Guitar Mics
Tim in Yucaipa
Posted 2005-03-22 5:15 PM (#158408)
Subject: Guitar Mics
I know this has probably been done to death, and I could do a Search, but I'm feeling lazy just now....so...
what's the best mic for a guitar/banjo stage mic?
...I know, I know, but sometimes it's just easier to do the mic thing rather than the plug in thing, especially when switching from banjo to guitar to banjo to guitar to banjo ......
Posted 2005-03-22 5:20 PM (#158409 - in reply to #158408)
Subject: Re: Guitar Mics
Tim,
Prepare yourself for the onslaught of cracks about how banjos should not only never be mic'ed, but....
Tim in Yucaipa
Posted 2005-03-22 5:23 PM (#158410 - in reply to #158408)
....just put all the cracks where they belong, in the crack pot....
Posted 2005-03-22 5:48 PM (#158411 - in reply to #158408)
I don't know if it is the best..probably not, but the fella that provides the sound equip for our little Bluegrass/Old Time jam uses both Shure Sm57 and Beta 58. They sound great and hold up well. He owns a successful pro recording studio and is the engineer, so I assume he knows what he's doing.
Tim in Yucaipa
Posted 2005-03-22 5:52 PM (#158412 - in reply to #158408)
...Thanks Jeff,
I've been looking at the Shures and the AKG C1000s....
....other advice????
Posted 2005-03-22 5:56 PM (#158413 - in reply to #158408)
If you must use a mike for live work a small diaphragm condenser mike is generally regarded as the best bet for acoustic guitar. Suitable affordable examples include the AKG C1000s & the Rode NT2, both of which can operate on phantom power or an internal 9volt. My preference would be for the Rode as it's externally-biased whereas the AKG is a back-electret type, though they sound pretty similar. I'm tempted to offer a few banjo gags but I'll resist and simply add that as the banjo is significantly louder & brighter than most acoustic guitars the extended sensitiviity, frequency response & output of condenser mikes becomes less of an issue and consequently a reasonable dynamic mike, such as a Shure Beta57A will work fine. If you need a single mike to cover as many bases as possible go with a condenser.
Posted 2005-03-22 6:04 PM (#158414 - in reply to #158408)
Tim,
I think he also uses a couple of condenser AKCs. Not sure of the model number, but I know they are kinda high-end. They are silver and have a uniform diameter from one end to the other. I know, highly technical description...I look the AKC up in a catlog to see if I can find the model...
Tim in Yucaipa
Posted 2005-03-22 6:06 PM (#158415 - in reply to #158408)
Thanks Paul and Jeff,
When I play the (gasp) banjo, I step back from the mic I use now unless I really need the boost, but I want to be able to pick up the nuances from my 2001 Redwood as well (close in to the mic)... the condensers seem like the best of both worlds...
...and I am really proud of you all for your astonishing restraint....
...how many banjo players does it take to change a light bulb...?
...none, they couldn't decide how Earl would have done it!
...there, feel better??? :D :rolleyes:
Posted 2005-03-22 6:09 PM (#158416 - in reply to #158408)
Nevermind...Pauls got it covered...
Posted 2005-03-22 6:47 PM (#158417 - in reply to #158408)
"...none, they couldn't decide how Earl would have done it!"
Gotta friend who has a banjo in need of some TLC. He is going to give to me as a starter.
Good thing I live alone way deep in the woods.
(Dueling Banjo tab here)
Posted 2005-03-22 8:08 PM (#158418 - in reply to #158408)
What do you call 20,000 banjo players at the bottom of the ocean??????
A GOOD START. :D
Just kidding. A condenser mic would be best. You can buy a single phantom power supply for around $40-$50. The Shure SM57 is also a good choice.
Tim in Yucaipa
Posted 2005-03-23 7:02 AM (#158419 - in reply to #158408)
....glub....glub....glub....thanks...glubbbbbbb
Posted 2005-03-23 7:17 AM (#158420 - in reply to #158408)
Tim;
You might also might wanna consider the re-issue of the Shure 55's. A combination of modern, stage mic technology that has that old-timey "look" that would compliment your banjo (probably the only "compliment" it'll EVER get! ;-)
I've got 3 of the original one's from the 50's/60's. The new ones have contemporary "works" in a retro-looking shell . . . .
Posted 2005-03-23 7:27 AM (#158421 - in reply to #158408)
"...The new ones have contemporary "works" in a retro-looking shell . . . ."
Not unlike Clifford himself...
Posted 2005-03-23 7:34 AM (#158422 - in reply to #158408)
I do what I can . . .
Tim in Yucaipa
Posted 2005-03-23 8:07 AM (#158423 - in reply to #158408)
...RetroCliff,
..how good are the Shure 55s for instruments? My image is tarnished far beyond restoration, even by a retro mic....
I seem to be staring at the AKG C100S for what I need....
Posted 2005-03-23 8:22 AM (#158424 - in reply to #158408)
". . ..how good are the Shure 55s for instruments? . ."
You could do better.
Tim in Yucaipa
Posted 2005-03-23 8:27 AM (#158425 - in reply to #158408)
AKG C1000S?...$149 at 8th ST. Music
Stevechapman
Posted 2005-03-23 9:11 AM (#158426 - in reply to #158408)
April 2003
Tim,
Akg C100 is a great choice . I use to own two and they were workhorses. and they should work fine since you aregoing to use them to mike an Instrument or two and$149 is a good price.
Tim in Yucaipa
Posted 2005-03-23 9:52 AM (#158427 - in reply to #158408)
tanks cuz
Posted 2005-03-23 9:56 AM (#158428 - in reply to #158408)
Originally posted by Tim Chapman:
...RetroCliff,
Part of the reason the SH55's sound the way they do is because the metal casing has a lot of mass and actually filters out the higher frequencies. So I wouldn't use them on acoustic instruments, except of course the banjo. Anything that will help push a banjo to the back of the mix has to be a good thing.
Posted 2005-03-23 10:36 AM (#158429 - in reply to #158408)
If it would push it off the stage altogether it would be even better. ;)
Then the ukes could step forward a little...
Tim in Yucaipa
Posted 2005-03-23 10:52 AM (#158430 - in reply to #158408)
...sigh...
Posted 2005-03-23 12:00 PM (#158431 - in reply to #158408)
But she doesn't really look THAT happy about it, does she?
Posted 2005-03-23 12:11 PM (#158432 - in reply to #158408)
I find Banjo players among the best natured folk...often a just knod and smile.
...course that could be cause they can't hear us over the pluckin'
TWA
Posted 2005-03-23 12:17 PM (#158433 - in reply to #158408)
Is the subtitle of that painting "Sweet City Woman"? :cool:
Posted 2005-03-23 1:13 PM (#158434 - in reply to #158408)
I thought this thread was about irish guitar players. Dave
Posted 2005-03-23 1:18 PM (#158435 - in reply to #158408)
:D
Posted 2005-03-23 1:21 PM (#158436 - in reply to #158408)
hmmmm . . . "Mr. Sensitivity" goes off on a tirade yesterday over ManBoobs, and then comes back today espousing ethnic slurs at an entire race of musicians . . . . . :-)
Posted 2005-03-23 2:31 PM (#158437 - in reply to #158408)
Just checking to see if you really read my posts. Dave
Posted 2005-03-23 2:47 PM (#158438 - in reply to #158408)
