Action on CC024
techman
Posted 2005-06-09 2:34 PM (#148138)
Subject: Action on CC024
June 2005
I tried out half a dozen Ovations in our local store, and fell in love with the Celebrity CC024 shallow bowl with quilted maple finish. I went back again today to have another try before parting with my cash and was surprised at how high the action seemed on this second visit, no real chance for easy string bends like I'm used to on my ancient Ibanez acoustic...
What I want to know is, is that a string type issue. With light strings (011/012) would I be okay for bends and stuff without losing the great tone?
Thanks for your help on this.
Posted 2005-06-09 2:46 PM (#148139 - in reply to #148138)
Subject: Re: Action on CC024
Lighter strings will definitely effect the tone.
techman
Posted 2005-06-09 3:55 PM (#148140 - in reply to #148138)
June 2005
But, where's the compromise point? Tone vs bendability?
Posted 2005-06-09 4:06 PM (#148141 - in reply to #148138)
I take some heat for using light strings but I'm okay with it. Try a few sets and see what fits best for you.
Posted 2005-06-09 4:12 PM (#148142 - in reply to #148138)
Take a shim (or two) out from under the saddle when you get it home to lower the action a bit . . . .
. . . now that I've made a that assinine statement, lemme ask . . . .
. . . . do Celebs HAVE shims?? :rolleyes:
Posted 2005-06-09 4:15 PM (#148143 - in reply to #148138)
I know my Ultra did. I would assume Celebs do as well.
Posted 2005-06-09 4:27 PM (#148144 - in reply to #148138)
There's a lot to consider. If you are playing plugged it will certainly make less of a difference. If you are playing acoustically it's what is acceptable to your ear. I personally like the power and tone of medium gage (13s), I can't hardly tolerate the sound of lighter strings. Bending the mediums is not difficult for me, but that's because I play nothing else.
You should consider lowering the set-up with the current strings, though that will also effect the tone, because you are softening the break angle of the strings over the saddle.
You should just experiment with finding a balance between tone and playability
Posted 2005-06-09 5:06 PM (#148145 - in reply to #148138)
"Bending the mediums is not difficult for me, but that's because I play nothing else."
He also kills a bear most days before breakfast.
Start light and go up - and welcome to the club.
Posted 2005-06-09 5:15 PM (#148146 - in reply to #148138)
Actually, I just wrestle them to the ground until they say, "Uncle"
Posted 2005-06-09 5:39 PM (#148147 - in reply to #148138)
Celebrity's have shims. Two I believe. I think they are different thickness so check and try removing the thinnest one frist.
Posted 2005-06-09 5:42 PM (#148148 - in reply to #148138)
How typically American. Not only are your bears the biggest and the meanest they can talk as well.
Posted 2005-06-09 6:03 PM (#148149 - in reply to #148138)
...And they have remarkably good grammer.
BruDeV
Posted 2005-06-09 8:13 PM (#148150 - in reply to #148138)
Just don't give them any warm beer.
techman
Posted 2005-06-10 2:16 AM (#148151 - in reply to #148138)
June 2005
Okay...good advice. So, I should go with the CC024 and just choose lighter strings/remove shims to get that movement. Isn't there an issue with taking all the strings off a guitar at once though to make that adjustment. I was always advised not to do that.
bauerhillboy
Posted 2005-06-10 5:45 AM (#148152 - in reply to #148138)
Don't listen to those naysayers. Just do it...everything will be OK.
techman
Posted 2005-06-10 6:13 AM (#148153 - in reply to #148138)
June 2005
Okay. So, I'm going to be happy with a CC024 - is that the consensus, they do a lovely black model...
Posted 2005-06-10 6:45 AM (#148154 - in reply to #148138)
Go for it. Make sure the neck is straight first, push down the first and 14th fret on the same string and the gap around the 6th-7th fret should be only about .005. If it is then pull the shims and lighten the strangs, all at once and play alot and add a verse to the my fingers are sore post.
Posted 2005-06-10 6:53 AM (#148155 - in reply to #148138)
" . . So, I'm going to be happy with a CC024 - is that the consensus . . ."
You've evidently played it. A couple of times.
Are YOU happy with it??
There's only one "concensus" that MATTERS - Yours.
Personally, I'd search out a USA model (even used), but that's just me. T'me, the Celebrities just don't feel/sound the same, but there are others here who love 'em . . . to each his own.
My advice (fwiw): Go back and spend a considerable amount of time with it. Does the guitar "speak" to you? D'ya think that (after you've yanked a shim) it'll be a natural extension of you??
If so,. . . buy it. If not, . . . walk away.
g'luck.
GrilledCheese
Posted 2005-06-10 7:16 AM (#148156 - in reply to #148138)
May 2005
g'luck.
That's exactly what I do. Even though I'm not that experienced of player. If it just doesn't sound and feel right, I just chalk it up to experience, and move on.
I figure I'll find the "right" one. Just takes time. :D
Posted 2005-06-10 4:05 PM (#148157 - in reply to #148138)
"If so,. . . buy it. If not, . . . walk away."
I've heard this is cliff's attitude to women as well.
Posted 2005-06-10 4:10 PM (#148158 - in reply to #148138)
See recent post in 'For Sale' section -alpep's "u681t..." thread....
Posted 2005-06-10 4:25 PM (#148159 - in reply to #148138)
:D
Posted 2005-06-10 4:38 PM (#148160 - in reply to #148138)
He might have to *run away* (real fast) from her...
Posted 2005-06-10 5:57 PM (#148161 - in reply to #148138)
I always thought that for women you were just supposed to rent them?
It's awfully expensive to buy.
bauerhillboy
Posted 2005-06-10 5:59 PM (#148162 - in reply to #148138)
Bought my wife 18 years ago. Costs me everything. Best purchase I'll ever make.
Posted 2005-06-10 6:20 PM (#148163 - in reply to #148138)
Your wife is the most expensive l*y you'll ever have.
Posted 2005-06-10 6:57 PM (#148164 - in reply to #148138)
The most expensive l*y you'll have is the one when your wife catches you at it. :eek:
Posted 2005-06-10 7:03 PM (#148165 - in reply to #148138)
Good point!
techman
Posted 2005-06-13 3:07 AM (#148166 - in reply to #148138)
June 2005
Got slightly off-message here didn't we fellas?
Maybe that's par for the course.
Anyway, I tried the CC024 again and came ful circle to my original gut feeling about it, that's it's very, very nice to play, and sounds far better than any of the others I tried in the shop. It's 250 quid online (as opposed to 350 in the shop)and I just got a Google AdSense cheque for my website that will cover that, so I'm going for it! Thanks for all the advice.
