Help with dead preamp
Posted 2005-11-04 1:56 PM (#130525)
Subject: Help with dead preamp
Following Northcountry's advice that any idiot can take the shims out of my daughter's Celebrity Deluxe CS247, I did it last night. Took out the 2 that looked like little finger nail files and left in the white plastic one. Helped the action a lot, but when I plugged it in, the low strings weren't amplified. The bass control on the equalizer didn't seem to do anything, but I couldn't tell if the pickup wasn't working on the low strings or just wasn't transmitting through the equalizer. Any ideas before I mess with it again and screw something else up?
Guitar Center said they'd do it when I bought it, but I told them I wanted to mess with it myself. Just call me Tim Allen.
Buckaroo
Posted 2005-11-04 2:17 PM (#130526 - in reply to #130525)
Subject: Re: Help with dead preamp
Hi Tim, make sure the bridge slot is clear and flat. Also the bone(white plastic thingy) needs to be flat so that the pickup rides evenly on top of it. If there is gaposis, the pickup sometimes does not function properly. Good Luck
Posted 2005-11-04 2:18 PM (#130527 - in reply to #130525)
Piezo crystals depend on pressure to work.
Posted 2005-11-04 4:03 PM (#130528 - in reply to #130525)
Thanks, guys. Fortunately, I didn't wait until Christmas Eve to screw this up. Last year I screwed up my other daughter's Ibanez after Christmas. It had a lot of noise in the preamp and I opened it up to look at it, promptly pulling off the wires to the preamp. Those Fishman preamps sure have tiny little wires and contacts. Took me a couple of days to solder it back together enough so she could send it back for warranty work.
Tim the Tool Man is my hero. A long history of disasters don't deter me from continuing to do it myself. Why do we play guitar rather than just listen to someone else?
Northcountry
Posted 2005-11-06 8:09 AM (#130529 - in reply to #130525)
Jeees somehow these messages make me feel responsible?
This problem should not be my friend, removing shims is a common practice among all guitar players, experienced and novices alike. Not that much more uncommon than changing strings really. I can't speak for anyone else here but I have never had an electric problem with any Guitar after resetting the action. And sometimes this process take several tries to get it where I like it. Unless I forgot to plug something back in, in the process.
Question? did you try the electronics before you moved the bridge? I mean; was this a new guitar or has it beeen used already? If it's new you may have had an electronics problem already, Hope you had the GC plug this in before you left the store?
I sure hope one of these guy's who have the experince to have either had this problem or have heard of others who did and can help will do so. Sounds like this may be as simple as having a loose plug not all the way in somewhere???
I thought after playing for 26 years and owning Ovation guitars for almost as many I could advise you to take out a shim or two to help your Daughter play the higher frets a little better?
Very sorry indeed if this adventure did not go well? I am very confused why that pickup will only work on one side??? I can tell you it should not have had anything to do with changing your action unless something was put back incorrectly but then you would see that when you tightened the strings? the bridge would obviously be sitting at an angle?
Beffuddled in Northville?
Randy
Posted 2005-11-06 9:10 AM (#130530 - in reply to #130525)
Lawyer + Technology = broken technology...
Posted 2005-11-06 9:36 AM (#130531 - in reply to #130525)
"Now I don't care who ya are....That's funny " :D
And just for you Mark .....copyright 2005 - Larry the Cable Guy
Posted 2005-11-06 11:14 PM (#130532 - in reply to #130525)
Sorry it sounded like I was blaming you Randy. I admit any idiot ought to be able to take out the shims. I fixed it tonight. I think the "white plastic thingy" wasn't pushed all the way to the bass side, causing the bass pickup to not pick up. This time I opened it up, made sure everything was seated properly and it works great.
And Randy, I was almost stupid enough to buy the guitar without checking the electronics, but I remembered at the last minute and it checked out fine. Tuner worked fine too, but didn't work on the low E string after I screwed it up. Works fine now. If there's a way, I will find it.
And I really do appreciate the help, Randy and everyone. Now if anyone has a dead string when they change shims, I've paved the way. Just move the white plastic thingy.
Posted 2005-11-07 9:09 AM (#130533 - in reply to #130525)
Now, Mark. Just like a lawyer, using obscure technical terms to obfuscate the dialogue.
Posted 2005-11-07 9:37 AM (#130534 - in reply to #130525)
You should have heard the terms I was using when I was trying to fix the plumbing under the cabin this weekend. Nothing over 4 letters.
I have to give Buckaroo credit for using terms that I could understand--white plastic thingy and gaposis.
Posted 2005-11-07 9:38 AM (#130535 - in reply to #130525)
What, plumbing again? I thought you had that fixed already?
Posted 2005-11-07 9:52 AM (#130536 - in reply to #130525)
I fix one thing and something else goes wrong. Wife's new kitchen faucet was plugged with sand. I couldn't get it apart. The old faucet worked fine, but she threw it away. I keep trying to dig a hole to fix an underground valve. I should have finished that before we built the mother of all decks over the valve. It's really hard to work under the deck. I gave up on that again after a bunch of cussing.
Posted 2005-11-07 9:57 AM (#130537 - in reply to #130525)
Cut a hatch in the deck over where the valve is, then reinforce around it to support it well. You may need to get to it in the future. Then build an insulated enclosure around the valve so you can get to it without having to dig it out.
Northcountry
Posted 2005-11-07 12:04 PM (#130538 - in reply to #130525)
Cool.
See........ now you know more about Ovation guitars than you did or perhaps ever wanted.
Those medium body Korean guitars are pretty well made for what they are and they certainly look fantastic and sound better than they ought to for the price. Nice buy.... I did the same for my daughter, she just loves it!
And yeah....... I know any Idiot can change shims Hell Cliff's been doing it for years!
Randy
Posted 2005-11-07 4:15 PM (#130539 - in reply to #130525)
Randy, I may have to confess to being even more inept than Cliff. I responded to Waskel's plumbing advice, but must have forgot to hit Add Reply again and lost what I had typed. Half the ones I do send, I read later and quickly spot mistakes or can't figure out why I typed what I did.
Posted 2005-11-07 4:19 PM (#130540 - in reply to #130525)
Waskel,
I built the trap door last summer. Only problem is that I need a bigger hole than the trapdoor allows.
Posted 2005-11-07 4:48 PM (#130541 - in reply to #130525)
". . I know any Idiot can change shims Hell Cliff's been doing it for years! . ."
". . even more inept than Cliff . ."
AssWipes.
Posted 2005-11-07 7:07 PM (#130542 - in reply to #130525)
Being more inept than you offends you? Sorry. I take it back. You're more inept than me, from what everybody else says.
Posted 2005-11-08 9:00 AM (#130543 - in reply to #130525)
Now, Cliffie... You should be honored that so many here hold you up as an example.
In many ways, we like to think of you as our 'benchmark'. ;)
Posted 2005-11-08 9:26 AM (#130544 - in reply to #130525)
The only ineptitude I'll "fess up to" is my guitar-playing.
I'm actually pretty good at "making things work" . . .
Posted 2005-11-08 10:22 AM (#130545 - in reply to #130525)
Come on out, Cliff. I have lots of projects for you.
Posted 2005-11-08 10:33 AM (#130546 - in reply to #130525)
Starting with the plumbing...
Posted 2005-11-08 10:44 AM (#130547 - in reply to #130525)
You're problem is simple:
Cabin.
Plumbing.
A "Cabin" isn't supposed t'HAVE "Plumbing".
Posted 2005-11-08 11:24 AM (#130548 - in reply to #130525)
You've just graduated to a "Vacation Home"! That is going to cost you!
Your best bet is to make it into a "Mother inlaw Home" and cut your losses.
Dude
Posted 2005-11-08 12:25 PM (#130549 - in reply to #130525)
Hello !
Sorry Mark if you feel that I'm highjacking your thread, but a friend of me has got a similar problem with its guitar.
I don't know if it comes from the preamp nor the piezzo (the famous white plastic piece is deadly attacked). He's unable to get all the harmonics when plugged.
So, is it possible to change only the white piece ?
How can we change it ?
Where can we buy another one ?
Thank's !
PS : perhaps it is easier to buy a new axe ;) !
Posted 2005-11-08 1:31 PM (#130550 - in reply to #130525)
Dude, no problem. We all seemed to have hijacked my thread a long time ago. It seems like shims and plastic pieces should be available. I'd check with an Ovation dealer near you or contact Al (alpep).
One of our local dealers a year ago was telling me he was having trouble getting the factory to respond regarding parts for an Ovation I was thinking about buying. It had a similar problem with a dead string. He ended up selling the guitar to someone else and I never found out if he was just giving me an excuse. There are several different style of saddles and pickups, and I assume the white plastic thingys vary, too.
Posted 2005-11-08 1:41 PM (#130551 - in reply to #130525)
Back to the cabin issue, thanks for all the free advice guys. My mother in law died, so I can't call the cabin hers. Cliff, I don't know if someone from New Jersey knows what a cabin is, but many don't have plumbing. Too bad I tore down the outhouse last year or I could have sold it to you as a cabin.
I wish I graduated to a "vacation home", but since the Californians discovered McCall, Idaho vacation homes are running about $1,000,000 to $10 million, so my 1955 log cabin is still a cabin, even with all the remodels. Somebody will eventually offer me a bunch of money just to knock it down and take over my State lease of the land and I will get rid of it. That just happened to a neighbor. Someone paid $250,000 for an old cabin on a 10 year State lease and then knocked the cabin down to build a "vacation home" on it.
Posted 2005-11-08 1:55 PM (#130552 - in reply to #130525)
Used to live in a house that started out as a "cabin", evolved into "vacation home" which was later (tastefully) augmented into a three-story, passive-solar Contemporary (on a private lake).
Jersey actually has QUITE a bit of lakes, mountains & forests. People just generally equate it to factories, cities & urban sprawl (much the same way people generally equate Idaho to just fields of potatoes . . .).
Posted 2005-11-08 2:00 PM (#130553 - in reply to #130525)
I know, Cliff, or at least I've been told that. They must have called it the Garden State for some reason. Had a good friend in law school from Jersey City. He couldn't wait to go back. He was a judge there last I heard.
Dude
Posted 2005-11-08 3:20 PM (#130554 - in reply to #130525)
Thank's Mark for your answer.
Posted 2005-11-08 3:36 PM (#130555 - in reply to #130525)
Dude, it occurred to me that their are two white plastic thingys. There is the saddle, then below that there us the metal thingy that is actually attached to a wire that goes to the preamp, then below that there is a white plastic thingy that is loose along with similarly shaped shims. It was the white plastic thingy on the bottom that I moved to restore the sound from the preamp.
