Of truss rod wrenches and goblins
iconocoustica
Posted 2005-10-31 5:24 PM (#131147)
Subject: Of truss rod wrenches and goblins
July 2003
Does anyone know if the center soundhole 12-string O's (e.g., Legend) use a different sized truss rod wrench than the multi-hole O's (e.g., Elite)? I have been trying to adjust the rod on my CL-12 with my CE-6 wrench and the wrench seems too small.
Franklin
P.s. Happy Halloween!
iconocoustica
Posted 2005-11-01 1:21 PM (#131148 - in reply to #131147)
Subject: Re: Of truss rod wrenches and goblins
July 2003
Bump
Does anyone who has a 6 and a 12 know if they need different wrenches?
Thanks
Franklin
Posted 2005-11-01 1:39 PM (#131149 - in reply to #131147)
same wrench for all 6 string, but no 12 string to know if it is different.
John B
Posted 2005-11-02 12:14 PM (#131150 - in reply to #131147)
January 2004
My Legend LX 6 + 12 have the same size hex nut. I use the same wrench for both with no problem.
Erniewan
Posted 2005-11-02 12:28 PM (#131151 - in reply to #131147)
June 2004
yep, same here....use the same size..
Buckaroo
Posted 2005-11-02 4:54 PM (#131152 - in reply to #131147)
The book calls for a 1/4" nut driver for the headstock adjustment. Inside the guitar, at the base of the neck, the rod size is unknown to me. I don't know if it's male or female. If it's female it's probably 3/16 or smaller. Maybe 5/32.
If it's male the size should be 1/4 " also.
Franklin, is your CL-12 guitar new? If someone has tried to use a smaller, or incorrect sized tool, it's possilbe the rod hole has been wallowed out. It's easy to mess up a hexagonal hole if the allen wrench is off sized. You might try a ball nosed allen wrench for adjustment, or you can slightly taper the edges of your tool, with a file, to get it to seat deeper in the hole. This technique would only apply to a female hex, as in a cap head bolt. That's about all I can suggest. I'll check inside one of my Ovations to see what it is, and come back later with a report. Other members are saying that all the rods take the same wrench and I believe them. The likelihood of different sized rods would be slim. Good Luck, Buck
