CHANGING PICKUPS ??
DEACON
Posted 2007-02-27 7:57 PM (#113032)
Subject: CHANGING PICKUPS ??
HELLO ! I WAS WONDERING IF ANYONE OUT THERE HAS EVER REMOVED THEIR BREADWINNER/DEACON PICKUPS AND SWAPED THEM IN FAVOR OF SOME OTHER BRAND OF ACTIVE PICKUP ? WOULD THE FET SYSTEM STILL FUNCTION ? I OWN 2 DEACONS , A BREADWINNER , & DEACON 12 - I'M JUST TOYING WITH THE IDEA OF MAYBE CHANGING THE PICKUPS IN ONE OF THE DEACONS TO SEE WHAT IT'S LIKE - PLEASE DON'T RUN ME OUT OF TOWN FOR THINKING IT ! IF I ONLY HAD ONE , I WOULD NOT EVEN CONSIDER IT ! THANKS TO ALL FOR YOUR ADVICE/INPUT & INSULTS IN ADVANCE !
Posted 2007-02-27 8:15 PM (#113033 - in reply to #113032)
Subject: Re: CHANGING PICKUPS ??
Originally posted by DEACON:
THANKS TO ALL FOR YOUR ... INSULTS IN ADVANCE !
OK YOU ASKED - GET YOUR KEYBOARD FIXED !!! READING ALL THOSE UPPER CASE LETTERS IS GIVING ME A HEADACHE.
To answer your question, yes it can be done. At least I've read others here who have put in new pu's in the deaconwinners. You'll get some advise (and insults).
Posted 2007-02-27 9:03 PM (#113034 - in reply to #113032)
Talk to Tom at www.tvjones.com and see what he can do for you!
And yes, CAPLOCKS is for angry people and Department of Defensense Senoir Brass. Also for those with some sight issues but you should pave the path first.
MW
numbfingers
Posted 2007-02-27 9:32 PM (#113035 - in reply to #113032)
Almost any mini-humbucker will work (assuming you have the smaller pickups). I like a clean lower output pickup like a Bartolini or Duncan SM-1N, but pickup choices are purely subjective. TV Jones does offer lots of choices.
It isn't the pickups that are active, it's the preamp. I've used EMG active mini-humbuckers but not through the Ovation preamp.
You'll need to make some sort of an adapter to match the mini humbucker mounting to the holes in the Ovation pickguard. Whatever you do, don't drill extra holes in the original guard. Make sure you keep track of the original pickups for later reinstallation. Sorry if this seems obvious, but I hate seeing butchered O's with missing parts.
-Steve W.
brainslag
Posted 2007-02-28 10:21 AM (#113036 - in reply to #113032)
Tweak your amp knobs. That'll give you a different sound! :D
