| I have an ovation CS257. I purchased it 3yrs ago. The guitar is 90% no sound comes out when I plug-in to the amp. the guitar comes with a op30 pre-amp. The pre-amp works fine to me. I am wondering if there anything I can do to fix this problem! THX guys! |
Location: Keepin' It Weird in Portland, OR | Welcome Ernest.
Please clarify your problem.
(I probably don't know the answer, but someone will!) |
Location: ranson,wva | sounds like the pup died....check the battery..thats the obvious first thing to check...jason |
Location: Steeler Nation, Hudson Valley Contingent | Ahhh! Good to see someone else as new here as me!
As a former IT troubleshooter (couldn't get out of that job fast enough!), I suggest you make sure you are looking at the right piece of equipment before assuming the worst. Try using a different cable and the same amp. Try using the usual cable with a different amp. Try using a different cable and a different amp. If all this fails, it's time to look more closely at your guitar. And, come to think of it, you may want to put a fresh battery in the thing. Even if your present battery is relatively new, you may have installed a dud.
Good luck |
Location: Upper Left USA | IT Troublemakers, er, trouble shooter?
The parts of the sound assembly with the OP30 are:
Undersaddle piezo pickup
preamp
Preamp socket
Output jack wire harness
Battery
Isolating where the problem is helps. Customer Service can support the OP 30. |
Location: Steeler Nation, Hudson Valley Contingent | Depends on how much I like the client. :D |
