Location: Ft. Lauderdale, Florida | Anybody have any good sources for a special sound card...
Low Low freq responce .33 Hz -> 22,000 Plus Hz
Also need help with Sonic Stage Mastering program that came with my Sony Vaio computer bundle...
AB |
jeez!!
You producing audio or testing seismic equipment?? |
Location: Earth·SolarSystem·LocalInterstellarCloud·Local Bub | trying to hit the "Brown Note" |
Location: Phoenix AZ | My card an m-audio 2496 with a descreet breakout box and m-audio audio-buddy for line balancing. The whole she-bang was about $450. Dave |
Thanks for the heads up... not quite .33 lo end...
I'm trying to reach some submariners in the Carribean...
AB |
Location: Toronto | I use an e-mu 1320 - which I find extremely excellent.
Now to get that low response hmmm... Well in my Signal Corp days, a Beta Record (yes, there was a practical use for Beta, not just Sony trying to be a bully). We could actually capture frequencie's lower than 3hz - but why you would want to is the question. I'm pretty sure humans don't hear anything under 20,000hz (or depending on your age, perhaps higher!!)...
Dano |
Location: Midland, MI | I thought human sensitivity was 20Hz-20KHz (generally speaking).
0.33Hz would be considerably below audible, with a peak passing a point every three seconds. Even the gubbermint was (allegedly) using ELF to (allegedly) talk to subs, which is up around 20-30Hz, IIRC. |
Location: Earth·SolarSystem·LocalInterstellarCloud·Local Bub | I think he's up to far more sinister things than hailing subs...
From a reliable and *very recently* outted informant:
"The story of the Brown Note, also known as the “Disco Dump,” asserts the existence of a low frequency vibration which, when reproduced at sufficient volume, resonates with the depths of the human digestive tract to cause what medical personnel call “involuntary gastrointestinal motility.” Put in less technical terms, the Brown Note reputedly precipitates a loss of sphincter control, giving rise to immediate defecation. The frequency, between 5 and 20hz has been reportedly used recently at rock concerts..."
(This may very well explain my reaction at the last Limp Bizkut show I attended) |
Location: Ft. Lauderdale, Florida | M-Audio 192 Sound card, this will do for starters...(Will work on low freq's later...)
http://www.m-audio.com/products/en_us/Audiophile192-main.html
AB |
