 thick shim and 1 thin shim...and everything is just perfect.
So check out that break angle. John <>{
Old Applause Owner
Posted 2006-08-14 11:01 PM (#244416 - in reply to #244409)
July 2003
I use styrene plastic strip stock by Evergreen Scale Models in thicknesses of .010", .020" and .030" from a well-stocked hobby shop. Buy the width just under what you need in those thicknesses, cut to length and add shims made that way to get the thickness you need. Has worked fine for me.
Roger
kensmith
Posted 2006-08-15 12:21 AM (#244417 - in reply to #244409)
John,
I am not a guitar setup expert...can you explain more about break angle?
thx
EDIT:
I actually found this page, very helpful that describes this for me. It does not show an "O" but I assume concept is same.
http://www.frets.com/FretsPages/Musician/Guitar/Setup/Saddle/saddle...
kensmith
Posted 2006-08-15 11:27 AM (#244418 - in reply to #244409)
I emailed the service department and they are mailing me some of the thinner spacers out. How easy was that? Thanks Al!
Ken
p.s. if that doesn't work I will cut up some credit cards....2 birds with one stone!
TimG
Posted 2006-08-18 1:51 PM (#244419 - in reply to #244409)
My guitar tech made some thin ones from what I assume is mylar (like those shiny balloons). He didn't like the thick one that came installed.
