Location: NJ | took in a pile of stuff over the past few weeks and I am looking to purge some old to make way for the new.
Interesting trades welcome.
peavey m 3000 power amp. stable reliable peavey goodness $150
Pryamid pa600x power amp
Speaker Switch: The PA-600X features a switchable speaker option. By depressing speaker switch A the speakers on channel A will become operational. Speaker switch B operates speakers hooked up to channel B. For full stereo operation both switches should be depressed. Output Level Gain Controls: There are 2 separate output level gain controls. The left knob controls the gain level of amplifier channel A and the right gain level controls channel B. The unit can be rack mounted or table top mounted. The PA-600X has built-in pure aluminum heatsinks to help dissipate heat build up from the integrated circuits inside.
Specs
Continuous Power Output (both channels driven):
20 Hz to 20 KHz: 300 watts per channel (8 ohms)
1 KHz: 600 watts per channel (4 ohms)
Total Harmonic Distortion: 0.1% at rated power (8 ohms)
Frequency Response: 10 Hz to 50 KHz ± 3dB
Input Sensitivity: 1 Volt for 70 watts at 8 ohms
Input Impedance: 47 Kohms
Signal to Noise Ratio: 90dB (A-weighted)
Speaker Impedance: A, B, A + B (4 - 16 ohms)
Power Requirement: AC 115V / 230V switchable
Power Fuse: 6A / 115V or 3A / 230V
Dimensions: 480(W) × 100(H) × 273(D) mm
$125
Carvin dcm1000 1000 watt power amp
DCM1000 Power Amp
1000W bridged 4 ohms, 700W bridged 8 ohms.
• Continuous RMS per CH: 8 ohms 225w, 4 ohms 300w, 2 ohms 500w.
• Not rated "pulse power" or at 2 ohms for a few minutes like some amps
• THD 20-20kHz @ rated 90% output: 0.1%, 50% ouput 0.03%.
• High transparent 45v/us slew rate. Studio quality 100 dB S/N ratio.
• INPUTS: 1/4" balanced and female XLR balanced.
• OUTPUTS: 5-way binding post, Speakon(tm) and two 1/4".
• Switches: limiters, ground lift, paralleling inputs, bridge mode.
• Recessed level attenuators, clip, signal, protect and power on indicators.
• Soft-start, DC SpeakerGuard(tm), thermal and short circuit protection relays.
• Variable speed fan. Heavy-duty all steel construction.
• Dynamic low frequency punch with transparent high-end for uncolored sound.
• 2U rackmount 3.5"H x 10"D x 19"W, WT: 25 lbs.
excellent condition lots of bang for the buck.
$250
phase liner 400 yup you know what these are it works great and is in excellent condition. ONe of the best sounding solid state hi fi amps I know.
$250
wood cabinet for the phase linear 400 700b or 4000
good condition some minor scratches and dings $85
phase linear model 5100 series two digital synthesized tuner. I should keep this but I have too much stuff. $150
Phase linear turntable $150
Dynaco ST 150
classic made in Blackwood NJ hi fi power amp. Wood sides some minor scratcher etc. 75 watts per channel
$175
Phase liner 4000 series two peramp. great classic hi fi sound.
$200
harman kardon hk 300xm cassette player $40
harmon kardon linear tracking turntable. Not sure if I want to let this go. catch me in a weak moment
bsr real time spectrum analyser model sa-3x $50
asr systems parametric octave band eq eq-10 it works $50
e me at alpep@lostartvintage.com if you have any interest or have something to swap
thanks |
