changing the nut and saddle to make strings wider
johbren
Posted 2005-08-25 10:11 PM (#139254)
Subject: changing the nut and saddle to make strings wider
on my custom balladeer there seams to be a lot of room from the big and little e strings to the edge of the fret board I wonder if a person could have a new nut and saddle cut to make the string spacing a little wider to make fingerpicking more easy
Posted 2005-08-25 10:15 PM (#139255 - in reply to #139254)
Subject: Re: changing the nut and saddle to make strings wider
Either a human, a person or/and an OFC member could do it.
Posted 2005-08-26 7:59 AM (#139256 - in reply to #139254)
On your saddle, just move the strings. You'll need a new nut cut though, no way to do it yourself.
leftovertion
Posted 2005-08-26 9:13 AM (#139257 - in reply to #139254)
July 2004
I did it on my Legend; just wanted to squeeze a little more room in between the strings, since I'm used to a 1 3/4" nut.
Just be careful that you don't get them TOO CLOSE to the edge of the fingerboard/frets; you'll be sliding off with minor pulls and bends (especially on the high E, there is some natural tendency to pull it toward the edge of the fingerboard, so leave a little "insurance space"). But there is some room to widen the spacing.
Posted 2005-08-26 9:44 AM (#139258 - in reply to #139254)
You'll want to leave about 1/8" on either side of the strings so they don't go off the side. (You can get closer if you can play that good)
I've always looked for 1 3/4 necks with 1 1/2 string spacing.
