heavy sounding E string
stuart_guitar
Posted 2002-08-23 4:04 AM (#218914)
Subject: heavy sounding E string
When I plug in my ovation,
the bass of the E-string sounds very heavy,
compered to the A and D-string.
Does anyone have this problem also or is it supposed to be like this.
I didn't play a lot when i'm pluged in.
Stuart\'s Guitar Site
Posted 2002-08-23 5:50 AM (#218915 - in reply to #218914)
Subject: Re: heavy sounding E string
Which type of pickup is it?
stuart_guitar
Posted 2002-08-24 5:09 AM (#218916 - in reply to #218914)
My guitar is 1996-TPB model with a High-Z Pickup.
I don't know what a High-Z Pickup means,
but that is what I've seen in the information.
Do you perhaps know what it means?
Posted 2002-08-24 5:20 AM (#218917 - in reply to #218914)
What's the model number of the guitar?
[ August 24, 2002: Message edited by: Paul Templeman ]
stuart_guitar
Posted 2002-08-24 9:13 AM (#218918 - in reply to #218914)
model 1996-TBP and serial 156
Posted 2002-08-24 10:37 AM (#218919 - in reply to #218914)
If your guitar has the original wide Ovation pickup & you are having string imbalance problems it's probably down to a faulty pickup, the Original Ovation bridge pickup unit is usually exceptional in terms of string to string balance. Email the factory to find a local service centre or the official distributor for the Netherlands.
stuart_guitar
Posted 2002-08-24 11:00 AM (#218920 - in reply to #218914)
Thanks Paul,
i'll go to my dealer.
I've read that you are a walking encyclopedia :D
Maybe you have some more information about my guitar?
Posted 2002-08-24 8:57 PM (#218921 - in reply to #218914)
If your guitar is a '96 collectors edition, I seem to remember that this guitar had the Hex-fx stereo pickup/preamp system. I don't know a great deal about this pre except that the output of each string is fed to the pre separately & various combinations of strings can be panned across the stereo field. If the pre isn't adjusted properly it may explain why you have a hot E-string. It could well be the pickup at fault as I suggested, but in the original Ovation stereo preamp each set of 3 strings had a trim pot and it could be that there are individual trim-pots for each string in the Hex-fx pre. Check with the factory.
stuart_guitar
Posted 2002-08-25 5:58 AM (#218922 - in reply to #218914)
Yes, My guitar is a '96 collectors edition,
and it has the HexFX stereo pickup/preamp system. So it must be the trim-pots for the E- string.
Thanks..
Posted 2002-08-25 6:15 AM (#218923 - in reply to #218914)
I'm making an educated guess here & may well be wrong, so have it checked.
Paul
luthier444
Posted 2002-08-26 3:57 PM (#218924 - in reply to #218914)
The hex fx pickup is made by shadow. It has individual crystals for each string so you can set the stereo accordingly. Six separate wires as well. It sounds like a bad pickup or the pickup isnt sitting flush on the bridge. They flex so the pressure may vary. Make sure you dont have a half ass shim uder it.
[ August 26, 2002: Message edited by: luthier444 ]
