Need help wiring output jack
Randy22
Posted 2007-06-25 11:27 PM (#94612)
Subject: Need help wiring output jack
April 2003
Hi! I just got a '93 1860 (FET3 preamp), and it's missing the jack. I need to know where the 3 wires attach; there's the shield, a black wire and a red wire. I'm sure the shield will go to the sleeve, so I need to know which wire goes to the tip and which wire goes to the switching connection.
Is this making sense? I bet Jason would know.
keven
Posted 2007-06-26 8:28 AM (#94613 - in reply to #94612)
Subject: Re: Need help wiring output jack
I just finished wiring up a reverb spring tank to a stereo headphone preamp; (also working on adding a blend control to balance between the guitar reverb(wet) with the dry guitar output).
Anyway, the red wire(+) should go to the tip(+).
Do you have a third-connection on the socket for turning off the battery power when the plug is removed? Might want to consider having it wired up with that, too?
Posted 2007-06-26 8:45 AM (#94614 - in reply to #94612)
I have no idea how they keep all the electrons and mojo inside the fence but here's a Plan view of the corral.
Posted 2007-06-26 9:01 AM (#94615 - in reply to #94612)
". .I have no idea how they keep all the electrons and mojo inside the fence . ."
It's all FM.
Posted 2007-06-26 9:42 AM (#94616 - in reply to #94612)
The ranch hands are all cosmic cowboys.
Joyful Noise
Posted 2007-06-26 11:02 AM (#94617 - in reply to #94612)
Just don't let the magic smoke escape!
Thanksforallthefish
Posted 2007-06-26 11:17 AM (#94618 - in reply to #94612)
usually means the bad jin has awakened.. :(
Glenn
Randy22
Posted 2007-06-26 3:13 PM (#94619 - in reply to #94612)
April 2003
Yes Keven, I have a jack with a switching connection. I've tried red to the tip and black to the switching, and vice-versa with no success. I'm not sure of the wiring order though, and hoped someone who had actually done one of these would chime in.
BruDeV
Posted 2007-06-26 4:08 PM (#94620 - in reply to #94612)
Shield goes to the two inner lugs.
Black to outer left lug.
Red to outer right lug.
If you don't have this type contact the factory.
1-800-552-4681
Randy22
Posted 2007-06-26 5:45 PM (#94621 - in reply to #94612)
April 2003
Thanks for the quick reply! I have an older jack, and John Budny is sending me a new one. I'll double check my solders to make sure they aren't sloppy and shorting across. Or maybe my older jack is bad.
