Ovation "Plugged In"
jbob30
Posted 2005-08-02 1:31 PM (#141991)
Subject: Ovation "Plugged In"
August 2005
I have a Celebrity Deluxe model CC257 which I have had for many years. I don't know what year it was made. The electronics on it have a bass treble and gain, nothing else. I love the guitar and want to keep it, it sounds great acoustic, but the sound of it plugged in is aweful!! :( Very "thin" like a AM radio. I have tried strings, batteries, LOTS of different amps, every setting known to man, still the same.
I would like to try different electronics, but need advice on what to try and what will fit. I don't mind cutting the body bigger to fit other controls in it, as long as they will fit and look factory when finished. Any ideas?? :confused:
THANKS!!
Posted 2005-08-02 3:40 PM (#141992 - in reply to #141991)
Subject: Re: Ovation "Plugged In"
What do you plug it into? You may want to try an external pre-amp in the chain. Dave
PS - Welcome to the club.
Posted 2005-08-02 4:40 PM (#141993 - in reply to #141991)
Send a picture of the preamp you have. If the saddle/piezo is the wide kind this may work:
Preamp on eBay
Keep your eyes peeled and there may be a replacement out there.
jbob30
Posted 2005-08-02 5:59 PM (#141994 - in reply to #141991)
August 2005
Standingovation:
I have tried LOTS of different amps. Fender, Marshall, Peavey, Gallien-Krueger, Line 6, Austin, etc. and a Avalon tube preamp in my recording studio. None of them sound great, the Avalon pre sounded the best, but still not like it should. (Thanks for the welcome!!)
MWoody:
I'm not sure if the saddle/piezo is the wide kind or not?? It measures about 1/8 inch wide. Here are some pictures:
Thanks for the help!
jbob30
Posted 2005-08-03 8:35 PM (#141995 - in reply to #141991)
August 2005
Any other ideas???
Posted 2005-08-04 10:11 AM (#141996 - in reply to #141991)
Pickup is thinline. Not the best. I don't recognize the pre-amp? Is that the original Ovation pre-amp? Did you try by-passing the pre-amp and wiring direct to the jack, then to a good external pre-amp? I think you need to get this existing pre-amp somehow out of the equation. Dave
Posted 2005-08-04 10:19 AM (#141997 - in reply to #141991)
I agree with MasterWitko.
That pre-amp looks suspicious . . . .
williamfriggle
Posted 2005-08-04 10:20 AM (#141998 - in reply to #141991)
April 2003
My question would be, these amps you are trying, are they designed for acoutsic guitars, or electric? Electric guitars amps are very heavy in the mid range. To get a truely good acoustic sound you need an amp designed for acoustic guitars.
Bill
Posted 2005-08-04 10:23 AM (#141999 - in reply to #141991)
I've never seen that pre before. I've also never seen Ovation put one on that overlaps the binding like that.
Dave's advice is good - try wiring the p/u direct to the jack.
Markthemagic
Posted 2005-08-04 10:27 AM (#142000 - in reply to #141991)
June 2004
Your list of amps that you have tried all look like electric guitar amps. There is a big difference between electric guitar amps and acoustic guitar amps. Have you tried your guitar with an acoustic guitar amp or directly into a PA system?
Many of the bigger guitar stores have acoustic guitar amps set up so you can try your guitar with them. A good way to sell an acoustic guitar amp in my opinion.
jbob30
Posted 2005-08-04 1:02 PM (#142001 - in reply to #141991)
August 2005
Thanks for all the replies!!
You say the thinline is not the best. What would it take to change it to the other style? I assume cutting the groove wider and changing the saddle?
As far as I know it is the original pre-amp, but I am not the original owner, so I am not 100% sure.
The part where it looks like the pre overlaps the binding is just the tuner I put on it. That is not part of the pre-amp.
Most of the amps I have tried are electric guitar amps, but I have tried several amps made for acoustic guitar. I have friends with Ovations, and they sound great in my current rig, much, much better than mine. I have also played their's and mine directly to a P.A. Their guitar sounds great, mine does not. And I have recorded Ovations through my Avalon tube pre in my recording studio. I can get an awesome sound through it----except for mine!!!
What I really think it is going to take is newer/better pick-up/pre-amp. Any ideas on what would be the best pick-up/pre-amp to use in this guitar?? Where can I purchase the newer electronic's, and will they fit? Like I said in my original post, I don't mind cutting the guitar as long as when it is finished it looks like it belongs there.
jbob30
Posted 2005-08-06 11:58 AM (#142002 - in reply to #141991)
August 2005
Any other idea's???
Posted 2005-08-06 12:43 PM (#142003 - in reply to #141991)
buy a USA model.
jbob30
Posted 2005-08-06 2:05 PM (#142004 - in reply to #141991)
August 2005
That's real helpful. Thanks :rolleyes:
Posted 2005-08-06 2:19 PM (#142005 - in reply to #141991)
Please don't be put off by the short answer. You could try to fit current up-grades into you guitar, spend alot of money, and still end up with something less than hoped for.
You might concider Cliff's answer.....
abrupt
insensitive
crude
ill-mannered
childish
And just plain rude....However......He's right.
Posted 2005-08-06 2:50 PM (#142006 - in reply to #141991)
He is right.
You get what you pay for. Luckily, there are USA built Ovations on ebay for $4-$700 that are outstanding guitars. I would consider something like that.
Posted 2005-08-06 2:55 PM (#142007 - in reply to #141991)
Aphex makes a stompbox called an Acoustic X-citer (I believe John (Strumming-12) uses one with much accolades). Y'could try one of them.
Or else try following MasterWitko's advice and go "direct out" to a better outboard pre.
To me, going through the time, EXPENSE and aggravation of routing/cutting a Celebrity for a different pickup/preamp just isn't worth it. The analogy of "polishing a turd" comes to mind . . .
but then, being abrupt, insensitive, crude, ill-mannered, childish, and just plain rude, . . . what th'F(&^@ do I know?? . . .
jbob30
Posted 2005-08-06 8:56 PM (#142008 - in reply to #141991)
August 2005
Thanks again for the replies. I realize my guitar is a cheap one, and you are probably right it does make since to go with something else, BUT I really, REALLY like this guitar!!!
Also you are probably right if I were go direct out to a good preamp it might sound good, but if the pickup is not a good one either, then your analogy of "polishing a turd" would apply to that also. Plus I would have controls on the guitar that didn't work, that would drive me NUTS!!!!
This guitar plays exactly like I like, and sounds great acoustic. So I do want to keep it, even if it doesn't make since. Plus I enjoy working on things (I have built a couple of custom show cars) so the time spent routing/cutting for different pickup/preamp would be enjoyable for me.
So what I am trying to say is, I want to give it a try. But I still need to know the answer to my original question. What Ovation pickup/preamp do you guys think sounds best, (I would like to keep it a factory, Ovation style), and where can I get them??
THANKS!!!
tpa
Posted 2005-08-07 7:58 AM (#142009 - in reply to #141991)
I had a Celebrity CC024 also with a thinline. It wasn't bad. The main annoyances were that (a) is was very sensitive to picking noises (b) it was humming sensitive. The preamp was OP-20.
You should consider removing the strings, saddle and pickup for inspecting the electrical connections and checking that the pickup seat is OK under all strings. You can find a description in the manual page 6. The second reference provides some good technical considerations which may also be of help in trouble shooting.
http://www.ovationguitars.com/img/OVmanual.pdf
http://www.fishman.com/uploads/products/documents/118.pdf
Bluebird
Posted 2005-08-07 10:18 AM (#142010 - in reply to #141991)
Keep in mind that if the preamp is not original, chances are the pickup is not the oem Ovation thinline either. I have on thinline equipped Ovation that I run directly to the output jack and then to a LR Baggs Para Acoustic DI. This sounds wonderful live.
However, for recording, I would try straight miking or double dtracking with a mike and blending the two sounds together.
Wayne
Posted 2005-08-07 10:29 AM (#142011 - in reply to #141991)
That's that cheesy shiny plastic guitar, isn't it Wayne?
Bluebird
Posted 2005-08-07 10:34 AM (#142012 - in reply to #141991)
Yes Paul, but it is that vintage shiny cheese that sounds vastly superior to some of the newer cheese!
Wayne
Posted 2005-08-07 10:42 AM (#142013 - in reply to #141991)
Agreed.
jbob30
Posted 2005-08-15 11:12 AM (#142014 - in reply to #141991)
August 2005
Thanks again for all the replies, I do appreciate them. But none of them have answered my origianl questions!! I have asked the same basic questions three times before, so I will try to rephrase them, maybe that will help!!
1. What Ovation pre/pickup do you like best? (This question is an opinion, so I know you can answer it...everyone has an opinion!!)
2. Where can I purchase these parts?? (Maybe you haven't answered this question because you don't know???)
Thanks again!!
Posted 2005-08-15 11:18 AM (#142015 - in reply to #141991)
1. OP 24 OP 50 OP Pro -- all with original pickup
2. Ovation Customer Service.
That's as clear as I can make it.
Posted 2005-08-15 11:29 AM (#142016 - in reply to #141991)
Optima with XLR output
Posted 2005-08-15 11:31 AM (#142017 - in reply to #141991)
I would guess that most here think the "wider" pickup performs better than the "thinline" pick-up. I don't think the wide pick-up has a consumer type part number. Some guitars are built for the thin, some for the thick. I would think the only place to buy them is from Ovation Customer Service or have your dealer order one for you.
That being said, I think your going to wind up with a "round peg in a square hole" situation. Are you prepared to take a router to the saddle groove in the bridge? And there might be other things to concider that I don't know about.
ChatMan
Posted 2005-08-15 12:23 PM (#142018 - in reply to #141991)
August 2004
I'd go with SO's recommendation. Optima with XLR try it with the existing pickup and if you don't like that, then go the router route. But I like the Optima better than anything else I've tried (OP24+E , OP PRO and Optima).
mtnbikerfred
Posted 2005-08-15 1:14 PM (#142019 - in reply to #141991)
Anyone ever see this?
Not an OPP
Posted 2005-08-15 1:25 PM (#142020 - in reply to #141991)
I'm thinking its the Celebrity made unit. Alls fair in the World market.
Posted 2005-08-16 5:31 AM (#142021 - in reply to #141991)
me like Optima too.
with opp
jbob30
Posted 2005-08-19 8:47 AM (#142022 - in reply to #141991)
August 2005
It seems most votes are for the Optima, so I thought I would give that a try. I went to the Ovation web site and under the title "where to buy parts for your Ovation" it said call your local dealer. So I did and was told Ovation will not sell upgrade parts for their guitars. So am I out of luck, or is there another place to get parts??
There must be a way to buy parts or on Ovations web site under "where to buy parts for your Ovation" it would have said "parts are not available"....wouldn't it???
Posted 2005-08-19 8:54 AM (#142023 - in reply to #141991)
Email Kim Keller, Customer Service. [email]kkeller-kmc@kaman.com[/email]
jbob30
Posted 2005-08-19 12:47 PM (#142024 - in reply to #141991)
August 2005
Thanks for the info, I will give that a try!!
