Worth it to replace preamp?
foyle
Posted 2007-02-25 4:59 PM (#113418)
Subject: Worth it to replace preamp?
February 2007
I contacted Ovation about replacing the pre-amp on my Elite Standard to a newer one, preferably with a built in tuner. My Elite has the OP-24 preamp, which sounds fine to me but I would like to have a built in tuner. Ovation said they can do it at the factory, so considering shipping costs I am now thinking it is not worth it. Anyone else replace pre-amps on their Ovations? If so, is it worth it?
thanks
Posted 2007-02-25 5:23 PM (#113419 - in reply to #113418)
Subject: Re: Worth it to replace preamp?
if you want the built in tuner then it is worth it. otherwise buy another guitar and have a spare.
bauerhillboy
Posted 2007-02-25 8:22 PM (#113420 - in reply to #113418)
See if they have any more Op-24+C's in the service dept. Same as yours with a tuner. You ought to be able to do the work yourself with a little coaching from folks here. John or Kim might even talk you through it on a phone call or 2.
John <>{
Posted 2007-02-25 8:41 PM (#113421 - in reply to #113418)
I like the philosophy. That just makes good sense :)
Posted 2007-02-25 8:47 PM (#113422 - in reply to #113418)
ditto that.
Posted 2007-02-25 8:57 PM (#113423 - in reply to #113418)
If all you want is the benefit of a tuner, just buy a tuner. If you're doing live (plugged in) work, the boss chromatic tuner pedal $90. works well as a pass through between your guitar and amp/board. Dave
Goober
Posted 2007-02-25 9:09 PM (#113424 - in reply to #113418)
January 2004
Buy a new guitar from Al. :D :D :D
foyle
Posted 2007-02-25 9:41 PM (#113425 - in reply to #113418)
February 2007
Dont get me wrong, I like having a reason to buy another guitar, any idea how much it will cost to replace the pre-amp? Ovation's email says it has to be done in the factory.
BTW, I have 3 tuners, 2 that attach to the guitar, one is the intellitouch PT1. great tuner but a bit of an appendage on the Elite. A friend had a Martin with built in tuner, I thought the built in was more accurate and it was nice to just look down and tune away. (I like open tunings, so at times I change tunings often)
Jason_S
Posted 2007-02-25 9:58 PM (#113426 - in reply to #113418)
i think the onboard tuners that are in the pres are seiko but i could be wrong....i verry rarely play plugged in and my ovations are direct out of have fet pre's so i cant give a opinion on the onboard tunners....ive got a couple of clip on's and a nice strobe stomp box tuner.......just my 2 cents worth...jason
Posted 2007-02-25 10:08 PM (#113427 - in reply to #113418)
I was gonna say to get a clip-on, or an inline plug-in. I'm thinkin' that a plug-in is affected by the EQ setting, maybe. The clip-on may be more true.
But you REALLY want a built-in, so your choices a an OP-24+C, or a whole new guitar! That new Ultra looks nice... (that way we can get a true review)
