Tuning Problem
GrilledCheese
Posted 2005-07-30 11:07 AM (#142330)
Subject: Tuning Problem
May 2005
Just received my Gibson Goth Explorer, awesome guitar BTW. Having a problem tuning it. I can tune all the strings, except the low E which doesn't even register on my Korg tuner as an E string. I was beginning to think the tuner was bad, but works great on my other guitars.
Supposedly it has a set of new strings on it. Could it be it had a bad low E string on it? I guess it could happen.
The string just sounds weird no matter where it's tuned. Should I try another set of strings? :rolleyes:
Posted 2005-07-30 11:56 AM (#142331 - in reply to #142330)
Subject: Re: Tuning Problem
Have you tried it with the pickup switch in a different position?
GrilledCheese
Posted 2005-07-31 7:48 AM (#142332 - in reply to #142330)
May 2005
Yes, I've tried it in all positions, still doesn't work. I even tried tuning it like you would an acoustic using the mike on the tuner, works on all the other strings except the low E. Strangest thing I've ever seen.
I could see it not working on one pickup or the other, maybe even both, but not acoustically. I bought a new set of strings for it, and a chromatic tuner (needed this anyway for the mandolin, and uke). I'll try that and see what happens. :D
Posted 2005-07-31 7:57 AM (#142333 - in reply to #142330)
How does it sound thru an amp? Can you just tune it by ear and is it OK? Dave
Paulcc1
Posted 2005-07-31 11:29 AM (#142334 - in reply to #142330)
September 2004
Bring it back where you bought it and let them restring it and tune it.
Paul
Posted 2005-07-31 1:09 PM (#142335 - in reply to #142330)
Yeah, I go for checking it by ear, and try it thru an amp.
Posted 2005-07-31 3:32 PM (#142336 - in reply to #142330)
I think it's the Gibson. Throw it away and start over.
Posted 2005-07-31 3:40 PM (#142337 - in reply to #142330)
try a new set of strings
a heavier gauge
see if the pickup is aligned under the string
take it back and get another one
GrilledCheese
Posted 2005-08-01 6:57 AM (#142338 - in reply to #142330)
May 2005
It would be nice if I could take it back, but this was an eBay buy. The guy I bought from said he had just replaced the strings, tuned and played it one last time to be sure it was in working condition, then loosened the strings for shipment. I think this may be the problem, so I have bought another set of strings, and will try those.
I tried the by ear tuning. Can't even get it remotely close that way either, haven't tried it through an amp yet. I know the pickups both work, so there has to be a problem with that one string.
karmanng
Posted 2005-08-01 11:47 AM (#142339 - in reply to #142330)
February 2003
Try cranking the string up slowly until the tuner picks up something, a G, A, D, etc.
Then you can bring it back down.
You have nothing to lose but a string, and maybe an eye, if your staring to closely!
LOOK OUT !!!
Posted 2005-08-01 1:58 PM (#142340 - in reply to #142330)
Wear gloves and safety goggles. Just like we all do when we use stuff like hammers.
williamfriggle
Posted 2005-08-01 2:29 PM (#142341 - in reply to #142330)
April 2003
It is a Gibson thing. A friend at church has a Les Paul and he has a horable time tuning it. Sell it and buy something that doesn't say Gibson on it. They ain't what they use to be.
Bill
Corvairfan
Posted 2005-08-01 3:05 PM (#142342 - in reply to #142330)
January 2004
Have you tried a different tuner? Have you tried fretting the 5th fret to make an A note and tune with that? I hear some tuners you need to try that.
Have you stretched the strings?
I don't know just tossing out some ideas. Hope there isn't a problem with the guitar but I suppose for like $70 you could take it to a Gibson authorized tech to set it up for you and tweek things like filing the nut and putting new strings on.
ChatMan
Posted 2005-08-01 3:23 PM (#142343 - in reply to #142330)
August 2004
I just put some new strings on one of my children this weekend. Didn't have a battery in for the on board tuner so I used another tuner I had laying about. I was really surprised at how the tuner responded. All the higher strings tuned up pretty easy. The tuner found the note easily and tracked the tuning process really well. But the low E registered all over the place. I'm assuming that symptom is related to the combination of vibration modes that the string is experiencing when brand new. After an hour or so, the string (ands tuner settled down). I like Corvairfan's idea. Tune it fretted first, to get it close, and then check it open. Might make a difference.
GrilledCheese
Posted 2005-08-01 5:21 PM (#142344 - in reply to #142330)
May 2005
I can get it to tune like the 5th string, but if I back it down it just won't work. I'm thinking it's the string. I will change them all tomorrow when I have more time to fool around with it. ;)
The string just sounds dead. Doesn't have any ring to it at all. Almost sounds muted. I'll get it figured out. :rolleyes:
Posted 2005-08-01 6:59 PM (#142345 - in reply to #142330)
If it sounds dead it probably isn't vibrating cleanly, maybe not seated in the nut or saddle just right? If some strings will tune they all should unless the angle of the bridge or nut are really wrong (this is not impossible but unlikely) The intonation might be off. Try a good tuner like an old Peterson (or whatever the modern equlivent is) that will show you the note and the harmonic and the 12th fret and all that.
When you're done call up Henry at Gibson (the CEO) and tell him his product sucks a mile of donkey sausage etc.....
GrilledCheese
Posted 2005-08-01 8:34 PM (#142346 - in reply to #142330)
May 2005
I'm going over it real good tomorrow. It has to be something I'm over looking. Sometimes I just don't see the obvious when it's staring me in the face. :D
I don't think ol' Henry would appreciate that... :)
BruDeV
Posted 2005-08-01 10:27 PM (#142347 - in reply to #142330)
Loose windings.
GrilledCheese
Posted 2005-08-02 7:03 PM (#142348 - in reply to #142330)
May 2005
Finally got it tuned. Sounds good through my amp too. I still think that low E string was bad, just doesn't quite have the ring to it like the others, so tomorrow I will change all of them. ;)
