K-Bar vs. Truss rod... Sound Altering?
Jeff
Posted 2005-05-24 4:55 PM (#149846)
Subject: K-Bar vs. Truss rod... Sound Altering?
I have two 1619 Custom Legends built two years apart: a 1981 with a traditional truss rod and "cloth" fiberglass bowl; and an '83 with a K-Bar and a "molded" bowl.
It seems, to my ears anyway, that the '83 produces noticably more bass response than the '81. The '83 also seems slightly heavier than the other. Would the extra weight of the K-Bar be the reason for the deeper bass, or is it the differences in how the bowls were made... Or a combination of both? Thanks.
Jeff
Stevechapman
Posted 2005-05-24 5:17 PM (#149847 - in reply to #149846)
Subject: Re: K-Bar vs. Truss rod... Sound Altering?
April 2003
The K-bar does add quite a bit of weight to the guitar, but also the bowls weer heavier then too. This was actually discussed during last years factory tour. When designing the LX, because of the lighter bowl they went to a redesigned neck with trussrod and graphite stabilizers. the reason was that the guitar too heavy on the neck end.Now not only are the guitars lighter in weight because of the neck system but because of the new bowls that reduce the weight by 33%.
Posted 2005-05-24 5:17 PM (#149848 - in reply to #149846)
Too many variables to say.
I would like to see some data from tests on the same models after 20-30 years to see how close they mature.
Does Ovation ever test "seasoned" guitars?
Posted 2005-05-24 5:25 PM (#149849 - in reply to #149846)
You just hit on one of the questions I was planning to ask.
Posted 2005-05-24 6:40 PM (#149850 - in reply to #149846)
It is my belief that the cloth bowl gives much more bass responce, that has much more to do with the sound than the K-Bar. The moulding compounds are slightly sound absorbing whereas the cloth is not.
My $2.02.
Posted 2005-05-24 7:07 PM (#149851 - in reply to #149846)
Jeff seems to say he hears the opposite on the 2 of his.
Mitchrx
Posted 2005-05-24 10:54 PM (#149852 - in reply to #149846)
I used to have both an '81 and '83 1619. My '81 sounded so much better than the '83 that I sold the '83. I don't know why it sounded better, but the difference was very apparent. I always thought that it was just the typical differences between individual guitars of the same make and model, and not a result of the bowl or neck construction. I find that the truss rod neck is a bit thinner and more comfortable to play.
Posted 2005-05-25 12:55 AM (#149853 - in reply to #149846)
Who cares about the sound, it's the LOOKS that matter. Ovations without TRC's look silly to me.
Mitchrx
Posted 2005-05-25 9:11 AM (#149854 - in reply to #149846)
Dave:
So where did you get all of those GC TRC's that you have on most of your O's?
Posted 2005-05-25 9:24 AM (#149855 - in reply to #149846)
He roots through Glen's trash cans at night . . .
Jeff
Posted 2005-05-25 9:42 AM (#149856 - in reply to #149846)
Dave, once again you've nailed it, little buddy! As Billy Crystal's "Fernando" used to say, "It is better to look good than to feel good (or in this case sound good)." I'm with you. I think the headstocks definitely look better with a TRC.
Getting back to the topic, I didn't mean to infer that one sounds "better" than the other. They both sound awesome just different, which is not necessarily a bad thing. I was just curious as to what, if any, bearing the K-bar might've had on the sound. I used to have a Legend Ltd. that also had the K-bar and molded bowl, and I found that it, too, produced a deeper bass response akin to my '83 CL. That's really what got me to wondering if there might be a connection between the K-bar and molded bowl combination and a deeper bass response.
Jeff
Posted 2005-05-25 10:01 AM (#149857 - in reply to #149846)
Yes, that's true. Among the J.D. bottles and Schlitz cans you can find hand fulls of truss rod covers ...
